Commit fcd544d4 authored by ESTERIE Pierre's avatar ESTERIE Pierre
Fix include analysis for SonarQube
parent 9141123d
...@@ -17,8 +17,8 @@ export SOURCES_TO_ANALYZE="include src Examples Tests UTests" ...@@ -17,8 +17,8 @@ export SOURCES_TO_ANALYZE="include src Examples Tests UTests"
# run cppcheck analysis # run cppcheck analysis
# commented for now because too long # commented for now because too long
export CPPCHECK_INCLUDES="-IBuild/Src -ISrc -IContribs" export CPPCHECK_INCLUDES="-IBuild/include -Iinclude -IContribs"
export SOURCES_TO_ANALYZE="Src Examples Tests UTests" export SOURCES_TO_ANALYZE="src Examples Tests UTests"
export CPPCHECK_UNDEF="-USCALFMM_USE_AVX -USCALFMM_USE_AVX2 -USCALFMM_USE_SSE -USCALFMM_USE_EZTRACE -USCALFMM_BLAS_NOCHANGE -USCALFMM_BLAS_UPCASE -U__AVXPE_INTEL_COMPILER -U__INTEL_COMPILER -U__MIC__ -U__SSEPE_INTEL_COMPILER -U__SSSE3__ -U__SSSE4_1__ -U_WIN32 -Uming -U_MSC_VER -U__IBMCPP__ -U__PGI -U__SUNPRO_CC -U__clang__ -U__APPLE__ -U__HP_aCC -U__HP_cc -U__ICC" export CPPCHECK_UNDEF="-USCALFMM_USE_AVX -USCALFMM_USE_AVX2 -USCALFMM_USE_SSE -USCALFMM_USE_EZTRACE -USCALFMM_BLAS_NOCHANGE -USCALFMM_BLAS_UPCASE -U__AVXPE_INTEL_COMPILER -U__INTEL_COMPILER -U__MIC__ -U__SSEPE_INTEL_COMPILER -U__SSSE3__ -U__SSSE4_1__ -U_WIN32 -Uming -U_MSC_VER -U__IBMCPP__ -U__PGI -U__SUNPRO_CC -U__clang__ -U__APPLE__ -U__HP_aCC -U__HP_cc -U__ICC"
cppcheck -v -f --language=c++ --std=c++14 --platform=unix64 --enable=all --xml --xml-version=2 --suppress=missingIncludeSystem ${CPPCHECK_UNDEF} ${CPPCHECK_INCLUDES} ${SOURCES_TO_ANALYZE} 2> scalfmm-cppcheck.xml cppcheck -v -f --language=c++ --std=c++14 --platform=unix64 --enable=all --xml --xml-version=2 --suppress=missingIncludeSystem ${CPPCHECK_UNDEF} ${CPPCHECK_INCLUDES} ${SOURCES_TO_ANALYZE} 2> scalfmm-cppcheck.xml
