Commit 043add66 authored by PRUVOST Florent's avatar PRUVOST Florent
change name MAGMAMORSE and cousins to CHAMELEON
parent 06075674
This diff is collapsed.
......@@ -39,21 +39,21 @@ if(NOT BUILDNAME)
endif(CMAKE_BUILD_TYPE)
# Specific options of Magma-Morse
if(MAGMAMORSE_SCHED_QUARK)
if(CHAMELEON_SCHED_QUARK)
set(BUILDNAME "${BUILDNAME}-Quark")
endif(MAGMAMORSE_SCHED_QUARK)
endif(CHAMELEON_SCHED_QUARK)
if(MAGMAMORSE_SCHED_STARPU)
if(CHAMELEON_SCHED_STARPU)
set(BUILDNAME "${BUILDNAME}-StarPU")
endif(MAGMAMORSE_SCHED_STARPU)
endif(CHAMELEON_SCHED_STARPU)
if(MAGMAMORSE_USE_MPI)
if(CHAMELEON_USE_MPI)
set(BUILDNAME "${BUILDNAME}-mpi")
endif(MAGMAMORSE_USE_MPI)
endif(CHAMELEON_USE_MPI)
if(MAGMAMORSE_USE_CUDA)
if(CHAMELEON_USE_CUDA)
set(BUILDNAME "${BUILDNAME}-cuda")
endif(MAGMAMORSE_USE_CUDA)
endif(CHAMELEON_USE_CUDA)
endif()
Some instructions about MagmaMorse usage
Some instructions about CHAMELEON usage
Compilation of MagmaMorse libraries and executables are done with CMake
Compilation of CHAMELEON libraries and executables are done with CMake
(http://www.cmake.org/). This version has been tested with CMake 2.8.8.
Usage: three steps are required to compile and install MagmaMorse
Usage: three steps are required to compile and install CHAMELEON
1) configure :
> cmake path/to/magmamorse -DOPTION1= -DOPTION2= ...
> cmake path/to/chameleon -DOPTION1= -DOPTION2= ...
see the "Options" section to get list of options
see the "Dependencies detection" for details about libraries detection
......@@ -19,11 +19,11 @@ do not hesitate to use -j[ncores] option to speedup the compilation
3) install (optional) :
> make install
do not forget to specify the install directory with -DCMAKE_INSTALL_PREFIX at configure
example : cmake /home/toto/magmamorse -DCMAKE_INSTALL_PREFIX=/home/toto/install
example : cmake /home/toto/chameleon -DCMAKE_INSTALL_PREFIX=/home/toto/install
* List of libraries MagmaMorse depends on *
* List of libraries CHAMELEON depends on *
threads : pthread
......@@ -84,17 +84,17 @@ by specifying them directly at cmake configure. Different cases :
You can optionally activate some options at cmake configure (like CUDA, MPI, ...)
invoking cmake path/to/your/CMakeLists.txt -DOPTION1= -DOPTION2= ...
example: cmake /home/toto/magmamorse/ -DCMAKE_BUILD_TYPE=Debug \
example: cmake /home/toto/chameleon/ -DCMAKE_BUILD_TYPE=Debug \
-DCMAKE_INSTALL_PREFIX=/home/toto/install/ \
-DMAGMAMORSE_USE_CUDA=ON \
-DMAGMAMORSE_USE_MAGMA=ON \
-DMAGMAMORSE_USE_MPI=ON \
-DCHAMELEON_USE_CUDA=ON \
-DCHAMELEON_USE_MAGMA=ON \
-DCHAMELEON_USE_MPI=ON \
-DBLA_VENDOR=Intel10_64lp \
-DSTARPU_DIR=/home/toto/install/starpu-1.1/build/include/starpu/1.1/ \
-DMAGMAMORSE_USE_FXT=ON
-DCHAMELEON_USE_FXT=ON
You can get the full list of options with -L[A][H] options of cmake command
example: cmake -LH /home/toto/magmamorse/
example: cmake -LH /home/toto/chameleon/
You can also set the options thanks to ccmake interface
......@@ -118,20 +118,20 @@ STARPU_LIBDIR=...
# same idea can be used for some packages, replace STARPU by one of these:
BLAS - CBLAS - FXT - HWLOC - LAPACK - LAPACKE - MAGMA - QUARK - TMG
MagmaMorse specific:
CHAMELEON specific:
MAGMAMORSE_USE_MPI=ON|OFF (default OFF)
MAGMAMORSE_USE_CUDA=ON|OFF (default OFF)
MAGMAMORSE_USE_MAGMA=ON|OFF (default OFF)
MAGMAMORSE_USE_FXT=ON|OFF (default OFF)
MAGMAMORSE_SCHED_STARPU=ON|OFF (default ON)
MAGMAMORSE_SCHED_QUARK=ON|OFF (default OFF)
MAGMAMORSE_SIMULATION=ON|OFF (default OFF)
CHAMELEON_USE_MPI=ON|OFF (default OFF)
CHAMELEON_USE_CUDA=ON|OFF (default OFF)
CHAMELEON_USE_MAGMA=ON|OFF (default OFF)
CHAMELEON_USE_FXT=ON|OFF (default OFF)
CHAMELEON_SCHED_STARPU=ON|OFF (default ON)
CHAMELEON_SCHED_QUARK=ON|OFF (default OFF)
CHAMELEON_SIMULATION=ON|OFF (default OFF)
Libraries detected with an official cmake module (see module files in CMAKE_ROOT/Modules/):
CUDA - MPI - Threads
Libraries detected with our cmake modules (see module files in cmake_modules/morse/find/ directory of MagmaMorse sources):
Libraries detected with our cmake modules (see module files in cmake_modules/morse/find/ directory of CHAMELEON sources):
BLAS - CBLAS - FXT - HWLOC - LAPACK - LAPACKE - MAGMA - QUARK - STARPU - TMG
......@@ -146,8 +146,8 @@ By doing so, traces are generated after each execution of a program which uses
StarPU in the directory pointed by the STARPU_FXT_PREFIX environment variable.
example: export STARPU_FXT_PREFIX=/home/toto/fxt_files/
When executing a ./timing/... MagmaMorse program, if it has been enabled
(StarPU compiled with FxT and -DMAGMAMORSE_USE_FXT=ON), you can give the option --trace
When executing a ./timing/... CHAMELEON program, if it has been enabled
(StarPU compiled with FxT and -DCHAMELEON_USE_FXT=ON), you can give the option --trace
to tell the program to generate trace log files.
Finally, to generate the trace file which can be opened with Vite program
......@@ -164,10 +164,10 @@ The trace file will be named paje.trace (use -o option to specify an output name
* Use simulation mode with StarPU-SimGrid *
Simulation mode can be activated by setting the cmake option MAGMAMORSE_SIMULATION to ON.
Simulation mode can be activated by setting the cmake option CHAMELEON_SIMULATION to ON.
This mode allows you to simulate execution of algorithms with StarPU compiled with SimGrid (http://simgrid.gforge.inria.fr/).
To do so, we provide some perfmodels in the simucore/perfmodels/ directory of MagmaMorse sources.
To use these perfmodels, please set your STARPU_HOME environment variable to path/to/your/magmamorse_sources/simucore/perfmodels.
To do so, we provide some perfmodels in the simucore/perfmodels/ directory of CHAMELEON sources.
To use these perfmodels, please set your STARPU_HOME environment variable to path/to/your/chameleon_sources/simucore/perfmodels.
Finally, you need to set your STARPU_HOSTNAME environment variable to the name of the machine to simulate.
For example: STARPU_HOSTNAME=mirage.
Note that only POTRF kernels with block sizes of 320 or 960 (simple and double precision) on mirage machine are available for now.
......@@ -36,43 +36,43 @@ MACRO(GENERATE_PKGCONFIG_FILE _file)
# The link flags specific to this package and any required libraries
# that don't support PkgConfig
set(MAGMAMORSE_PKGCONFIG_LIBS "")
set(CHAMELEON_PKGCONFIG_LIBS "")
# The link flags for private libraries required by this package but not
# exposed to applications
set(MAGMAMORSE_PKGCONFIG_LIBS_PRIVATE "")
set(CHAMELEON_PKGCONFIG_LIBS_PRIVATE "")
# A list of packages required by this package
set(MAGMAMORSE_PKGCONFIG_REQUIRED "")
set(CHAMELEON_PKGCONFIG_REQUIRED "")
# A list of private packages required by this package but not exposed to
# applications
set(MAGMAMORSE_PKGCONFIG_REQUIRED_PRIVATE "")
set(CHAMELEON_PKGCONFIG_REQUIRED_PRIVATE "")
list(APPEND MAGMAMORSE_PKGCONFIG_LIBS -lmagmamorse)
list(APPEND MAGMAMORSE_PKGCONFIG_LIBS -lmagmamorse_starpu)
if ( MAGMAMORSE_USE_MPI )
list(APPEND MAGMAMORSE_PKGCONFIG_REQUIRED
starpumpi-${MAGMAMORSE_STARPU_VERSION})
list(APPEND CHAMELEON_PKGCONFIG_LIBS -lchameleon)
list(APPEND CHAMELEON_PKGCONFIG_LIBS -lchameleon_starpu)
if ( CHAMELEON_USE_MPI )
list(APPEND CHAMELEON_PKGCONFIG_REQUIRED
starpumpi-${CHAMELEON_STARPU_VERSION})
else()
starpu-${MAGMAMORSE_STARPU_VERSION})
starpu-${CHAMELEON_STARPU_VERSION})
endif()
elseif(MAGMAMORSE_SCHED_QUARK)
list(APPEND MAGMAMORSE_PKGCONFIG_LIBS -lmagmamorse_quark)
list(APPEND MAGMAMORSE_PKGCONFIG_LIBS -lquark)
elseif(CHAMELEON_SCHED_QUARK)
list(APPEND CHAMELEON_PKGCONFIG_LIBS -lchameleon_quark)
list(APPEND CHAMELEON_PKGCONFIG_LIBS -lquark)
endif()
if(NOT MAGMAMORSE_SIMULATION)
if(NOT CHAMELEON_SIMULATION)
list(APPEND MAGMAMORSE_PKGCONFIG_LIBS ${CUDA_LIBRARIES})
list(APPEND CHAMELEON_PKGCONFIG_LIBS ${CUDA_LIBRARIES})
endif()
if(MAGMAMORSE_USE_MAGMA)
list(APPEND MAGMAMORSE_PKGCONFIG_REQUIRED magma)
if(CHAMELEON_USE_MAGMA)
list(APPEND CHAMELEON_PKGCONFIG_REQUIRED magma)
endif()
-lcoreblas
${LAPACKE_LIBRARIES}
${CBLAS_LIBRARIES}
......@@ -81,45 +81,45 @@ MACRO(GENERATE_PKGCONFIG_FILE _file)
${EXTRA_LIBRARIES}
list(APPEND MAGMAMORSE_PKGCONFIG_REQUIRED hwloc)
list(APPEND CHAMELEON_PKGCONFIG_REQUIRED hwloc)
else(NOT MAGMAMORSE_SIMULATION)
else(NOT CHAMELEON_SIMULATION)
-lcoreblas
-lsimulapacke
-lsimucblas
${EXTRA_LIBRARIES}
endif(NOT MAGMAMORSE_SIMULATION)
endif(NOT CHAMELEON_SIMULATION)
list(REMOVE_DUPLICATES MAGMAMORSE_PKGCONFIG_LIBS)
list(REMOVE_DUPLICATES MAGMAMORSE_PKGCONFIG_LIBS_PRIVATE)
list(REMOVE_DUPLICATES MAGMAMORSE_PKGCONFIG_REQUIRED)
list(REMOVE_DUPLICATES MAGMAMORSE_PKGCONFIG_REQUIRED_PRIVATE)
list(REMOVE_DUPLICATES CHAMELEON_PKGCONFIG_LIBS)
list(REMOVE_DUPLICATES CHAMELEON_PKGCONFIG_LIBS_PRIVATE)
list(REMOVE_DUPLICATES CHAMELEON_PKGCONFIG_REQUIRED)
list(REMOVE_DUPLICATES CHAMELEON_PKGCONFIG_REQUIRED_PRIVATE)
# Define required package
set(MAGMAMORSE_PKGCONFIG_LIBS_CPY "${MAGMAMORSE_PKGCONFIG_LIBS}")
foreach(_dep ${MAGMAMORSE_PKGCONFIG_LIBS_CPY})
set(CHAMELEON_PKGCONFIG_LIBS_CPY "${CHAMELEON_PKGCONFIG_LIBS}")
foreach(_dep ${CHAMELEON_PKGCONFIG_LIBS_CPY})
get_filename_component(dep_we ${_dep} NAME)
STRING(REPLACE "lib" "-l" dep_we "${dep_we}")
STRING(REPLACE ".so" "" dep_we "${dep_we}")
STRING(REPLACE ".a" "" dep_we "${dep_we}")
STRING(REPLACE ".dylib" "" dep_we "${dep_we}")
STRING(REPLACE ".dll" "" dep_we "${dep_we}")
list(APPEND MAGMAMORSE_PKGCONFIG_LIBS ${dep_we})
list(APPEND CHAMELEON_PKGCONFIG_LIBS ${dep_we})
endforeach()
STRING(REPLACE ";" " " MAGMAMORSE_PKGCONFIG_LIBS "${MAGMAMORSE_PKGCONFIG_LIBS}")
STRING(REPLACE ";" " " MAGMAMORSE_PKGCONFIG_LIBS_PRIVATE "${MAGMAMORSE_PKGCONFIG_LIBS_PRIVATE}")
STRING(REPLACE ";" " " MAGMAMORSE_PKGCONFIG_REQUIRED "${MAGMAMORSE_PKGCONFIG_REQUIRED}")
STRING(REPLACE ";" " " MAGMAMORSE_PKGCONFIG_REQUIRED_PRIVATE "${MAGMAMORSE_PKGCONFIG_REQUIRED_PRIVATE}")
STRING(REPLACE ";" " " CHAMELEON_PKGCONFIG_LIBS "${CHAMELEON_PKGCONFIG_LIBS}")
STRING(REPLACE ";" " " CHAMELEON_PKGCONFIG_LIBS_PRIVATE "${CHAMELEON_PKGCONFIG_LIBS_PRIVATE}")
STRING(REPLACE ";" " " CHAMELEON_PKGCONFIG_REQUIRED "${CHAMELEON_PKGCONFIG_REQUIRED}")
STRING(REPLACE ";" " " CHAMELEON_PKGCONFIG_REQUIRED_PRIVATE "${CHAMELEON_PKGCONFIG_REQUIRED_PRIVATE}")
# Create .pc file
......@@ -23,7 +23,7 @@
# @date 10-11-2014
message("\nConfiguration of package `magmamorse':")
message("\nConfiguration of package `chameleon':")
message(" BUILDNAME ...........: ${BUILDNAME}")
message(" SITE ................: ${SITE}")
message(" ")
......@@ -37,7 +37,7 @@ if(CMAKE_Fortran_COMPILER)
message(" Compiler: Fortran ...: ${CMAKE_Fortran_COMPILER} (${CMAKE_Fortran_COMPILER_ID})")
message(" version .....: ${COMPILER_Fortran_VERSION}")
endif()
message(" Compiler: MPI .......: ${MPI_C_COMPILER}")
message(" compiler flags ......: ${MPI_C_COMPILE_FLAGS}")
endif()
......@@ -50,28 +50,28 @@ message(" CXXFlags ............: ${CMAKE_CXX_FLAGS}")
message(" LDFlags .............: ${CMAKE_C_LINK_FLAGS}")
message(" ")
message(" Implementation paradigm")
message(" CUDA ................: ${MAGMAMORSE_USE_CUDA}")
message(" MPI .................: ${MAGMAMORSE_USE_MPI}")
message(" CUDA ................: ${CHAMELEON_USE_CUDA}")
message(" MPI .................: ${CHAMELEON_USE_MPI}")
message(" ")
message(" Runtime specific")
message(" QUARK ...............: ${MAGMAMORSE_SCHED_QUARK}")
message(" StarPU ..............: ${MAGMAMORSE_SCHED_STARPU}")
message(" FxT .................: ${MAGMAMORSE_USE_FXT}")
message(" QUARK ...............: ${CHAMELEON_SCHED_QUARK}")
message(" StarPU ..............: ${CHAMELEON_SCHED_STARPU}")
message(" FxT .................: ${CHAMELEON_USE_FXT}")
message(" ")
message(" Kernels specific")
message(" BLAS ................: ${BLA_VENDOR}")
message(" MAGMA ...............: ${MAGMAMORSE_USE_MAGMA}")
message(" MAGMA ...............: ${CHAMELEON_USE_MAGMA}")
message(" ")
message(" Simulation mode .....: ${MAGMAMORSE_SIMULATION}")
message(" Simulation mode .....: ${CHAMELEON_SIMULATION}")
message(" ")
message(" Binaries to build")
message(" documentation ........: ${MAGMAMORSE_ENABLE_DOCS}")
message(" example ..............: ${MAGMAMORSE_ENABLE_EXAMPLE}")
message(" testing ..............: ${MAGMAMORSE_ENABLE_TESTING}")
message(" timing ...............: ${MAGMAMORSE_ENABLE_TIMING}")
message(" documentation ........: ${CHAMELEON_ENABLE_DOCS}")
message(" example ..............: ${CHAMELEON_ENABLE_EXAMPLE}")
message(" testing ..............: ${CHAMELEON_ENABLE_TESTING}")
message(" timing ...............: ${CHAMELEON_ENABLE_TIMING}")
message(" ")
message(" Magmamorse dependencies :")
foreach (_dep ${MAGMAMORSE_DEP})
message(" CHAMELEON dependencies :")
foreach (_dep ${CHAMELEON_DEP})
message(" ${_dep}")
endforeach ()
message(" ")
......@@ -47,7 +47,7 @@
# License text for the above reference.)
# Some macros to print status when search for headers and libs
# PrintFindStatus.cmake is in cmake_modules/morse/find directory of magmamorse
# PrintFindStatus.cmake is in cmake_modules/morse/find directory of chameleon
include(PrintFindStatus)
option(BLAS_VERBOSE "Print some additional information during BLAS
libraries detection" OFF)
......@@ -32,7 +32,7 @@
# add a cache variable to let the user specify the BLAS vendor
......@@ -41,7 +41,7 @@
# CBLAS depends on BLAS
......@@ -33,7 +33,7 @@
# Optionally use pkg-config to detect include/library dirs (if pkg-config is available)
......@@ -44,7 +44,7 @@
option(LAPACK_VERBOSE "Print some additional information during LAPACK
# LAPACKE depends on LAPACK
......@@ -34,7 +34,7 @@
# LAPACKEXT depends on BLASEXT
# MAGMA may depend on CUDA
......@@ -35,7 +35,7 @@
# Looking for include
# PARMETIS depends on MPI
# PTSCOTCH may depend on MPI and Threads
# QUARK may depend on HWLOC
# SCOTCH may depend on Threads
# used to test a TMG function after
......@@ -436,7 +436,7 @@ subs = {
('strsm', 'dtrsm', 'ctrsm', 'ztrsm' ),
('strsv', 'dtrsv', 'ctrsv', 'ztrsv' ),
# ADD FOR NEW VERSION OF MAGMA_MORSE
# ADD FOR NEW VERSION OF CHAMELEON
('sgeadd', 'dgeadd', 'cgeadd', 'zgeadd' ),
('shbcpy', 'dhbcpy', 'chbcpy', 'zhbcpy' ),
('ssyrbt', 'dsyrbt', 'cherbt', 'zherbt' ),
......@@ -29,7 +29,7 @@
# Define the list of sources
set(MAGMAMORSE_CONTROL
set(CHAMELEON_CONTROL
../control/async.c
../control/auxiliary.c
../control/context.c
......@@ -42,13 +42,13 @@ set(MAGMAMORSE_CONTROL
# ../control/morsewinthread.c
foreach(_prec ${MAGMAMORSE_PRECISION})
foreach(_prec ${CHAMELEON_PRECISION})
set_source_files_properties(../control/tile.c PROPERTIES COMPILE_FLAGS "-DPRECISION_${_prec}")
endforeach()
# Generate the morse sources for all possible precisions
set(MAGMAMORSE_SRCS_GENERATED "")
set(CHAMELEON_SRCS_GENERATED "")
set(ZSRC
# BLAS 3
......@@ -197,8 +197,8 @@ set(ZSRC
ztile.c
precisions_rules_py(MAGMAMORSE_SRCS_GENERATED "${ZSRC}"
PRECISIONS "${MAGMAMORSE_PRECISION}")
precisions_rules_py(CHAMELEON_SRCS_GENERATED "${ZSRC}"
PRECISIONS "${CHAMELEON_PRECISION}")
set(CONTROL_SRCS_GENERATED "")
set(ZSRC
......@@ -207,51 +207,51 @@ set(ZSRC
precisions_rules_py(CONTROL_SRCS_GENERATED "${ZSRC}"
TARGETDIR "control" )
set(MAGMAMORSE_SRCS
${MAGMAMORSE_CONTROL}
${MAGMAMORSE_SRCS_GENERATED}
set(CHAMELEON_SRCS
${CHAMELEON_CONTROL}
${CHAMELEON_SRCS_GENERATED}
${CONTROL_SRCS_GENERATED}
# Generate the morse fortran sources for all possible precisions
if(HAVE_ISO_C_BINDING)
set(MAGMAMORSE_SRCS_F_GENERATED "")
set(CHAMELEON_SRCS_F_GENERATED "")
set(ZSRCF
../control/morse_zcf90.F90
../control/morse_zf90.F90
../control/morse_zf90_wrappers.F90
precisions_rules_py(MAGMAMORSE_SRCS_F_GENERATED "${ZSRCF}"
precisions_rules_py(CHAMELEON_SRCS_F_GENERATED "${ZSRCF}"
set(MAGMAMORSE_SRCSF
set(CHAMELEON_SRCSF
../control/morse_f90.f90
${MAGMAMORSE_SRCS_F_GENERATED}
${CHAMELEON_SRCS_F_GENERATED}
endif(HAVE_ISO_C_BINDING)
# Compile step
add_library(magmamorse ${MAGMAMORSE_SRCS} ${MAGMAMORSE_SRCSF})
add_library(chameleon ${CHAMELEON_SRCS} ${CHAMELEON_SRCSF})
add_dependencies(magmamorse
magmamorse_include
add_dependencies(chameleon
chameleon_include
coreblas_include
control_include
runtime_starpu_include
set_property(TARGET magmamorse PROPERTY LINKER_LANGUAGE Fortran)
set_property(TARGET magmamorse PROPERTY Fortran_MODULE_DIRECTORY "${CMAKE_BINARY_DIR}/include")
set_property(TARGET chameleon PROPERTY LINKER_LANGUAGE Fortran)
set_property(TARGET chameleon PROPERTY Fortran_MODULE_DIRECTORY "${CMAKE_BINARY_DIR}/include")
# installation
install(TARGETS magmamorse
install(TARGETS chameleon
DESTINATION lib)
#define A(m,n) A, m, n
#define T(m,n) T, m, n
#if defined(MAGMAMORSE_USE_MAGMA)
#if defined(CHAMELEON_USE_MAGMA)
#define DIAG(k) DIAG, k, 0
#else
#define DIAG(k) A, k, k
......@@ -76,7 +76,7 @@ void morse_pzgelqf(MORSE_desc_t *A, MORSE_desc_t *T,
ws_worker = A->nb * (ib+1);
/* Allocation of temporary (scratch) working space */
