Commit 29ed46b7 authored by PRUVOST Florent's avatar PRUVOST Florent Committed by Mathieu Faverge
Doc
    improve user's doc style
    add some explanation about the code structure in the main doxygen
    fix coverage in analysis sonarqube
    add a release job to automatize release publication
    change the cdash server to my.cdash.org which is more recent and reactive than cdash.inria.fr
    fix the version number, dates and authors in headers to prepare the release 0.9.2
parent 75528e23
...@@ -9,7 +9,7 @@ stages: ...@@ -9,7 +9,7 @@ stages:
before_script: before_script:
- git submodule update --init --recursive - git submodule update --init --recursive
- source .gitlab-ci-env.sh $SIMU - source .gitlab-ci-env.sh $SIMU
- mkdir -p build - mkdir -p build-$VERSION
.build_script_template: &build_script .build_script_template: &build_script
stage: build stage: build
...@@ -17,15 +17,15 @@ before_script: ...@@ -17,15 +17,15 @@ before_script:
script: script:
- echo BUILD_OPTIONS $BUILD_OPTIONS - echo BUILD_OPTIONS $BUILD_OPTIONS
- echo VERSION $VERSION - echo VERSION $VERSION
- (cd build && - (cd build-$VERSION &&
scan-build -plist --intercept-first --analyze-headers -o analyzer_reports scan-build -plist --intercept-first --exclude CMakeFiles --analyze-headers -o analyzer_reports
cmake -C ../cmake_modules/gitlab-ci-initial-cache.cmake .. $BUILD_OPTIONS && cmake -C ../cmake_modules/gitlab-ci-initial-cache.cmake .. $BUILD_OPTIONS &&
ctest --no-compress-output -V -j 5 ctest --no-compress-output -V -j 5
-D ExperimentalBuild -D ExperimentalBuild
-D ExperimentalSubmit -D ExperimentalSubmit
| tee ../chameleon_${VERSION}.log) | tee ../chameleon_${VERSION}.log)
make install | tee -a ../chameleon_${VERSION}.log && make install | tee -a ../chameleon_${VERSION}.log &&
rm install/ -r) rm install/ -r)
...@@ -35,39 +35,38 @@ before_script: ...@@ -35,39 +35,38 @@ before_script:
script: script:
- echo TESTS_RESTRICTION $TESTS_RESTRICTION - echo TESTS_RESTRICTION $TESTS_RESTRICTION
eval "ctest --no-compress-output -V eval "ctest --no-compress-output -V
$TESTS_RESTRICTION $TESTS_RESTRICTION
-D ExperimentalTest -D ExperimentalTest
-D ExperimentalCoverage -D ExperimentalCoverage
| tee -a ../chameleon_${VERSION}.log") | tee -a ../chameleon_${VERSION}.log")
- lcov --directory build --capture --output-file ./chameleon_${VERSION}.lcov - lcov --directory build-$VERSION --capture --output-file ./chameleon_${VERSION}.lcov
build_starpu: build_openmp:
<<: *build_script <<: *build_script
artifacts: artifacts:
name: build_starpu name: build_openmp
expire_in: 48 hours expire_in: 48 hours
paths: paths:
- build - build-$VERSION
- chameleon_starpu.log - chameleon_openmp.log
variables: variables:
BUILD_OPTIONS: "-DCHAMELEON_USE_CUDA=ON -DCHAMELEON_USE_MPI=ON" BUILD_OPTIONS: "-DCHAMELEON_SCHED=OPENMP"
VERSION: starpu VERSION: openmp
build_starpu_simgrid: build_parsec:
name: build_starpu_simgrid name: build_parsec
paths: paths:
- chameleon_starpu_simgrid.log - chameleon_parsec.log
SIMU: simu BUILD_OPTIONS: "-DCHAMELEON_SCHED=PARSEC"
BUILD_OPTIONS: "-DCHAMELEON_SIMULATION=ON -DCHAMELEON_USE_CUDA=ON -DCHAMELEON_USE_MPI=OFF" VERSION: parsec
VERSION: starpu_simgrid
build_quark: build_quark:
...@@ -75,109 +74,112 @@ build_quark: ...@@ -75,109 +74,112 @@ build_quark:
name: build_quark name: build_quark
paths: paths:
- chameleon_quark.log - chameleon_quark.log
BUILD_OPTIONS: "-DCHAMELEON_SCHED=QUARK" BUILD_OPTIONS: "-DCHAMELEON_SCHED=QUARK"
VERSION: quark VERSION: quark
build_parsec: build_starpu:
name: build_parsec name: build_starpu
paths: paths:
- chameleon_parsec.log - chameleon_starpu.log
BUILD_OPTIONS: "-DCHAMELEON_SCHED=PARSEC" BUILD_OPTIONS: "-DCHAMELEON_USE_CUDA=ON -DCHAMELEON_USE_MPI=ON"
VERSION: parsec VERSION: starpu
build_openmp: build_starpu_simgrid:
name: build_openmp name: build_starpu_simgrid
paths: paths:
- chameleon_openmp.log - chameleon_starpu_simgrid.log
BUILD_OPTIONS: "-DCHAMELEON_SCHED=OPENMP" SIMU: simu
VERSION: openmp BUILD_OPTIONS: "-DCHAMELEON_SIMULATION=ON -DCHAMELEON_USE_CUDA=ON -DCHAMELEON_USE_MPI=OFF"
test_starpu_branches: test_openmp_branches:
<<: *test_script <<: *test_script
TESTS_RESTRICTION: "-R \"test_shm_s|test_mpi_s|time_ooc_shm_s|time_ooc_mpi_s\"" TESTS_RESTRICTION: "-R \"test_shm_s|test_mpi_s\""
dependencies: dependencies:
- build_starpu - build_openmp
name: test_starpu name: test_openmp
paths: paths:
- chameleon_starpu.lcov - chameleon_openmp.lcov
only: only:
- branches - branches
except: except:
- master - master
- /^ci-.*$/
test_starpu_master: test_openmp_master:
TESTS_RESTRICTION: "-R \"_shm_|_mpi_\"" TESTS_RESTRICTION: "-R \"_shm_|_mpi_\""
paths: paths:
only: only:
- master@solverstack/chameleon - master@solverstack/chameleon
- /^ci-.*$/
test_starpu_simgrid_branches: test_parsec_branches:
SIMU: simu TESTS_RESTRICTION: "-R \"test_shm_s|test_mpi_s\""
TESTS_RESTRICTION: "-R simu" VERSION: parsec
- build_starpu_simgrid - build_parsec
name: test_starpu_simgrid name: test_parsec
paths: paths:
- chameleon_starpu_simgrid.lcov - chameleon_parsec.lcov
only: only:
except: except:
- master - master
- /^ci-.*$/
test_starpu_simgrid_master: test_parsec_master:
SIMU: simu TESTS_RESTRICTION: "-R \"_shm_|_mpi_\""
paths: paths:
only: only:
- /^ci-.*$/
test_quark_branches: test_quark_branches:
...@@ -190,13 +192,14 @@ test_quark_branches: ...@@ -190,13 +192,14 @@ test_quark_branches:
name: test_quark name: test_quark
paths: paths:
- chameleon_quark.lcov - chameleon_quark.lcov
only: only:
except: except:
- master - master
- /^ci-.*$/
test_quark_master: test_quark_master:
...@@ -209,83 +212,90 @@ test_quark_master: ...@@ -209,83 +212,90 @@ test_quark_master:
paths: paths:
only: only:
- /^ci-.*$/
test_parsec_branches: test_starpu_branches:
TESTS_RESTRICTION: "-R \"test_shm_s|test_mpi_s\"" TESTS_RESTRICTION: "-R \"test_shm_s|test_mpi_s|time_ooc_shm_s|time_ooc_mpi_s\""
- build_parsec - build_starpu
name: test_parsec name: test_starpu
