Commit 05b67413 authored by PRUVOST Florent's avatar PRUVOST Florent
use spack from the /home/pruvost of gitlab-runner user, to avoid possible locks
parent a5e7e69e
...@@ -17,7 +17,7 @@ starpu-simgrid: ...@@ -17,7 +17,7 @@ starpu-simgrid:
- git submodule update - git submodule update
- mkdir build - mkdir build
- cd build - cd build
- . /home/ci/spack/share/spack/setup-env.sh - . $HOME/spack/share/spack/setup-env.sh
- spack load hwloc && spack load fxt && spack load simgrid && spack load starpu - spack load hwloc && spack load fxt && spack load simgrid && spack load starpu
- cmake .. -DCHAMELEON_SIMULATION=ON -DCHAMELEON_USE_CUDA=ON -DCHAMELEON_USE_MAGMA=OFF -DCHAMELEON_USE_MPI=OFF - cmake .. -DCHAMELEON_SIMULATION=ON -DCHAMELEON_USE_CUDA=ON -DCHAMELEON_USE_MAGMA=OFF -DCHAMELEON_USE_MPI=OFF
- make -j2 - make -j2
