GitLab
Explore
Primary navigation
Search or go to…
Chameleon
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Container Registry
Operate
Environments
Terraform modules
Monitor
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
solverstack
Chameleon
62b14f81
62b14f81
7 years ago
Mathieu Faverge
Downloads
Patches
Disable dataflush in Parsec to avoid freeing a data before it's fully used in the sequence
95826f37
1 merge request
!72
PaRSEC DTD Interface
runtime/parsec/control/runtime_descriptor.c
+10
-3
10 additions, 3 deletions
10 additions
3 deletions
10
3
62b14f81
@@ -332,9 +332,16 @@ void RUNTIME_desc_flush( const MORSE_desc_t *desc,
void
RUNTIME_data_flush
const
MORSE_sequence_t
sequence
void
RUNTIME_data_flush
const
MORSE_sequence_t
sequence
const
MORSE_desc_t
A
int
Am
int
An
const
MORSE_desc_t
A
int
Am
int
An
parsec_taskpool_t
PARSEC_dtd_taskpool
parsec_taskpool_t
sequence
schedopt
* For now, we do nothing in this function as in PaRSEC, once the data is
parsec_dtd_data_flush
PARSEC_dtd_taskpool
RTBLKADDR
A
MORSE_Complex64_t
Am
An
* flushed it cannot be reused in the same sequence, when this issue will be
* fixed, we will uncomment this function
/* parsec_taskpool_t* PARSEC_dtd_taskpool = (parsec_taskpool_t *)(sequence->schedopt); */
/* parsec_dtd_data_flush( PARSEC_dtd_taskpool, RTBLKADDR( A, MORSE_Complex64_t, Am, An ) ); */
void
sequence
void
A
void
Am
void
An
return
This diff is collapsed.
Loading
Save comment
