Commit 69d821d3 authored by Mathieu Faverge's avatar Mathieu Faverge
Merge branch 'issue68' into 'master'
Fix issue #68 - Move the check of ncuda to the init function instead of doing it in timings
Closes #68
See merge request !145
parents 9abc1b22 40bc52b4
1 merge request!145Fix issue #68 - Move the check of ncuda to the init function instead of doing it in timings
Loading
