Commit 7f4befbd authored by PRUVOST Florent's avatar PRUVOST Florent
Install chameleon_env in bin/ and use it in the gitlab-ci build job
parent 29bde9ef
1 merge request!502Update CI to fix sonarqube job and use chameleon_env script in build
...@@ -64,10 +64,16 @@ eval '${SCAN}cmake --build build-${VERSION} -j 4 > /dev/null' ...@@ -64,10 +64,16 @@ eval '${SCAN}cmake --build build-${VERSION} -j 4 > /dev/null'
# Install # Install
cmake --install build-${VERSION} cmake --install build-${VERSION}
# Check link to chameleon # Check link to chameleon
cd .gitlab/check_link/
# Set the path variables
if [[ "$SYSTEM" == "windows" ]]; then
export PATH="/c/Windows/WinSxS/x86_microsoft-windows-m..namespace-downlevel_31bf3856ad364e35_10.0.19041.1_none_21374cb0681a6320":$PATH
fi
source install-${VERSION}/bin/chameleon_env
# Set the compiler # Set the compiler
if [[ "$SYSTEM" == "macosx" ]]; then if [[ "$SYSTEM" == "macosx" ]]; then
...@@ -78,21 +84,7 @@ else ...@@ -78,21 +84,7 @@ else
fi fi
export FC=gfortran export FC=gfortran
# Set the path variables cd .gitlab/check_link/
if [[ "$SYSTEM" == "guix" ]]; then
export LIBRARY_PATH=$PWD/../../install-${VERSION}/lib:$LIBRARY_PATH
export LD_LIBRARY_PATH=$PWD/../../install-${VERSION}/lib:$LD_LIBRARY_PATH
elif [[ "$SYSTEM" == "linux" ]]; then
elif [[ "$SYSTEM" == "macosx" ]]; then
export DYLD_LIBRARY_PATH=$PWD/../../install-${VERSION}/lib:$DYLD_LIBRARY_PATH
elif [[ "$SYSTEM" == "windows" ]]; then
export PATH=$PWD/../../install-${VERSION}/bin:$PATH
fi
# 1) using cmake: # 1) using cmake:
./link_cmake.sh $PWD/../../install-${VERSION} ./link_cmake.sh $PWD/../../install-${VERSION}
# 2) using pkg-config: # 2) using pkg-config:
...@@ -821,6 +821,8 @@ include(ChameleonPkgConfig) ...@@ -821,6 +821,8 @@ include(ChameleonPkgConfig)
# Create .pc file # Create .pc file
chameleon_generate_pkgconfig_files() chameleon_generate_pkgconfig_files()
generate_newenv_file(PACKAGE chameleon)
