Commit d9cc3c50 authored by Berenger Bramas's avatar Berenger Bramas
Update install process
parent eb21d923
...@@ -150,6 +150,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse_ ...@@ -150,6 +150,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse_
set(INASTEMP_JUST_LIB TRUE) set(INASTEMP_JUST_LIB TRUE)
set(INASTEMP_DO_INSTALL TRUE)
# add the cmakelist directory # add the cmakelist directory
add_subdirectory(inastemp) add_subdirectory(inastemp)
# use the filled variables from inastemp # use the filled variables from inastemp
Subproject commit 5f1c2dd418c99c2eaa9299633929bbc1ac75001e Subproject commit 55234c380b3beb3f50f8c31545ef1c4d281170ba
