Commit a799eecf authored by PRUVOST Florent's avatar PRUVOST Florent
update warning parser
parent 6beb880f
...@@ -47,7 +47,8 @@ sonar.sources=build, compute, control, coreblas, example, include, runtime, test ...@@ -47,7 +47,8 @@ sonar.sources=build, compute, control, coreblas, example, include, runtime, test
sonar.inclusions=`cat filelist.txt | xargs echo | sed 's/ /, /g'` sonar.inclusions=`cat filelist.txt | xargs echo | sed 's/ /, /g'`
sonar.sourceEncoding=UTF-8 sonar.sourceEncoding=UTF-8
sonar.cxx.compiler.charset=UTF-8 sonar.cxx.compiler.charset=UTF-8
sonar.cxx.compiler.regex=^(.*):([0-9]+):[0-9]+: warning: (.*)\[(.*)\]$ sonar.cxx.compiler.parser=GCC
sonar.cxx.compiler.regex=^(.*):(\\d+):\\d+: warning: (.*)\\[(.*)\\]$
sonar.cxx.compiler.reportPath=chameleon-build.log sonar.cxx.compiler.reportPath=chameleon-build.log
sonar.cxx.coverage.reportPath=chameleon-coverage.xml sonar.cxx.coverage.reportPath=chameleon-coverage.xml
sonar.cxx.cppcheck.reportPath=chameleon-cppcheck.xml sonar.cxx.cppcheck.reportPath=chameleon-cppcheck.xml
