Commits (27)
This diff is collapsed.
...@@ -34,19 +34,19 @@ ...@@ -34,19 +34,19 @@
if (MORSE_ENABLE_WARNING) if (MORSE_ENABLE_WARNING)
if(CMAKE_C_COMPILER_ID MATCHES GNU) if(CMAKE_C_COMPILER_ID MATCHES GNU)
set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -Wall") set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -Wall -fdiagnostics-show-option")
elseif(CMAKE_C_COMPILER_ID MATCHES Intel) elseif(CMAKE_C_COMPILER_ID MATCHES Intel)
set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -w3 -diag-disable:remark") set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -w3 -diag-disable:remark")
endif() endif()
if(CMAKE_CXX_COMPILER_ID MATCHES GNU) if(CMAKE_CXX_COMPILER_ID MATCHES GNU)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Wall") set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Wall -fdiagnostics-show-option")
elseif(CMAKE_CXX_COMPILER_ID MATCHES Intel) elseif(CMAKE_CXX_COMPILER_ID MATCHES Intel)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -w3 -diag-disable:remark") set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -w3 -diag-disable:remark")
endif() endif()
if(CMAKE_Fortran_COMPILER_ID MATCHES GNU) if(CMAKE_Fortran_COMPILER_ID MATCHES GNU)
set(CMAKE_Fortran_FLAGS "${CMAKE_Fortran_FLAGS} -Wall") set(CMAKE_Fortran_FLAGS "${CMAKE_Fortran_FLAGS} -Wall -fdiagnostics-show-option")
elseif(CMAKE_Fortran_COMPILER_ID MATCHES Intel) elseif(CMAKE_Fortran_COMPILER_ID MATCHES Intel)
set(CMAKE_Fortran_FLAGS "${CMAKE_Fortran_FLAGS} -warn all -diag-disable:remark") set(CMAKE_Fortran_FLAGS "${CMAKE_Fortran_FLAGS} -warn all -diag-disable:remark")
endif() endif()
...@@ -56,21 +56,21 @@ endif(MORSE_ENABLE_WARNING) ...@@ -56,21 +56,21 @@ endif(MORSE_ENABLE_WARNING)
if (MORSE_ENABLE_COVERAGE) if (MORSE_ENABLE_COVERAGE)
set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} --coverage") set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -fPIC -fno-inline --coverage")
else() else()
message(FATAL_ERROR "Code coverage is only available with the GNU C (gcc)" message(FATAL_ERROR "Code coverage is only available with the GNU C (gcc)"
"\n compiler, please turn MORSE_ENABLE_COVERAGE OFF\n.") "\n compiler, please turn MORSE_ENABLE_COVERAGE OFF\n.")
endif() endif()
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} --coverage") set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -fPIC -fno-inline --coverage")
else() else()
message(FATAL_ERROR "Code coverage is only available with the GNU CXX" message(FATAL_ERROR "Code coverage is only available with the GNU CXX"
"\n (g++) compiler, please turn MORSE_ENABLE_COVERAGE OFF\n.") "\n (g++) compiler, please turn MORSE_ENABLE_COVERAGE OFF\n.")
endif() endif()
set(CMAKE_Fortran_FLAGS "${CMAKE_Fortran_FLAGS} --coverage") set(CMAKE_Fortran_FLAGS "${CMAKE_Fortran_FLAGS} -fPIC -fno-inline --coverage")
else() else()
message(FATAL_ERROR "Code coverage is only available with the GNU" message(FATAL_ERROR "Code coverage is only available with the GNU"
"\n Fortran (gfortran) compiler, please turn MORSE_ENABLE_COVERAGE" "\n Fortran (gfortran) compiler, please turn MORSE_ENABLE_COVERAGE"
...@@ -3,7 +3,7 @@ ...@@ -3,7 +3,7 @@
# @copyright (c) 2009-2014 The University of Tennessee and The University # @copyright (c) 2009-2014 The University of Tennessee and The University
# of Tennessee Research Foundation. # of Tennessee Research Foundation.
# All rights reserved. # All rights reserved.
# @copyright (c) 2012-2014 Inria. All rights reserved. # @copyright (c) 2012-2018 Inria. All rights reserved.
# @copyright (c) 2012-2014 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved. # @copyright (c) 2012-2014 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
...@@ -18,7 +18,7 @@ ...@@ -18,7 +18,7 @@
# Univ. of California Berkeley, # Univ. of California Berkeley,
# Univ. of Colorado Denver. # Univ. of Colorado Denver.
# @version 0.9.0 # @version 1.0.0
# @author Cedric Castagnede # @author Cedric Castagnede
# @author Emmanuel Agullo # @author Emmanuel Agullo
# @author Mathieu Faverge # @author Mathieu Faverge
...@@ -28,51 +28,51 @@ ...@@ -28,51 +28,51 @@
# Set some colors # Set some colors
#if(NOT WIN32) if(NOT WIN32)
# string(ASCII 27 Esc) string(ASCII 27 Esc)
# set(ColourReset "${Esc}[m") set(ColourReset "${Esc}[m")
# set(ColourBold "${Esc}[1m") set(ColourBold "${Esc}[1m")
# set(Red "${Esc}[31m") set(Red "${Esc}[31m")
# set(Green "${Esc}[32m") set(Green "${Esc}[32m")
# set(Yellow "${Esc}[33m") set(Yellow "${Esc}[33m")
# set(Blue "${Esc}[34m") set(Blue "${Esc}[34m")
# set(Magenta "${Esc}[35m") set(Magenta "${Esc}[35m")
# set(Cyan "${Esc}[36m") set(Cyan "${Esc}[36m")
# set(White "${Esc}[37m") set(White "${Esc}[37m")
# set(BoldRed "${Esc}[1;31m") set(BoldRed "${Esc}[1;31m")
# set(BoldGreen "${Esc}[1;32m") set(BoldGreen "${Esc}[1;32m")
# set(BoldYellow "${Esc}[1;33m") set(BoldYellow "${Esc}[1;33m")
# set(BoldBlue "${Esc}[1;34m") set(BoldBlue "${Esc}[1;34m")
# set(BoldMagenta "${Esc}[1;35m") set(BoldMagenta "${Esc}[1;35m")
# set(BoldCyan "${Esc}[1;36m") set(BoldCyan "${Esc}[1;36m")
# set(BoldWhite "${Esc}[1;37m") set(BoldWhite "${Esc}[1;37m")
#endif()
# Colorize cmake messages during configure # Colorize cmake messages during configure
function(message) function(message)
list(GET ARGV 0 MessageType) list(GET ARGV 0 MessageType)
if(MessageType STREQUAL FATAL_ERROR OR MessageType STREQUAL SEND_ERROR) if(MessageType STREQUAL FATAL_ERROR OR MessageType STREQUAL SEND_ERROR)
list(REMOVE_AT ARGV 0) list(REMOVE_AT ARGV 0)
string (REPLACE ";" " " ARGV_STR "${ARGV}") string (REPLACE ";" " " ARGV_STR "${ARGV}")
_message(${MessageType} "${BoldRed}${ARGV_STR}${ColourReset}") _message(${MessageType} "${BoldRed}${ARGV_STR}${ColourReset}")
elseif(MessageType STREQUAL WARNING) elseif(MessageType STREQUAL WARNING)
_message(${MessageType} "${BoldYellow}${ARGV_STR}${ColourReset}") _message(${MessageType} "${BoldYellow}${ARGV_STR}${ColourReset}")
elseif(MessageType STREQUAL AUTHOR_WARNING) elseif(MessageType STREQUAL AUTHOR_WARNING)
_message(${MessageType} "${BoldCyan}${ARGV_STR}${ColourReset}") _message(${MessageType} "${BoldCyan}${ARGV_STR}${ColourReset}")
elseif(MessageType STREQUAL STATUS) elseif(MessageType STREQUAL STATUS)
_message(${MessageType} "${Green}${ARGV_STR}${ColourReset}") _message(${MessageType} "${Green}${ARGV_STR}${ColourReset}")
else() else()
string (REPLACE "${Esc}[1 " "${Esc}[1;" ARGV_STR "${ARGV_STR}") string (REPLACE "${Esc}[1 " "${Esc}[1;" ARGV_STR "${ARGV_STR}")
_message("${ARGV_STR}") _message("${ARGV_STR}")
endif() endif()
endfunction() endfunction()
endif()
## @end file ColorizeMessage.cmake ## @end file ColorizeMessage.cmake
# @copyright (c) 2012-2016 Inria. All rights reserved. # @copyright (c) 2012-2018 Inria. All rights reserved.
...@@ -27,11 +27,25 @@ ...@@ -27,11 +27,25 @@
# Global Morse options
option(MORSE_ENABLE_WARNING "Enable warning messages" OFF)
option(MORSE_ENABLE_COVERAGE "Enable flags for coverage test" OFF)
option(MORSE_ENABLE_COLOR_MESSAGE "Enable colors in messages" OFF)
#option(MORSE_VERBOSE_FIND_PACKAGE "Add additional messages concerning packages not found" OFF)
#message(STATUS "MORSE_VERBOSE_FIND_PACKAGE is set to OFF, turn it ON to get"
# " information about packages not found")
# This include is required to check symbols of libs in the main CMakeLists.txt # This include is required to check symbols of libs in the main CMakeLists.txt
include(CheckFunctionExists) include(CheckFunctionExists)
# To colorize messages # This include is required to check defines in headers
#include(ColorizeMessage) include(CheckIncludeFiles)
if (MORSE_ENABLE_COLOR_MESSAGE)
# colorize messages
endif()
# To find headers and libs # To find headers and libs
include(FindHeadersAndLibs) include(FindHeadersAndLibs)
...@@ -49,12 +63,6 @@ include(Ressources) ...@@ -49,12 +63,6 @@ include(Ressources)
# Add the path where we handle our FindFOO.cmake to seek for liraries # Add the path where we handle our FindFOO.cmake to seek for liraries
list(APPEND CMAKE_MODULE_PATH ${MORSE_CMAKE_MODULE_PATH}/find) list(APPEND CMAKE_MODULE_PATH ${MORSE_CMAKE_MODULE_PATH}/find)
## @end file MorseInit.cmake ## @end file MorseInit.cmake
...@@ -3,8 +3,7 @@ ...@@ -3,8 +3,7 @@
# @copyright (c) 2012-2014 Inria. All rights reserved. # @copyright (c) 2012-2016 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria, Univ. Bordeaux. All rights reserved.
...@@ -158,6 +157,10 @@ endif() ...@@ -158,6 +157,10 @@ endif()
# the target receives a -DPRECISION_p in its cflags. # the target receives a -DPRECISION_p in its cflags.
include(ParseArguments) include(ParseArguments)
# Add a hint to help Cmake to find the correct python version:
# (see https://cmake.org/cmake/help/v3.0/module/FindPythonInterp.html)
set(Python_ADDITIONAL_VERSIONS 2)
find_package(PythonInterp REQUIRED) find_package(PythonInterp REQUIRED)
MACRO(precisions_rules_py) MACRO(precisions_rules_py)
...@@ -237,10 +240,9 @@ MACRO(precisions_rules_py) ...@@ -237,10 +240,9 @@ MACRO(precisions_rules_py)
COMMAND ${CMAKE_COMMAND} -E remove -f ${_dependency_OUTPUT} && ${pythoncmd} && chmod a-w ${_dependency_OUTPUT} COMMAND ${CMAKE_COMMAND} -E remove -f ${_dependency_OUTPUT} && ${pythoncmd} && chmod a-w ${_dependency_OUTPUT}
DEPENDS ${CMAKE_CURRENT_SOURCE_DIR}/${_dependency_INPUT} ${RP_CODEGEN} ${RP_${CMAKE_PROJECT_NAME}_DICTIONNARY}) DEPENDS ${CMAKE_CURRENT_SOURCE_DIR}/${_dependency_INPUT} ${RP_CODEGEN} ${RP_${CMAKE_PROJECT_NAME}_DICTIONNARY})
set_SOURCE_FILES_PROPERTIES(${_dependency_OUTPUT} PROPERTIES COMPILE_FLAGS "-DPRECISION_${_dependency_PREC}" GENERATED 1 IS_IN_BINARY_DIR 1 ) set_source_files_properties(${_dependency_OUTPUT} PROPERTIES COMPILE_FLAGS "-DPRECISION_${_dependency_PREC}" GENERATED 1 IS_IN_BINARY_DIR 1 )
else( generate_out ) else( generate_out )
set_SOURCE_FILES_PROPERTIES(${_dependency_OUTPUT} PROPERTIES COMPILE_FLAGS "-DPRECISION_${_dependency_PREC}" GENERATED 0 ) set_source_files_properties(${_dependency_OUTPUT} PROPERTIES COMPILE_FLAGS "-DPRECISION_${_dependency_PREC}" GENERATED 0 )
endif( generate_out ) endif( generate_out )
list(APPEND ${OUTPUTLIST} ${_dependency_OUTPUT}) list(APPEND ${OUTPUTLIST} ${_dependency_OUTPUT})
# @copyright (c) 2017 Inria. All rights reserved.
# - Find CPPCHECK bin directory
# Use this module by invoking find_package with the form:
# find_package(CPPCHECK
# [REQUIRED]) # Fail with error if cppcheck is not found
# This module finds headers and cppcheck library.
# Results are reported in variables:
# CPPCHECK_FOUND - True if cppcheck executable is found
# CPPCHECK_EXECUTABLE - cppcheck executable directory found
# The user can give specific paths where to find the libraries adding cmake
# options at configure (ex: cmake path/to/project -DCPPCHECK_DIR=path/to/cppcheck):
# CPPCHECK_DIR - Where to find the base directory of cppcheck
# CPPCHECK_BINDIR - Where to find the executable cppcheck
# The module can also look for the following environment variables if paths
# are not given as cmake variable: CPPCHECK_DIR, CPPCHECK_BINDIR
if (NOT CPPCHECK_FOUND)
set(CPPCHECK_DIR "" CACHE PATH "Installation directory of CPPCHECK library")
mark_as_advanced(CPPCHECK_DIR)
if (NOT CPPCHECK_FIND_QUIETLY)
message(STATUS "A cache variable, namely CPPCHECK_DIR, has been set to specify the install directory of CPPCHECK")
endif()
endif()
set(ENV_CPPCHECK_DIR "$ENV{CPPCHECK_DIR}")
set(ENV_CPPCHECK_BINDIR "$ENV{CPPCHECK_BINDIR}")
set(CPPCHECK_GIVEN_BY_USER "FALSE")
if ( CPPCHECK_DIR OR CPPCHECK_BINDIR OR ENV_CPPCHECK_DIR OR ENV_CPPCHECK_BINDIR )
set(CPPCHECK_GIVEN_BY_USER "TRUE")
endif()
message(STATUS "Looking for CPPCHECK")
endif()
# Looking for executable
# Add system include paths to search include
unset(where_to_look)
if(CPPCHECK_BINDIR)
list(APPEND where_to_look "${CPPCHECK_BINDIR}")
elseif(CPPCHECK_DIR)
list(APPEND where_to_look "${CPPCHECK_DIR}")
elseif(ENV_CPPCHECK_BINDIR)
list(APPEND where_to_look "${ENV_CPPCHECK_BINDIR}")
elseif(ENV_CPPCHECK_DIR)
list(APPEND where_to_look "${ENV_CPPCHECK_DIR}/bin")
else()
string(REPLACE ":" ";" _path_env "$ENV{PATH}")
list(APPEND where_to_look "${_path_env}")
endif()
list(APPEND where_to_look "${CMAKE_PLATFORM_IMPLICIT_INCLUDE_DIRECTORIES}")
list(APPEND where_to_look "${CMAKE_C_IMPLICIT_INCLUDE_DIRECTORIES}")
list(REMOVE_DUPLICATES where_to_look)
find_program(CPPCHECK_EXECUTABLE
NAMES cppcheck
HINTS ${where_to_look}
mark_as_advanced(CPPCHECK_EXECUTABLE)
if(CPPCHECK_EXECUTABLE)
execute_process(COMMAND ${CPPCHECK_EXECUTABLE} "--version" OUTPUT_VARIABLE CPPCHECK_VERSION OUTPUT_STRIP_TRAILING_WHITESPACE)
string(REGEX REPLACE "Cppcheck " "" CPPCHECK_VERSION "${CPPCHECK_VERSION}")
endif()
# check that CPPCHECK has been found
include(FindPackageHandleStandardArgs)
find_package_handle_standard_args(CPPCHECK DEFAULT_MSG
CPPCHECK_EXECUTABLE
CPPCHECK_VERSION)
...@@ -20,9 +20,11 @@ ...@@ -20,9 +20,11 @@
# This module finds headers and eztrace library. # This module finds headers and eztrace library.
# Results are reported in variables: # Results are reported in variables:
# EZTRACE_FOUND - True if headers and requested libraries were found # EZTRACE_FOUND - True if headers and requested libraries were found
# EZTRACE_C_FLAGS - list of required compilation flags (excluding -I)
# EZTRACE_INCLUDE_DIRS - eztrace include directories # EZTRACE_INCLUDE_DIRS - eztrace include directories
# EZTRACE_LIBRARY_DIRS - Link directories for eztrace libraries # EZTRACE_LIBRARY_DIRS - Link directories for eztrace libraries
# EZTRACE_LIBRARIES - eztrace component libraries to be linked # EZTRACE_LIBRARIES - eztrace component libraries to be linked
# EZTRACE_FOUND_WITH_PKGCONFIG - True if found with pkg-config
# The user can give specific paths where to find the libraries adding cmake # The user can give specific paths where to find the libraries adding cmake
# options at configure (ex: cmake path/to/project -DEZTRACE_DIR=path/to/eztrace): # options at configure (ex: cmake path/to/project -DEZTRACE_DIR=path/to/eztrace):
...@@ -33,11 +35,11 @@ ...@@ -33,11 +35,11 @@
# are not given as cmake variable: EZTRACE_DIR, EZTRACE_INCDIR, EZTRACE_LIBDIR # are not given as cmake variable: EZTRACE_DIR, EZTRACE_INCDIR, EZTRACE_LIBDIR
# Copyright 2012-2013 Inria # Copyright 2012-2018 Inria
# Copyright 2012-2013 Emmanuel Agullo # Copyright 2012-2013 Emmanuel Agullo
# Copyright 2012-2013 Mathieu Faverge # Copyright 2012-2013 Mathieu Faverge
# Copyright 2012 Cedric Castagnede # Copyright 2012 Cedric Castagnede
# Copyright 2013 Florent Pruvost # Copyright 2013-2018 Florent Pruvost
# Distributed under the OSI-approved BSD License (the "License"); # Distributed under the OSI-approved BSD License (the "License");
# see accompanying file MORSE-Copyright.txt for details. # see accompanying file MORSE-Copyright.txt for details.
...@@ -81,11 +83,18 @@ if( PKG_CONFIG_EXECUTABLE AND NOT EZTRACE_GIVEN_BY_USER ) ...@@ -81,11 +83,18 @@ if( PKG_CONFIG_EXECUTABLE AND NOT EZTRACE_GIVEN_BY_USER )
#endif() #endif()
else() else()
message(STATUS "${Magenta}Looking for EZTRACE - not found using PkgConfig." message(STATUS "${Magenta}Looking for EZTRACE - not found using PkgConfig."
"\n Perhaps you should add the directory containing eztrace.pc to" "\n Perhaps you should add the directory containing eztrace.pc to"
"\n the PKG_CONFIG_PATH environment variable.${ColourReset}") "\n the PKG_CONFIG_PATH environment variable.${ColourReset}")
endif()
if (EZTRACE_FOUND AND EZTRACE_LIBRARIES)
set(EZTRACE_FOUND_WITH_PKGCONFIG "TRUE")
else()
set(EZTRACE_FOUND_WITH_PKGCONFIG "FALSE")
endif() endif()
endif() endif()
set(EZTRACE_C_FLAGS "${EZTRACE_CFLAGS_OTHER}")
endif( PKG_CONFIG_EXECUTABLE AND NOT EZTRACE_GIVEN_BY_USER ) endif( PKG_CONFIG_EXECUTABLE AND NOT EZTRACE_GIVEN_BY_USER )
if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT EZTRACE_FOUND) OR (EZTRACE_GIVEN_BY_USER) ) if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT EZTRACE_FOUND) OR (EZTRACE_GIVEN_BY_USER) )
...@@ -177,15 +186,15 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT EZTRACE_FOUND) ...@@ -177,15 +186,15 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT EZTRACE_FOUND)
if(EZTRACE_DIR) if(EZTRACE_DIR)
set(EZTRACE_eztrace.h_DIRS "EZTRACE_eztrace.h_DIRS-NOTFOUND") set(EZTRACE_eztrace.h_DIRS "EZTRACE_eztrace.h_DIRS-NOTFOUND")
find_path(EZTRACE_eztrace.h_DIRS find_path(EZTRACE_eztrace.h_DIRS
NAMES eztrace.h NAMES eztrace.h
HINTS ${EZTRACE_DIR} HINTS ${EZTRACE_DIR}
PATH_SUFFIXES "include" "include/eztrace") PATH_SUFFIXES "include" "include/eztrace")
else() else()
HINTS ${PATH_TO_LOOK_FOR} HINTS ${PATH_TO_LOOK_FOR}
PATH_SUFFIXES "eztrace") PATH_SUFFIXES "eztrace")
endif() endif()
endif() endif()
mark_as_advanced(EZTRACE_eztrace.h_DIRS) mark_as_advanced(EZTRACE_eztrace.h_DIRS)
...@@ -222,9 +231,9 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT EZTRACE_FOUND) ...@@ -222,9 +231,9 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT EZTRACE_FOUND)
string(REPLACE ":" ";" _lib_env "$ENV{LIB}") string(REPLACE ":" ";" _lib_env "$ENV{LIB}")
else() else()
if(APPLE) if(APPLE)
string(REPLACE ":" ";" _lib_env "$ENV{DYLD_LIBRARY_PATH}") string(REPLACE ":" ";" _lib_env "$ENV{DYLD_LIBRARY_PATH}")
else() else()
string(REPLACE ":" ";" _lib_env "$ENV{LD_LIBRARY_PATH}") string(REPLACE ":" ";" _lib_env "$ENV{LD_LIBRARY_PATH}")
endif() endif()
list(APPEND _lib_env "${CMAKE_PLATFORM_IMPLICIT_LINK_DIRECTORIES}") list(APPEND _lib_env "${CMAKE_PLATFORM_IMPLICIT_LINK_DIRECTORIES}")
list(APPEND _lib_env "${CMAKE_C_IMPLICIT_LINK_DIRECTORIES}") list(APPEND _lib_env "${CMAKE_C_IMPLICIT_LINK_DIRECTORIES}")
...@@ -248,14 +257,14 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT EZTRACE_FOUND) ...@@ -248,14 +257,14 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT EZTRACE_FOUND)
set(EZTRACE_eztrace_LIBRARY "EZTRACE_eztrace_LIBRARY-NOTFOUND") set(EZTRACE_eztrace_LIBRARY "EZTRACE_eztrace_LIBRARY-NOTFOUND")
find_library(EZTRACE_eztrace_LIBRARY find_library(EZTRACE_eztrace_LIBRARY
NAMES eztrace NAMES eztrace
PATH_SUFFIXES lib lib32 lib64) PATH_SUFFIXES lib lib32 lib64)
else() else()
HINTS ${PATH_TO_LOOK_FOR}) HINTS ${PATH_TO_LOOK_FOR})
endif() endif()
endif() endif()
mark_as_advanced(EZTRACE_eztrace_LIBRARY) mark_as_advanced(EZTRACE_eztrace_LIBRARY)
...@@ -312,10 +321,10 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT EZTRACE_FOUND) ...@@ -312,10 +321,10 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT EZTRACE_FOUND)
if(NOT EZTRACE_WORKS) if(NOT EZTRACE_WORKS)
if(NOT EZTRACE_FIND_QUIETLY) if(NOT EZTRACE_FIND_QUIETLY)
message(STATUS "Looking for eztrace : test of eztrace_topology_init with eztrace library fails") message(STATUS "Looking for eztrace : test of eztrace_topology_init with eztrace library fails")
message(STATUS "CMAKE_REQUIRED_LIBRARIES: ${CMAKE_REQUIRED_LIBRARIES}") message(STATUS "CMAKE_REQUIRED_LIBRARIES: ${CMAKE_REQUIRED_LIBRARIES}")
message(STATUS "CMAKE_REQUIRED_INCLUDES: ${CMAKE_REQUIRED_INCLUDES}") message(STATUS "CMAKE_REQUIRED_INCLUDES: ${CMAKE_REQUIRED_INCLUDES}")
message(STATUS "Check in CMakeFiles/CMakeError.log to figure out why it fails") message(STATUS "Check in CMakeFiles/CMakeError.log to figure out why it fails")
endif() endif()
endif() endif()
set(CMAKE_REQUIRED_INCLUDES) set(CMAKE_REQUIRED_INCLUDES)
...@@ -331,6 +340,7 @@ if (EZTRACE_LIBRARIES) ...@@ -331,6 +340,7 @@ if (EZTRACE_LIBRARIES)
else() else()
list(GET EZTRACE_LIBRARIES 0 first_lib) list(GET EZTRACE_LIBRARIES 0 first_lib)
get_filename_component(first_lib_path "${first_lib}" PATH) get_filename_component(first_lib_path "${first_lib}" PATH)
set(EZTRACE_LIBRARY_DIRS "${first_lib_path}")
endif() endif()
if (${first_lib_path} MATCHES "/lib(32|64)?$") if (${first_lib_path} MATCHES "/lib(32|64)?$")
string(REGEX REPLACE "/lib(32|64)?$" "" not_cached_dir "${first_lib_path}") string(REGEX REPLACE "/lib(32|64)?$" "" not_cached_dir "${first_lib_path}")
# - Try to find fabulous (C-api)
# If this script have difficulties to find fabulous, you can try to help
# it by setting the variable FABULOUS_DIR to the prefix path where fabulous
# was installed
# Once done this will define
# FABULOUS_FOUND - System has fabulous
# FABULOUS_INCLUDE_DIRS - The fabulous include directories
# FABULOUS_MODULE_DIRS - The fabulous module directories for Fortran API
# FABULOUS_LIBRARIES - The libraries needed to use fabulous
# FABULOUS_DEFINITIONS - Compiler switches required for using fabulous
macro(FABULOUS_FIND_LIBRARIES_FROM_PKGCONFIG_RESULTS _prefix _pc_xprefix)
foreach(_library ${${_pc_xprefix}_LIBRARIES})
get_filename_component(_library ${_library} NAME_WE)
unset(_library_path)
unset(_library_path CACHE)
find_library(_library_path NAMES ${_library}
HINTS ${${_pc_xprefix}_LIBDIR} ${${_pc_xprefix}_LIBRARY_DIRS} )
if (_library_path)
list(APPEND ${_prefix}_LIBRARIES ${_library_path})
else()
message(FATAL_ERROR "Dependency of ${_prefix} '${_library}' NOT FOUND")
endif()
endforeach()
endmacro()
macro(FABULOUS_CHECK_FUNCTION_EXISTS _prefix _function)
unset(${_prefix}_WORKS)
unset(${_prefix}_WORKS CACHE)
set(CMAKE_REQUIRED_LIBRARIES ${${_prefix}_LIBRARIES})
set(CMAKE_REQUIRED_INCLUDES ${${_prefix}_INCLUDE_DIRS})
set(CMAKE_REQUIRED_DEFINITIONS ${${_prefix}_DEFINITIONS})
check_function_exists(${_function} ${_prefix}_WORKS)
set(CMAKE_REQUIRED_LIBRARIES "")
set(CMAKE_REQUIRED_INCLUDES "")
set(CMAKE_REQUIRED_DEFINITIONS "")
mark_as_advanced(${_prefix}_WORKS)
endmacro()
find_package(PkgConfig QUIET)
set(ENV_FABULOUS_DIR "$ENV{FABULOUS_DIR}")
set(ENV_FABULOUS_INCDIR "$ENV{FABULOUS_INCDIR}")
set(ENV_FABULOUS_LIBDIR "$ENV{FABULOUS_LIBDIR}")
set(FABULOUS_GIVEN_BY_USER "FALSE")
if ( FABULOUS_DIR OR ENV_FABULOUS_DIR
OR ( FABULOUS_INCDIR AND FABULOUS_LIBDIR )
OR ( ENV_FABULOUS_INCDIR AND ENV_FABULOUS_LIBDIR ) )
set(FABULOUS_GIVEN_BY_USER "TRUE")
endif()
set(FABULOUS_STATIC_FIND_QUIETLY "TRUE")
set(FABULOUS_SHARED_FIND_QUIETLY "TRUE")
if ((NOT FABULOUS_FOUND) AND (NOT FABULOUS_GIVEN_BY_USER) AND PKG_CONFIG_FOUND)
pkg_check_modules(PC_FABULOUS QUIET fabulous)
find_path(FABULOUS_STATIC_INCLUDE_DIR NAMES fabulous.h
HINTS ${PC_FABULOUS_STATIC_INCLUDEDIR} ${PC_FABULOUS_STATIC_INCLUDE_DIRS} )
find_library(FABULOUS_STATIC_LIBRARY NAMES libfabulous.a
HINTS ${PC_FABULOUS_STATIC_LIBDIR} ${PC_FABULOUS_STATIC_LIBRARY_DIRS} )
find_path(FABULOUS_SHARED_INCLUDE_DIR NAMES fabulous.h
HINTS ${PC_FABULOUS_INCLUDEDIR} ${PC_FABULOUS_INCLUDE_DIRS} )
find_library(FABULOUS_SHARED_LIBRARY NAMES libfabulous.so
HINTS ${PC_FABULOUS_LIBDIR} ${PC_FABULOUS_LIBRARY_DIRS} )
# handle the QUIETLY and REQUIRED arguments and set FABULOUS_FOUND to TRUE
# if all listed variables are TRUE
FABULOUS_STATIC DEFAULT_MSG
FABULOUS_STATIC_LIBRARY FABULOUS_STATIC_INCLUDE_DIR)
mark_as_advanced(FABULOUS_STATIC_INCLUDE_DIR FABULOUS_STATIC_LIBRARY)
FABULOUS_SHARED DEFAULT_MSG
FABULOUS_SHARED_LIBRARY FABULOUS_SHARED_INCLUDE_DIR)
mark_as_advanced(FABULOUS_SHARED_INCLUDE_DIR FABULOUS_SHARED_LIBRARY)
if (FABULOUS_STATIC_FOUND AND NOT FABULOUS_SHARED_FOUND)
set(FABULOUS_INCLUDE_DIRS ${FABULOUS_STATIC_INCLUDE_DIR} )
set(FABULOUS_DEFINITIONS ${PC_FABULOUS_STATIC_CFLAGS_OTHER} )
set(FABULOUS_LIBRARIES "")
fabulous_find_libraries_from_pkgconfig_results(FABULOUS PC_FABULOUS_STATIC)
elseif(FABULOUS_SHARED_FOUND)
set(FABULOUS_INCLUDE_DIRS ${FABULOUS_INCLUDE_DIR} )
set(FABULOUS_DEFINITIONS ${PC_FABULOUS_CFLAGS_OTHER} )
fabulous_find_libraries_from_pkgconfig_results(FABULOUS PC_FABULOUS)
endif()
fabulous_check_function_exists(FABULOUS fabulous_create)
FABULOUS DEFAULT_MSG
FABULOUS_LIBRARIES FABULOUS_INCLUDE_DIRS FABULOUS_WORKS)
endif()
if ((NOT FABULOUS_FOUND) AND (FABULOUS_GIVEN_BY_USER OR (NOT PKG_CONFIG_FOUND)))
# Currently the C-api (compiled version) does not depent on chameleon
# so the library only depends on CBLAS AND LAPACKE
set(FABULOUS_DEFINITIONS "")
if ( ( FABULOUS_INCDIR AND FABULOUS_LIBDIR ) OR ( ENV_FABULOUS_INCDIR AND ENV_FABULOUS_LIBDIR ) )
if ((NOT FABULOUS_LIBDIR) AND (NOT FABULOUS_INCDIR)
AND (ENV_FABULOUS_INCDIR AND ENV_FABULOUS_LIBDIR) )
set(FABULOUS_LIBDIR ${ENV_FABULOUS_LIBDIR})
set(FABULOUS_INCDIR ${ENV_FABULOUS_INCDIR})
endif()
find_path(FABULOUS_INCLUDE_DIRS NAMES fabulous.h HINTS ${FABULOUS_INCDIR})
find_path(FABULOUS_MODULE_DIRS NAMES fabulous_mod.mod HINTS ${FABULOUS_INCDIR}
PATH_SUFFIXES fabulous)
find_library(FABULOUS_STATIC_LIBRARY NAMES libfabulous.a HINTS ${FABULOUS_LIBDIR})
find_library(FABULOUS_SHARED_LIBRARY NAMES libfabulous.so HINTS ${FABULOUS_LIBDIR})
else()
if (ENV_FABULOUS_DIR AND NOT FABULOUS_DIR)
set(FABULOUS_DIR "${ENV_FABULOUS_DIR}" CACHE PATH "Installation prefix where fabulous is installed")
else()
set(FABULOUS_DIR "${FABULOUS_DIR}" CACHE PATH "Installation prefix where fabulous is installed")
endif()
HINTS ${FABULOUS_DIR}
PATH_SUFFIXES include include/fabulous)
PATH_SUFFIXES lib lib32 lib64 lib/fabulous lib32/fabulous lib64/fabulous)
endif()
find_package_handle_standard_args(FABULOUS_STATIC DEFAULT_MSG FABULOUS_STATIC_LIBRARY)
find_package_handle_standard_args(FABULOUS_SHARED DEFAULT_MSG FABULOUS_SHARED_LIBRARY)
mark_as_advanced(FABULOUS_STATIC_LIBRARY FABULOUS_SHARED_LIBRARY)
if (FABULOUS_FIND_REQUIRED)
find_package(CBLAS REQUIRED)
find_package(LAPACKE REQUIRED)
else()
find_package(CBLAS)
find_package(LAPACKE)
endif()
set(FABULOUS_LIBRARIES ${FABULOUS_STATIC_LIBRARY} ${CBLAS_LIBRARIES} ${LAPACKE_LIBRARIES} "-lstdc++" "-lm")
set(FABULOUS_LIBRARIES ${FABULOUS_SHARED_LIBRARY} ${CBLAS_LIBRARIES} ${LAPACKE_LIBRARIES})
endif()
endif()
...@@ -16,9 +16,11 @@ ...@@ -16,9 +16,11 @@
# This module finds headers and fxt library. # This module finds headers and fxt library.
# FXT_FOUND - True if headers and requested libraries were found # FXT_FOUND - True if headers and requested libraries were found
# FXT_C_FLAGS - list of required compilation flags (excluding -I)
# FXT_INCLUDE_DIRS - fxt include directories # FXT_INCLUDE_DIRS - fxt include directories
# FXT_LIBRARY_DIRS - Link directories for fxt libraries # FXT_LIBRARY_DIRS - Link directories for fxt libraries
# FXT_LIBRARIES - fxt component libraries to be linked # FXT_LIBRARIES - fxt component libraries to be linked
# FXT_FOUND_WITH_PKGCONFIG - True if found with pkg-config
# options at configure (ex: cmake path/to/project -DFXT_DIR=path/to/fxt): # options at configure (ex: cmake path/to/project -DFXT_DIR=path/to/fxt):
...@@ -29,11 +31,11 @@ ...@@ -29,11 +31,11 @@
# are not given as cmake variable: FXT_DIR, FXT_INCDIR, FXT_LIBDIR # are not given as cmake variable: FXT_DIR, FXT_INCDIR, FXT_LIBDIR
...@@ -77,11 +79,19 @@ if(PKG_CONFIG_EXECUTABLE AND NOT FXT_GIVEN_BY_USER) ...@@ -77,11 +79,19 @@ if(PKG_CONFIG_EXECUTABLE AND NOT FXT_GIVEN_BY_USER)
#endif() #endif()
else() else()
message(STATUS "${Magenta}Looking for FXT - not found using PkgConfig." message(STATUS "${Magenta}Looking for FXT - not found using PkgConfig."
"\n Perhaps you should add the directory containing fxt.pc to the" "\n Perhaps you should add the directory containing fxt.pc to the"
"\n PKG_CONFIG_PATH environment variable.${ColourReset}") "\n PKG_CONFIG_PATH environment variable.${ColourReset}")
endif() endif()
endif() endif()
set(FXT_C_FLAGS "${FXT_CFLAGS_OTHER}")
if (FXT_FOUND AND FXT_LIBRARIES)
set(FXT_FOUND_WITH_PKGCONFIG "TRUE")
else()
set(FXT_FOUND_WITH_PKGCONFIG "FALSE")
endif()
endif(PKG_CONFIG_EXECUTABLE AND NOT FXT_GIVEN_BY_USER) endif(PKG_CONFIG_EXECUTABLE AND NOT FXT_GIVEN_BY_USER)
if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT FXT_FOUND) OR (FXT_GIVEN_BY_USER) ) if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT FXT_FOUND) OR (FXT_GIVEN_BY_USER) )
...@@ -134,15 +144,15 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT FXT_FOUND) OR ...@@ -134,15 +144,15 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT FXT_FOUND) OR
if(FXT_DIR) if(FXT_DIR)
set(FXT_fxt.h_DIRS "FXT_fxt.h_DIRS-NOTFOUND") set(FXT_fxt.h_DIRS "FXT_fxt.h_DIRS-NOTFOUND")
find_path(FXT_fxt.h_DIRS find_path(FXT_fxt.h_DIRS
NAMES fxt.h NAMES fxt.h
HINTS ${FXT_DIR} HINTS ${FXT_DIR}
PATH_SUFFIXES "include" "include/fxt") PATH_SUFFIXES "include" "include/fxt")
else() else()
HINTS ${_inc_env} HINTS ${_inc_env}
PATH_SUFFIXES "fxt") PATH_SUFFIXES "fxt")
endif() endif()
endif() endif()
mark_as_advanced(FXT_fxt.h_DIRS) mark_as_advanced(FXT_fxt.h_DIRS)
...@@ -180,9 +190,9 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT FXT_FOUND) OR ...@@ -180,9 +190,9 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT FXT_FOUND) OR
else() else()
if(APPLE) if(APPLE)
else() else()
endif() endif()
...@@ -203,14 +213,14 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT FXT_FOUND) OR ...@@ -203,14 +213,14 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT FXT_FOUND) OR
set(FXT_fxt_LIBRARY "FXT_fxt_LIBRARY-NOTFOUND") set(FXT_fxt_LIBRARY "FXT_fxt_LIBRARY-NOTFOUND")
find_library(FXT_fxt_LIBRARY find_library(FXT_fxt_LIBRARY
NAMES fxt NAMES fxt
else() else()
NAMES fxt NAMES fxt
HINTS ${_lib_env}) HINTS ${_lib_env})
endif() endif()
endif() endif()
mark_as_advanced(FXT_fxt_LIBRARY) mark_as_advanced(FXT_fxt_LIBRARY)
...@@ -267,10 +277,10 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT FXT_FOUND) OR ...@@ -267,10 +277,10 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT FXT_FOUND) OR
if(NOT FXT_WORKS) if(NOT FXT_WORKS)
if(NOT FXT_FIND_QUIETLY) if(NOT FXT_FIND_QUIETLY)
message(STATUS "Looking for fxt : test of fut_keychange with fxt library fails") message(STATUS "Looking for fxt : test of fut_keychange with fxt library fails")
endif() endif()
endif() endif()
...@@ -286,6 +296,7 @@ if (FXT_LIBRARIES) ...@@ -286,6 +296,7 @@ if (FXT_LIBRARIES)
else() else()
list(GET FXT_LIBRARIES 0 first_lib) list(GET FXT_LIBRARIES 0 first_lib)
set(FXT_LIBRARY_DIRS "${first_lib_path}")
endif() endif()
# This module finds headers and hwloc library. # This module finds headers and hwloc library.
# HWLOC_FOUND - True if headers and requested libraries were found # HWLOC_FOUND - True if headers and requested libraries were found
# HWLOC_C_FLAGS - list of required compilation flags (excluding -I)
# HWLOC_INCLUDE_DIRS - hwloc include directories # HWLOC_INCLUDE_DIRS - hwloc include directories
# HWLOC_LIBRARY_DIRS - Link directories for hwloc libraries # HWLOC_LIBRARY_DIRS - Link directories for hwloc libraries
# HWLOC_LIBRARIES - hwloc component libraries to be linked # HWLOC_LIBRARIES - hwloc component libraries to be linked
# HWLOC_FOUND_WITH_PKGCONFIG - True if found with pkg-config
# options at configure (ex: cmake path/to/project -DHWLOC_DIR=path/to/hwloc): # options at configure (ex: cmake path/to/project -DHWLOC_DIR=path/to/hwloc):
# are not given as cmake variable: HWLOC_DIR, HWLOC_INCDIR, HWLOC_LIBDIR # are not given as cmake variable: HWLOC_DIR, HWLOC_INCDIR, HWLOC_LIBDIR
...@@ -73,18 +75,21 @@ if( PKG_CONFIG_EXECUTABLE AND NOT HWLOC_GIVEN_BY_USER ) ...@@ -73,18 +75,21 @@ if( PKG_CONFIG_EXECUTABLE AND NOT HWLOC_GIVEN_BY_USER )
if (NOT HWLOC_FIND_QUIETLY) if (NOT HWLOC_FIND_QUIETLY)
if (HWLOC_FOUND AND HWLOC_LIBRARIES) if (HWLOC_FOUND AND HWLOC_LIBRARIES)
message(STATUS "Looking for HWLOC - found using PkgConfig") message(STATUS "Looking for HWLOC - found using PkgConfig")
#if(NOT HWLOC_INCLUDE_DIRS)
# message("${Magenta}HWLOC_INCLUDE_DIRS is empty using PkgConfig."
# "Perhaps the path to hwloc headers is already present in your"
# "C(PLUS)_INCLUDE_PATH environment variable.${ColourReset}")
#endif()
else() else()
message(STATUS "${Magenta}Looking for HWLOC - not found using PkgConfig." message(STATUS "${Magenta}Looking for HWLOC - not found using PkgConfig."
"\n Perhaps you should add the directory containing hwloc.pc to" "\n Perhaps you should add the directory containing hwloc.pc to"
endif() endif()
endif() endif()
set(HWLOC_C_FLAGS "${HWLOC_CFLAGS_OTHER}")
set(HWLOC_FOUND_WITH_PKGCONFIG "TRUE")
else()
set(HWLOC_FOUND_WITH_PKGCONFIG "FALSE")
endif()
endif( PKG_CONFIG_EXECUTABLE AND NOT HWLOC_GIVEN_BY_USER ) endif( PKG_CONFIG_EXECUTABLE AND NOT HWLOC_GIVEN_BY_USER )
if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT HWLOC_FOUND) OR (HWLOC_GIVEN_BY_USER) ) if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT HWLOC_FOUND) OR (HWLOC_GIVEN_BY_USER) )
...@@ -138,15 +143,15 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT HWLOC_FOUND) O ...@@ -138,15 +143,15 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT HWLOC_FOUND) O
if(HWLOC_DIR) if(HWLOC_DIR)
set(HWLOC_hwloc.h_DIRS "HWLOC_hwloc.h_DIRS-NOTFOUND") set(HWLOC_hwloc.h_DIRS "HWLOC_hwloc.h_DIRS-NOTFOUND")
find_path(HWLOC_hwloc.h_DIRS find_path(HWLOC_hwloc.h_DIRS
NAMES hwloc.h NAMES hwloc.h
HINTS ${HWLOC_DIR} HINTS ${HWLOC_DIR}
PATH_SUFFIXES "include" "include/hwloc") PATH_SUFFIXES "include" "include/hwloc")
else() else()
PATH_SUFFIXES "hwloc") PATH_SUFFIXES "hwloc")
endif() endif()
endif() endif()
mark_as_advanced(HWLOC_hwloc.h_DIRS) mark_as_advanced(HWLOC_hwloc.h_DIRS)
...@@ -183,9 +188,9 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT HWLOC_FOUND) O ...@@ -183,9 +188,9 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT HWLOC_FOUND) O
else() else()
if(APPLE) if(APPLE)
else() else()
endif() endif()
...@@ -209,14 +214,14 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT HWLOC_FOUND) O ...@@ -209,14 +214,14 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT HWLOC_FOUND) O
set(HWLOC_hwloc_LIBRARY "HWLOC_hwloc_LIBRARY-NOTFOUND") set(HWLOC_hwloc_LIBRARY "HWLOC_hwloc_LIBRARY-NOTFOUND")
find_library(HWLOC_hwloc_LIBRARY find_library(HWLOC_hwloc_LIBRARY
NAMES hwloc NAMES hwloc
else() else()
endif() endif()
endif() endif()
mark_as_advanced(HWLOC_hwloc_LIBRARY) mark_as_advanced(HWLOC_hwloc_LIBRARY)
...@@ -273,10 +278,10 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT HWLOC_FOUND) O ...@@ -273,10 +278,10 @@ if( (NOT PKG_CONFIG_EXECUTABLE) OR (PKG_CONFIG_EXECUTABLE AND NOT HWLOC_FOUND) O
if(NOT HWLOC_WORKS) if(NOT HWLOC_WORKS)
if(NOT HWLOC_FIND_QUIETLY) if(NOT HWLOC_FIND_QUIETLY)
message(STATUS "Looking for hwloc : test of hwloc_topology_init with hwloc library fails") message(STATUS "Looking for hwloc : test of hwloc_topology_init with hwloc library fails")
endif() endif()
endif() endif()
...@@ -292,6 +297,7 @@ if (HWLOC_LIBRARIES) ...@@ -292,6 +297,7 @@ if (HWLOC_LIBRARIES)
else() else()
list(GET HWLOC_LIBRARIES 0 first_lib) list(GET HWLOC_LIBRARIES 0 first_lib)
set(HWLOC_LIBRARY_DIRS "${first_lib_path}")
endif() endif()
...@@ -318,12 +324,24 @@ endif() ...@@ -318,12 +324,24 @@ endif()
if (HWLOC_FOUND) if (HWLOC_FOUND)
set(HWLOC_SAVE_CMAKE_REQUIRED_INCLUDES ${CMAKE_REQUIRED_INCLUDES}) set(HWLOC_SAVE_CMAKE_REQUIRED_INCLUDES ${CMAKE_REQUIRED_INCLUDES})
list(APPEND CMAKE_REQUIRED_INCLUDES ${HWLOC_INCLUDE_DIRS}) list(APPEND CMAKE_REQUIRED_INCLUDES ${HWLOC_INCLUDE_DIRS})
set(CMAKE_REQUIRED_LIBRARIES)
if (HWLOC_LIBRARY_DIRS)
set (LIBDIR ${HWLOC_LIBRARY_DIRS})
elseif(HWLOC_LIBDIR)
set (LIBDIR ${HWLOC_LIBDIR})
endif()
if (LIBDIR)
foreach(lib_dir ${LIBDIR})
list(APPEND CMAKE_REQUIRED_LIBRARIES "-L${lib_dir}")
endforeach()
endif()
string(REGEX REPLACE "^ -" "-" CMAKE_REQUIRED_LIBRARIES "${CMAKE_REQUIRED_LIBRARIES}")
# test headers to guess the version # test headers to guess the version
check_struct_has_member( "struct hwloc_obj" parent hwloc.h HAVE_HWLOC_PARENT_MEMBER ) check_struct_has_member( "struct hwloc_obj" parent hwloc.h HAVE_HWLOC_PARENT_MEMBER )
check_struct_has_member( "struct hwloc_cache_attr_s" size hwloc.h HAVE_HWLOC_CACHE_ATTR ) check_struct_has_member( "struct hwloc_cache_attr_s" size hwloc.h HAVE_HWLOC_CACHE_ATTR )
check_c_source_compiles( "#include <hwloc.h> check_c_source_compiles( "#include <hwloc.h>
int main(void) { hwloc_obj_t o; o->type = HWLOC_OBJ_PU; return 0;}" HAVE_HWLOC_OBJ_PU) int main(void) { hwloc_obj_t o; o->type = HWLOC_OBJ_PU; return 0;}" HAVE_HWLOC_OBJ_PU)
include(CheckLibraryExists) include(CheckLibraryExists)
check_library_exists(${HWLOC_LIBRARIES} hwloc_bitmap_free "" HAVE_HWLOC_BITMAP) check_library_exists(${HWLOC_LIBRARIES} hwloc_bitmap_free "" HAVE_HWLOC_BITMAP)
# WARNING: only HYPRE lib is searched for now
# it is surely too simple, must be completed
...@@ -20,6 +20,7 @@ ...@@ -20,6 +20,7 @@
# METIS_INCLUDE_DIRS - metis include directories # METIS_INCLUDE_DIRS - metis include directories
# METIS_LIBRARY_DIRS - Link directories for metis libraries # METIS_LIBRARY_DIRS - Link directories for metis libraries
# METIS_LIBRARIES - metis component libraries to be linked # METIS_LIBRARIES - metis component libraries to be linked
# METIX_INTSIZE - Number of octets occupied by a idx_t (IDXTYPEWIDTH)
# options at configure (ex: cmake path/to/project -DMETIS_DIR=path/to/metis): # options at configure (ex: cmake path/to/project -DMETIS_DIR=path/to/metis):
...@@ -243,6 +244,9 @@ endif(METIS_LIBRARIES) ...@@ -243,6 +244,9 @@ endif(METIS_LIBRARIES)
if (METIS_LIBRARIES) if (METIS_LIBRARIES)
list(GET METIS_LIBRARIES 0 first_lib) list(GET METIS_LIBRARIES 0 first_lib)
if (NOT METIS_LIBRARY_DIRS)
set(METIS_LIBRARY_DIRS "${first_lib_path}")
endif()
set(METIS_DIR_FOUND "${not_cached_dir}" CACHE PATH "Installation directory of METIS library" FORCE) set(METIS_DIR_FOUND "${not_cached_dir}" CACHE PATH "Installation directory of METIS library" FORCE)
...@@ -253,6 +257,50 @@ endif() ...@@ -253,6 +257,50 @@ endif()
mark_as_advanced(METIS_DIR) mark_as_advanced(METIS_DIR)
mark_as_advanced(METIS_DIR_FOUND) mark_as_advanced(METIS_DIR_FOUND)
# Check the size of METIS_Idx
set(CMAKE_REQUIRED_INCLUDES ${METIS_INCLUDE_DIRS})
include(CheckCSourceRuns)
#stdio.h and stdint.h should be included by metis.h directly
set(METIS_C_TEST_METIS_Idx_4 "
#include <stdio.h>
#include <stdint.h>
#include <metis.h>
int main(int argc, char **argv) {
if (sizeof(idx_t) == 4)
return 0;
else
return 1;
set(METIS_C_TEST_METIS_Idx_8 "
#include <stdio.h>
#include <stdint.h>
#include <metis.h>
if (sizeof(idx_t) == 8)
return 0;
else
return 1;
unset(METIS_Idx_4 CACHE)
unset(METIS_Idx_8 CACHE)
check_c_source_runs("${METIS_C_TEST_METIS_Idx_4}" METIS_Idx_4)
check_c_source_runs("${METIS_C_TEST_METIS_Idx_8}" METIS_Idx_8)
if(NOT METIS_Idx_4)
if(NOT METIS_Idx_8)
set(METIS_INTSIZE -1)
else()
set(METIS_INTSIZE 8)
endif()
else()
set(METIS_INTSIZE 4)
endif()
# check that METIS has been found # check that METIS has been found
include(FindPackageHandleStandardArgs) include(FindPackageHandleStandardArgs)
...@@ -3,6 +3,7 @@ ...@@ -3,6 +3,7 @@
# This module allows to find MPI libraries by calling the official FindMPI module # This module allows to find MPI libraries by calling the official FindMPI module
# and adds an additional variable indicating the level of thread supported: # and adds an additional variable indicating the level of thread supported:
# MPI_THREAD_SUPPORTED_LEVEL - MPI_THREAD_MULTIPLE, MPI_THREAD_SERIALIZED, MPI_THREAD_FUNNELED, or MPI_THREAD_SINGLE # MPI_THREAD_SUPPORTED_LEVEL - MPI_THREAD_MULTIPLE, MPI_THREAD_SERIALIZED, MPI_THREAD_FUNNELED, or MPI_THREAD_SINGLE
# MPIEXT_FOUND - if a MPI has been found
# Copyright 2012-2013 Inria # Copyright 2012-2013 Inria
...@@ -29,8 +30,10 @@ if (NOT MPI_FOUND) ...@@ -29,8 +30,10 @@ if (NOT MPI_FOUND)
find_package(MPI) find_package(MPI)
endif() endif()
endif () endif ()
set(MPIEXT_FOUND ${MPI_FOUND})
if (MPI_FOUND) if (MPI_FOUND)
set(CMAKE_REQUIRED_INCLUDES_SAVE ${CMAKE_REQUIRED_INCLUDES}) set(CMAKE_REQUIRED_INCLUDES_SAVE ${CMAKE_REQUIRED_INCLUDES})
set(CMAKE_REQUIRED_LIBRARIES_SAVE ${CMAKE_REQUIRED_LIBRARIES}) set(CMAKE_REQUIRED_LIBRARIES_SAVE ${CMAKE_REQUIRED_LIBRARIES})
set(CMAKE_REQUIRED_FLAGS_SAVE ${CMAKE_REQUIRED_FLAGS}) set(CMAKE_REQUIRED_FLAGS_SAVE ${CMAKE_REQUIRED_FLAGS})
...@@ -103,9 +106,9 @@ int main(int argc, char **argv) { ...@@ -103,9 +106,9 @@ int main(int argc, char **argv) {
if(NOT SERIALIZED_TEST_RUNS) if(NOT SERIALIZED_TEST_RUNS)
check_c_source_runs("${MPI_C_TEST_FUNNELED_SOURCE}" FUNNELED_TEST_RUNS) check_c_source_runs("${MPI_C_TEST_FUNNELED_SOURCE}" FUNNELED_TEST_RUNS)
if(NOT FUNNELED_TEST_RUNS) if(NOT FUNNELED_TEST_RUNS)
set(MPI_THREAD_SUPPORTED_LEVEL "MPI_THREAD_SINGLE") set(MPI_THREAD_SUPPORTED_LEVEL "MPI_THREAD_SINGLE")
else(NOT FUNNELED_TEST_RUNS) else(NOT FUNNELED_TEST_RUNS)
set(MPI_THREAD_SUPPORTED_LEVEL "MPI_THREAD_FUNNELED") set(MPI_THREAD_SUPPORTED_LEVEL "MPI_THREAD_FUNNELED")
endif(NOT FUNNELED_TEST_RUNS) endif(NOT FUNNELED_TEST_RUNS)
else(NOT SERIALIZED_TEST_RUNS) else(NOT SERIALIZED_TEST_RUNS)
set(MPI_THREAD_SUPPORTED_LEVEL "MPI_THREAD_SERIALIZED") set(MPI_THREAD_SUPPORTED_LEVEL "MPI_THREAD_SERIALIZED")
...@@ -117,4 +120,5 @@ int main(int argc, char **argv) { ...@@ -117,4 +120,5 @@ int main(int argc, char **argv) {
set(CMAKE_REQUIRED_INCLUDES ${CMAKE_REQUIRED_INCLUDES_SAVE}) set(CMAKE_REQUIRED_INCLUDES ${CMAKE_REQUIRED_INCLUDES_SAVE})
set(CMAKE_REQUIRED_LIBRARIES ${CMAKE_REQUIRED_LIBRARIES_SAVE}) set(CMAKE_REQUIRED_LIBRARIES ${CMAKE_REQUIRED_LIBRARIES_SAVE})
set(CMAKE_REQUIRED_FLAGS ${CMAKE_REQUIRED_FLAGS_SAVE}) set(CMAKE_REQUIRED_FLAGS ${CMAKE_REQUIRED_FLAGS_SAVE})
endif(MPI_FOUND) endif(MPI_FOUND)
...@@ -258,9 +258,9 @@ if(QUARK_LIBRARIES) ...@@ -258,9 +258,9 @@ if(QUARK_LIBRARIES)
endif() endif()
foreach(lib ${HWLOC_LIBRARIES}) foreach(lib ${HWLOC_LIBRARIES})
if (EXISTS ${lib} OR ${lib} MATCHES "^-") if (EXISTS ${lib} OR ${lib} MATCHES "^-")
list(APPEND REQUIRED_LIBS "${lib}") list(APPEND REQUIRED_LIBS "${lib}")
else() else()
list(APPEND REQUIRED_LIBS "-l${lib}") list(APPEND REQUIRED_LIBS "-l${lib}")
endif() endif()
endforeach() endforeach()
endif() endif()
...@@ -296,7 +296,7 @@ if(QUARK_LIBRARIES) ...@@ -296,7 +296,7 @@ if(QUARK_LIBRARIES)
message(STATUS "Maybe QUARK is linked with specific libraries like. " message(STATUS "Maybe QUARK is linked with specific libraries like. "
"Have you tried with COMPONENTS (HWLOC)? See the explanation in FindQUARK.cmake.") "Have you tried with COMPONENTS (HWLOC)? See the explanation in FindQUARK.cmake.")
endif() endif()
endif() endif()
...@@ -307,6 +307,9 @@ endif(QUARK_LIBRARIES) ...@@ -307,6 +307,9 @@ endif(QUARK_LIBRARIES)
if (QUARK_LIBRARIES) if (QUARK_LIBRARIES)
list(GET QUARK_LIBRARIES 0 first_lib) list(GET QUARK_LIBRARIES 0 first_lib)
if (NOT QUARK_LIBRARY_DIRS)
set(QUARK_LIBRARY_DIRS "${first_lib_path}")
endif()
set(QUARK_DIR_FOUND "${not_cached_dir}" CACHE PATH "Installation directory of QUARK library" FORCE) set(QUARK_DIR_FOUND "${not_cached_dir}" CACHE PATH "Installation directory of QUARK library" FORCE)
Copyright ScalFmm 2011-2016 INRIA Copyright ScalFmm 2011-2018 INRIA
This software is a computer program which purpose is to compute the FMM. This software is a computer program which purpose is to compute the FMM.
