Commit 58684e26 authored by LISITO Alycia's avatar LISITO Alycia
zgetrf: Add option to set a unique size of batch
parent 508be3fe
1 merge request!523Restructuration of the codelets getrf and getrf_nopiv
...@@ -59,7 +59,7 @@ CHAMELEON_zgetrf_WS_Alloc( const CHAM_desc_t *A ) ...@@ -59,7 +59,7 @@ CHAMELEON_zgetrf_WS_Alloc( const CHAM_desc_t *A )
CHAM_context_t *chamctxt; CHAM_context_t *chamctxt;
struct chameleon_pzgetrf_s *ws; struct chameleon_pzgetrf_s *ws;
int lookahead; int lookahead, batch_size;
chamctxt = chameleon_context_self(); chamctxt = chameleon_context_self();
if ( chamctxt == NULL ) { if ( chamctxt == NULL ) {
...@@ -114,21 +114,16 @@ CHAMELEON_zgetrf_WS_Alloc( const CHAM_desc_t *A ) ...@@ -114,21 +114,16 @@ CHAMELEON_zgetrf_WS_Alloc( const CHAM_desc_t *A )
chameleon_cleanenv( allreduce ); chameleon_cleanenv( allreduce );
ws->batch_size_blas2 = chameleon_getenv_get_value_int( "CHAMELEON_GETRF_BATCH_SIZE_BLAS2", 0 ); batch_size = chameleon_getenv_get_value_int( "CHAMELEON_GETRF_BATCH_SIZE", 0 );
if ( ws->batch_size_blas2 > CHAMELEON_BATCH_SIZE ) { if ( batch_size > CHAMELEON_BATCH_SIZE ) {
chameleon_warning( "CHAMELEON_BATCH_SIZE", "CHAMELEON_GETRF_BATCH_SIZE_BLAS2 must be smaller than CHAMELEON_BATCH_SIZE, please recompile with the right CHAMELEON_BATCH_SIZE, or reduce the CHAMELEON_GETRF_BATCH_SIZE_BLAS2 value\n" ); chameleon_warning( "CHAMELEON_BATCH_SIZE", "CHAMELEON_GETRF_BATCH_SIZE must be smaller than CHAMELEON_BATCH_SIZE, please recompile with the right CHAMELEON_BATCH_SIZE, or reduce the CHAMELEON_GETRF_BATCH_SIZE value\n" );
ws->batch_size_blas2 = CHAMELEON_BATCH_SIZE;
ws->batch_size_blas3 = chameleon_getenv_get_value_int( "CHAMELEON_GETRF_BATCH_SIZE_BLAS3", 0 );
if ( ws->batch_size_blas3 > CHAMELEON_BATCH_SIZE ) {
chameleon_warning( "CHAMELEON_BATCH_SIZE", "CHAMELEON_GETRF_BATCH_SIZE_BLAS3 must be smaller than CHAMELEON_BATCH_SIZE, please recompile with the right CHAMELEON_BATCH_SIZE, or reduce the CHAMELEON_GETRF_BATCH_SIZE_BLAS3 value\n" );
ws->batch_size_blas3 = CHAMELEON_BATCH_SIZE;
ws->batch_size_swap = chameleon_getenv_get_value_int( "CHAMELEON_GETRF_BATCH_SIZE_SWAP", 0 );
if ( ws->batch_size_swap > CHAMELEON_BATCH_SIZE ) {
chameleon_warning( "CHAMELEON_BATCH_SIZE", "CHAMELEON_GETRF_BATCH_SIZE_SWAP must be smaller than CHAMELEON_BATCH_SIZE, please recompile with the right CHAMELEON_BATCH_SIZE, or reduce the CHAMELEON_GETRF_BATCH_SIZE_SWAP value\n" );
ws->batch_size_swap = CHAMELEON_BATCH_SIZE;
ws->batch_size_blas2 = chameleon_getenv_get_value_int( "CHAMELEON_GETRF_BATCH_SIZE_BLAS2", batch_size );
ws->batch_size_blas2 = ( ws->batch_size_blas2 > CHAMELEON_BATCH_SIZE ) ? CHAMELEON_BATCH_SIZE : ws->batch_size_blas2;
ws->batch_size_blas3 = chameleon_getenv_get_value_int( "CHAMELEON_GETRF_BATCH_SIZE_BLAS3", batch_size );
ws->batch_size_blas3 = ( ws->batch_size_blas3 > CHAMELEON_BATCH_SIZE ) ? CHAMELEON_BATCH_SIZE : ws->batch_size_blas3;
ws->batch_size_swap = chameleon_getenv_get_value_int( "CHAMELEON_GETRF_BATCH_SIZE_SWAP", batch_size );
ws->batch_size_swap = ( ws->batch_size_swap > CHAMELEON_BATCH_SIZE ) ? CHAMELEON_BATCH_SIZE : ws->batch_size_swap;
ws->ringswitch = chameleon_getenv_get_value_int( "CHAMELEON_GETRF_RINGSWITCH", INT_MAX ); ws->ringswitch = chameleon_getenv_get_value_int( "CHAMELEON_GETRF_RINGSWITCH", INT_MAX );
