Commit 51e834a5 authored by PRUVOST Florent's avatar PRUVOST Florent Committed by Mathieu Faverge
fix header timing
parent 6c0ac13b
1 merge request!122Release/header
......@@ -13,8 +13,8 @@
* @precisions normal z -> c d s
#ifndef TIMING_ZAUXILIARY_H
#define TIMING_ZAUXILIARY_H
#ifndef _timing_zauxiliary_h_
#define _timing_zauxiliary_h_
int z_check_orthogonality (int M, int N, int LDQ, CHAMELEON_Complex64_t *Q);
int z_check_QRfactorization (int M, int N, CHAMELEON_Complex64_t *A1, CHAMELEON_Complex64_t *A2, int LDA, CHAMELEON_Complex64_t *Q);
......@@ -41,4 +41,4 @@ int zcheck_inverse(int N, CHAMELEON_Complex64_t *A1, CHAMELEON_Complex64_t *A2,
int LDA, cham_uplo_t uplo, double *rnorm, double *anorm, double *ainvnorm);
#endif /* TIMING_ZAUXILIARY_H */
#endif /* _timing_zauxiliary_h_ */
