Commit 5155ebde authored by Mathieu Faverge's avatar Mathieu Faverge
Merge branch 'descriptor/ranks' into 'master'
descriptor: Add a rank_of_init function to store the initial distribution, and...
See merge request !340
parents 9610ba58 981e38a4
1 merge request!340descriptor: Add a rank_of_init function to store the initial distribution, and...
...@@ -42,7 +42,7 @@ chameleon_pzgenm2( double tol, const CHAM_desc_t *A, double *result, ...@@ -42,7 +42,7 @@ chameleon_pzgenm2( double tol, const CHAM_desc_t *A, double *result,
int cnt, maxiter; int cnt, maxiter;
double e0, normx, normsx, beta, scl; double e0, normx, normsx, beta, scl;
if ( A->get_rankof != chameleon_getrankof_2d ) { if ( A->get_rankof_init != chameleon_getrankof_2d ) {
sequence->status = CHAMELEON_ERR_NOT_SUPPORTED; sequence->status = CHAMELEON_ERR_NOT_SUPPORTED;
...@@ -171,7 +171,7 @@ void *CHAMELEON_zgemm_WS_Alloc( cham_trans_t transA __attribute__((unused) ...@@ -171,7 +171,7 @@ void *CHAMELEON_zgemm_WS_Alloc( cham_trans_t transA __attribute__((unused)
/* Now that we have decided which algorithm, let's allocate the required data structures. */ /* Now that we have decided which algorithm, let's allocate the required data structures. */
if ( (options->alg == ChamGemmAlgSummaC ) && if ( (options->alg == ChamGemmAlgSummaC ) &&
(C->get_rankof == chameleon_getrankof_2d ) ) (C->get_rankof_init == chameleon_getrankof_2d ) )
int lookahead = chamctxt->lookahead; int lookahead = chamctxt->lookahead;
...@@ -150,7 +150,7 @@ void *CHAMELEON_zhemm_WS_Alloc( cham_side_t side __attribute__((unused)), ...@@ -150,7 +150,7 @@ void *CHAMELEON_zhemm_WS_Alloc( cham_side_t side __attribute__((unused)),
...@@ -150,7 +150,7 @@ void *CHAMELEON_zsymm_WS_Alloc( cham_side_t side __attribute__((unused)), ...@@ -150,7 +150,7 @@ void *CHAMELEON_zsymm_WS_Alloc( cham_side_t side __attribute__((unused)),
...@@ -119,19 +119,19 @@ void chameleon_pclag2z(CHAM_context_t *chamctxt); ...@@ -119,19 +119,19 @@ void chameleon_pclag2z(CHAM_context_t *chamctxt);
#if defined(__GNUC__) #if defined(__GNUC__)
static inline void chameleon_asprintf( char **strp, const char *fmt, ... ) __attribute__((format(printf,2,3))); static inline int chameleon_asprintf( char **strp, const char *fmt, ... ) __attribute__((format(printf,2,3)));
#endif #endif
static inline void chameleon_asprintf( char **strp, const char *fmt, ... ) static inline int chameleon_asprintf( char **strp, const char *fmt, ... )
va_list ap; va_list ap;
int rc; int rc;
va_start( ap, fmt ); va_start( ap, fmt );
rc = asprintf( strp, fmt, ap ); rc = asprintf( strp, fmt, ap );
va_end(ap); va_end( ap );
assert( rc != -1 ); assert( rc != -1 );
(void)rc; return rc;
#ifdef __cplusplus #ifdef __cplusplus
...@@ -242,7 +242,7 @@ chameleon_zdesc_copy_and_restrict( const CHAM_desc_t *descIn, ...@@ -242,7 +242,7 @@ chameleon_zdesc_copy_and_restrict( const CHAM_desc_t *descIn,
m, n, 0, 0, m, n, descIn->p, descIn->q, m, n, 0, 0, m, n, descIn->p, descIn->q,
descIn->get_blkaddr, descIn->get_blkaddr,
descIn->get_blkldd, descIn->get_blkldd,
descIn->get_rankof ); descIn->get_rankof_init );
return rc; return rc;
...@@ -88,22 +88,24 @@ int chameleon_desc_mat_free( CHAM_desc_t *desc ) ...@@ -88,22 +88,24 @@ int chameleon_desc_mat_free( CHAM_desc_t *desc )
return CHAMELEON_SUCCESS; return CHAMELEON_SUCCESS;
void chameleon_desc_init_tiles( CHAM_desc_t *desc ) void chameleon_desc_init_tiles( CHAM_desc_t *desc, blkrankof_fct_t rankof )
CHAM_tile_t *tile; CHAM_tile_t *tile;
int ii, jj; int ii, jj;
assert( rankof != chameleon_getrankof_tile );
desc->tiles = malloc( desc->lmt * desc->lnt * sizeof(CHAM_tile_t) ); desc->tiles = malloc( desc->lmt * desc->lnt * sizeof(CHAM_tile_t) );
tile = desc->tiles; tile = desc->tiles;
for( jj=0; jj<desc->lnt; jj++ ) { for( jj=0; jj<desc->lnt; jj++ ) {
for( ii=0; ii<desc->lmt; ii++, tile++ ) { for( ii=0; ii<desc->lmt; ii++, tile++ ) {
int rank = desc->get_rankof( desc, ii, jj ); int rank = rankof( desc, ii, jj );
tile->format = CHAMELEON_TILE_FULLRANK; tile->format = CHAMELEON_TILE_FULLRANK;
tile->m = ii == desc->lmt-1 ? desc->lm - ii * desc->mb : desc->mb; tile->rank = rank;
tile->n = jj == desc->lnt-1 ? desc->ln - jj * desc->nb : desc->nb; tile->m = ii == desc->lmt-1 ? desc->lm - ii * desc->mb : desc->mb;
tile->mat = (rank == desc->myrank) ? desc->get_blkaddr( desc, ii, jj ) : NULL; tile->n = jj == desc->lnt-1 ? desc->ln - jj * desc->nb : desc->nb;
tile->ld = desc->get_blkldd( desc, ii ); tile->mat = (rank == desc->myrank) ? desc->get_blkaddr( desc, ii, jj ) : NULL;
#if defined(CHAMELEON_KERNELS_TRACE) #if defined(CHAMELEON_KERNELS_TRACE)
chameleon_asprintf( &(tile->name), "%s(%d,%d)", desc->name, ii, jj ); chameleon_asprintf( &(tile->name), "%s(%d,%d)", desc->name, ii, jj );
#endif #endif
...@@ -215,7 +217,8 @@ int chameleon_desc_init_internal( CHAM_desc_t *desc, const char *name, void *mat ...@@ -215,7 +217,8 @@ int chameleon_desc_init_internal( CHAM_desc_t *desc, const char *name, void *mat
desc->get_blktile = chameleon_desc_gettile; desc->get_blktile = chameleon_desc_gettile;
desc->get_blkaddr = get_blkaddr ? get_blkaddr : chameleon_getaddr_ccrb; desc->get_blkaddr = get_blkaddr ? get_blkaddr : chameleon_getaddr_ccrb;
desc->get_blkldd = get_blkldd ? get_blkldd : chameleon_getblkldd_ccrb; desc->get_blkldd = get_blkldd ? get_blkldd : chameleon_getblkldd_ccrb;
desc->get_rankof = get_rankof ? get_rankof : chameleon_getrankof_2d; desc->get_rankof = chameleon_getrankof_tile;
desc->get_rankof_init = get_rankof ? get_rankof : chameleon_getrankof_2d;
/* Matrix properties */ /* Matrix properties */
desc->dtyp = dtyp; desc->dtyp = dtyp;
...@@ -331,7 +334,7 @@ int chameleon_desc_init_internal( CHAM_desc_t *desc, const char *name, void *mat ...@@ -331,7 +334,7 @@ int chameleon_desc_init_internal( CHAM_desc_t *desc, const char *name, void *mat
desc->A12 = (size_t)( desc->llm%mb)*(size_t)(desc->lln - desc->lln%nb) + desc->A21; desc->A12 = (size_t)( desc->llm%mb)*(size_t)(desc->lln - desc->lln%nb) + desc->A21;
desc->A22 = (size_t)(desc->llm - desc->llm%mb)*(size_t)( desc->lln%nb) + desc->A12; desc->A22 = (size_t)(desc->llm - desc->llm%mb)*(size_t)( desc->lln%nb) + desc->A12;
chameleon_desc_init_tiles( desc ); chameleon_desc_init_tiles( desc, desc->get_rankof_init );
/* Create runtime specific structure like registering data */ /* Create runtime specific structure like registering data */
RUNTIME_desc_create( desc ); RUNTIME_desc_create( desc );
...@@ -790,7 +793,7 @@ CHAM_desc_t *CHAMELEON_Desc_Copy( const CHAM_desc_t *descin, void *mat ) ...@@ -790,7 +793,7 @@ CHAM_desc_t *CHAMELEON_Desc_Copy( const CHAM_desc_t *descin, void *mat )
CHAMELEON_Desc_Create_User( &descout, mat, CHAMELEON_Desc_Create_User( &descout, mat,
descin->dtyp, descin->mb, descin->nb, descin->bsiz, descin->dtyp, descin->mb, descin->nb, descin->bsiz,
descin->lm, descin->ln, descin->i, descin->j, descin->m, descin->n, descin->p, descin->q, descin->lm, descin->ln, descin->i, descin->j, descin->m, descin->n, descin->p, descin->q,
NULL, NULL, descin->get_rankof ); NULL, NULL, descin->get_rankof_init );
return descout; return descout;
...@@ -825,7 +828,7 @@ CHAM_desc_t *CHAMELEON_Desc_CopyOnZero( const CHAM_desc_t *descin, void *mat ) ...@@ -825,7 +828,7 @@ CHAM_desc_t *CHAMELEON_Desc_CopyOnZero( const CHAM_desc_t *descin, void *mat )
descin->lm, descin->ln, descin->i, descin->j, descin->m, descin->n, 1, 1, descin->lm, descin->ln, descin->i, descin->j, descin->m, descin->n, 1, 1,
...@@ -1003,6 +1006,7 @@ chameleon_desc_print( const CHAM_desc_t *desc, int shift ) ...@@ -1003,6 +1006,7 @@ chameleon_desc_print( const CHAM_desc_t *desc, int shift )
trank = desc->get_rankof( desc, m, n ); trank = desc->get_rankof( desc, m, n );
tile = desc->get_blktile( desc, m, n ); tile = desc->get_blktile( desc, m, n );
tiledesc = tile->mat; tiledesc = tile->mat;
assert( trank == tile->rank );
ptr = ( tile->format == CHAMELEON_TILE_DESC ) ? (intptr_t)(tiledesc->mat) : (intptr_t)(tile->mat); ptr = ( tile->format == CHAMELEON_TILE_DESC ) ? (intptr_t)(tiledesc->mat) : (intptr_t)(tile->mat);
...@@ -1139,7 +1143,7 @@ int CHAMELEON_Desc_Change_Distribution_Async( cham_uplo_t uplo, ...@@ -1139,7 +1143,7 @@ int CHAMELEON_Desc_Change_Distribution_Async( cham_uplo_t uplo,
/* Nothing to do if the new mapping is the same as the original one */ /* Nothing to do if the new mapping is the same as the original one */
if ( ( new_get_rankof == desc->get_rankof ) || if ( ( new_get_rankof == desc->get_rankof_init ) ||
( RUNTIME_comm_size( chamctxt ) == 1 ) ) ( RUNTIME_comm_size( chamctxt ) == 1 ) )
...@@ -1164,12 +1168,16 @@ int CHAMELEON_Desc_Change_Distribution_Async( cham_uplo_t uplo, ...@@ -1164,12 +1168,16 @@ int CHAMELEON_Desc_Change_Distribution_Async( cham_uplo_t uplo,
mmin = ( uplo == ChamLower ) ? chameleon_min( n, desc->mt ) : 0; mmin = ( uplo == ChamLower ) ? chameleon_min( n, desc->mt ) : 0;
mmax = ( uplo == ChamUpper ) ? chameleon_min( n+1, desc->mt ) : desc->mt; mmax = ( uplo == ChamUpper ) ? chameleon_min( n+1, desc->mt ) : desc->mt;
for ( m = mmin; m < mmax; m++ ) { for ( m = mmin; m < mmax; m++ ) {
CHAM_tile_t *tile = desc->get_blktile( desc, m, n );
int rank = new_get_rankof( desc, m, n );
RUNTIME_data_migrate( sequence, desc, m, n, new_get_rankof( desc, m, n ) ); RUNTIME_data_migrate( sequence, desc, m, n, new_get_rankof( desc, m, n ) );
tile->rank = rank;
/* Actually change data location in Chameleon */ /* Actually change data location in Chameleon */
desc->get_rankof = new_get_rankof; desc->get_rankof_init = new_get_rankof;
...@@ -51,6 +51,12 @@ inline static int chameleon_getblkldd_ccrb(const CHAM_desc_t *A, int m); ...@@ -51,6 +51,12 @@ inline static int chameleon_getblkldd_ccrb(const CHAM_desc_t *A, int m);
int chameleon_getrankof_2d(const CHAM_desc_t *desc, int m, int n); int chameleon_getrankof_2d(const CHAM_desc_t *desc, int m, int n);
int chameleon_getrankof_2d_diag(const CHAM_desc_t *desc, int m, int n); int chameleon_getrankof_2d_diag(const CHAM_desc_t *desc, int m, int n);
static inline int chameleon_getrankof_tile(const CHAM_desc_t *desc, int m, int n) {
assert( tile != NULL );
return tile->rank;
int chameleon_desc_init_internal( CHAM_desc_t *desc, const char *name, void *mat, int chameleon_desc_init_internal( CHAM_desc_t *desc, const char *name, void *mat,
cham_flttype_t dtyp, int mb, int nb, cham_flttype_t dtyp, int mb, int nb,
int lm, int ln, int m, int n, int p, int q, int lm, int ln, int m, int n, int p, int q,
...@@ -39,9 +39,9 @@ typedef struct chameleon_tile_s { ...@@ -39,9 +39,9 @@ typedef struct chameleon_tile_s {
char *name; char *name;
#endif #endif
int8_t format;
int m, n, ld;
void *mat; void *mat;
int rank, m, n, ld;
int8_t format;
} CHAM_tile_t; } CHAM_tile_t;
...@@ -80,6 +80,8 @@ struct chameleon_desc_s { ...@@ -80,6 +80,8 @@ struct chameleon_desc_s {
blkldd_fct_t get_blkldd; blkldd_fct_t get_blkldd;
// function to get chameleon tiles MPI rank // function to get chameleon tiles MPI rank
blkrankof_fct_t get_rankof; blkrankof_fct_t get_rankof;
blkrankof_fct_t get_rankof_init;
CHAM_tile_t *tiles; // pointer to the array of tiles descriptors CHAM_tile_t *tiles; // pointer to the array of tiles descriptors
void *mat; // pointer to the beginning of the matrix void *mat; // pointer to the beginning of the matrix
size_t A21; // pointer to the beginning of the matrix A21 size_t A21; // pointer to the beginning of the matrix A21
