Commit c3e0c4a8 authored by COULAUD Olivier's avatar COULAUD Olivier
Restore letSTF just after separation with develop
parent baf36974
...@@ -7,11 +7,12 @@ endif() ...@@ -7,11 +7,12 @@ endif()
cmake_policy(SET CMP0004 NEW) cmake_policy(SET CMP0004 NEW)
set(CMAKE_DISABLE_IN_SOURCE_BUILD ON) set(CMAKE_DISABLE_IN_SOURCE_BUILD ON)
set(FUSE_LIST " MPI;BLAS;FFT;STARPU;CUDA;OPENCL;OMP4;SSE;AVX;AVX2;MIC;MPI2")
# Project Declaration # Project Declaration
project(SCALFMM C CXX) project(SCALFMM C CXX )
# check if compiling into source directories # check if compiling into source directories
string(COMPARE EQUAL "${CMAKE_CURRENT_SOURCE_DIR}" "${CMAKE_CURRENT_BINARY_DIR}" insource) string(COMPARE EQUAL "${CMAKE_CURRENT_SOURCE_DIR}" "${CMAKE_CURRENT_BINARY_DIR}" insource)
...@@ -215,7 +216,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/ ...@@ -215,7 +216,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/
# FUSE list # # FUSE list #
set(FUSE_LIST "") # set(FUSE_LIST "")
# then do list(APPEND FUSE_LIST "BLAS") to protect from FUSE_BLAS # then do list(APPEND FUSE_LIST "BLAS") to protect from FUSE_BLAS
list(APPEND FUSE_LIST "MPI") list(APPEND FUSE_LIST "MPI")
...@@ -307,7 +308,6 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/ ...@@ -307,7 +308,6 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/
endif() endif()
find_package(MPI REQUIRED) find_package(MPI REQUIRED)
if (MPI_CXX_INCLUDE_PATH) if (MPI_CXX_INCLUDE_PATH)
include_directories( ${MPI_CXX_INCLUDE_PATH} ) include_directories( ${MPI_CXX_INCLUDE_PATH} )
endif() endif()
...@@ -315,7 +315,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/ ...@@ -315,7 +315,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/
set(SCALFMM_CXX_FLAGS "${SCALFMM_CXX_FLAGS} ${MPI_CXX_COMPILE_FLAGS}") set(SCALFMM_CXX_FLAGS "${SCALFMM_CXX_FLAGS} ${MPI_CXX_COMPILE_FLAGS}")
endif() endif()
set(SCALFMM_INCLUDES "${SCALFMM_INCLUDES}; ${MPI_CXX_INCLUDE_PATH}") set(SCALFMM_INCLUDES "${SCALFMM_INCLUDES};${MPI_CXX_INCLUDE_PATH}")
endif() endif()
if (MPI_CXX_LINK_FLAGS) if (MPI_CXX_LINK_FLAGS)
list(APPEND "CMAKE_EXE_LINKER_FLAGS ${MPI_CXX_LINK_FLAGS}") list(APPEND "CMAKE_EXE_LINKER_FLAGS ${MPI_CXX_LINK_FLAGS}")
...@@ -821,6 +821,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/ ...@@ -821,6 +821,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/
# Build - lib # # Build - lib #
MESSAGE(STATUS "FUSE : ${FUSE_LIST} ")
add_subdirectory(Src) add_subdirectory(Src)
# Link with scalfmm lib # Link with scalfmm lib
set(scalfmm_lib scalfmm) set(scalfmm_lib scalfmm)
...@@ -13,6 +13,7 @@ ...@@ -13,6 +13,7 @@
#include "inria/utils.hpp" #include "inria/utils.hpp"
#include "inria/meta.hpp" #include "inria/meta.hpp"
#include <numeric> #include <numeric>
#include <iterator> #include <iterator>
#include <vector> #include <vector>
...@@ -189,8 +189,8 @@ create_balanced_linear_tree( ...@@ -189,8 +189,8 @@ create_balanced_linear_tree(
* @return [description] * @return [description]
std::size_t send_get_max_morton_idx( std::size_t send_get_max_morton_idx(
inria::mpi_config& conf, inria::mpi_config& conf,
std::size_t& max_morton_idx std::size_t& max_morton_idx
// Setting parametter // Setting parametter
...@@ -291,7 +291,7 @@ std::vector<details::cblt::node_info_from_range<Range>> create_balanced_linear_t ...@@ -291,7 +291,7 @@ std::vector<details::cblt::node_info_from_range<Range>> create_balanced_linear_t
last_morton_index = curr_idx_morton; last_morton_index = curr_idx_morton;
++nb_leaf; ++nb_leaf;
return {begin(lin_tree), end(lin_tree)}; return {begin(lin_tree), end(lin_tree)};
...@@ -14,7 +14,6 @@ file( ...@@ -14,7 +14,6 @@ file(
./*.cpp ./*.cpp
# Adding the project sources dir as an include dir # Adding the project sources dir as an include dir
INCLUDE_DIRECTORIES( INCLUDE_DIRECTORIES(
${SCALFMM_BINARY_DIR}/Src ${SCALFMM_BINARY_DIR}/Src
...@@ -56,7 +56,7 @@ int main(int argc, char* argv[]) ...@@ -56,7 +56,7 @@ int main(int argc, char* argv[])
FHelpDescribeAndExit(argc, argv, FHelpDescribeAndExit(argc, argv,
"Driver for HArmonic Spherical + Rotation -- kernel (1/r kernel).", "Driver for HArmonic Spherical + Rotation -- kernel (1/r kernel).",
FParameterDefinitions::InputFile, FParameterDefinitions::OctreeHeight, FParameterDefinitions::InputFile, FParameterDefinitions::OctreeHeight,
FParameterDefinitions::OctreeSubHeight, FParameterDefinitions::InputFile, FParameterDefinitions::OctreeSubHeight, FParameterDefinitions::OutputFile,
FParameterDefinitions::NbThreads); FParameterDefinitions::NbThreads);
const std::string defaultFile(/*SCALFMMDataPath+*/"../Data/test20k.fma"); const std::string defaultFile(/*SCALFMMDataPath+*/"../Data/test20k.fma");
...@@ -188,7 +188,56 @@ int main(int argc, char* argv[]) ...@@ -188,7 +188,56 @@ int main(int argc, char* argv[])
if(FParameters::existParameter(argc, argv, FParameterDefinitions::OutputFile.options)){
std::string name(FParameters::getStr(argc,argv,FParameterDefinitions::OutputFile.options, "output.fma"));
FFmaGenericWriter<FReal> writer(name) ;
FSize NbPoints = loader.getNumberOfParticles();
FReal * particles ;
particles = new FReal[8*NbPoints] ;
memset(particles,0,8*NbPoints*sizeof(FReal));
FSize j = 0 ;
tree.forEachLeaf([&](LeafClass* leaf){
// Input
const FReal*const posX = leaf->getTargets()->getPositions()[0];
const FReal*const posY = leaf->getTargets()->getPositions()[1];
const FReal*const posZ = leaf->getTargets()->getPositions()[2];
const FReal*const physicalValues = leaf->getTargets()->getPhysicalValues();
const FVector<FSize>& indexes = leaf->getTargets()->getIndexes();
// Computed data
const FReal*const potentials = leaf->getTargets()->getPotentials();
const FReal*const forcesX = leaf->getTargets()->getForcesX();
const FReal*const forcesY = leaf->getTargets()->getForcesY();
const FReal*const forcesZ = leaf->getTargets()->getForcesZ();
const FSize nbParticlesInLeaf = leaf->getTargets()->getNbParticles();
for(FSize idxPart = 0 ; idxPart < nbParticlesInLeaf ; ++idxPart){
j = 8*indexes[idxPart];
particles[j] = posX[idxPart] ;
particles[j+1] = posY[idxPart] ;
particles[j+2] = posZ[idxPart] ;
particles[j+3] = physicalValues[idxPart] ;
particles[j+4] = potentials[idxPart] ;
particles[j+5] = forcesX[idxPart] ;
particles[j+6] = forcesY[idxPart] ;
particles[j+7] = forcesZ[idxPart] ;
writer.writeHeader( loader.getCenterOfBox(), loader.getBoxWidth() , NbPoints, sizeof(FReal), 8) ;
writer.writeArrayOfReal(particles, 8 , NbPoints);
delete[] particles;
std::string name1( "output.fma");
FFmaGenericWriter<FReal> writer1(name1) ;
writer1.writeDistributionOfParticlesFromOctree(&tree,NbPoints) ;
return 0; return 0;
Copyright ScalFmm 2011-2016 INRIA Copyright ScalFmm 2011-2017 INRIA
This software is a computer program which purpose is to compute the FMM. This software is a computer program which purpose is to compute the FMM.
...@@ -2,9 +2,9 @@ ...@@ -2,9 +2,9 @@
#define FBASICCELLPOD_HPP #define FBASICCELLPOD_HPP
#include "../../Utils/FGlobal.hpp" #include "../../Src/Utils/FGlobal.hpp"
#include "../../Containers/FTreeCoordinate.hpp" #include "../../Src/Containers/FTreeCoordinate.hpp"
#include "../StarPUUtils/FStarPUDefaultAlign.hpp" #include "../../Src/GroupTree/StarPUUtils/FStarPUDefaultAlign.hpp"
struct alignas(FStarPUDefaultAlign::StructAlign) FBasicCellPOD { struct alignas(FStarPUDefaultAlign::StructAlign) FBasicCellPOD {
MortonIndex mortonIndex; MortonIndex mortonIndex;
#ifndef FCHEBCELLPOD_HPP #ifndef FCHEBCELLPOD_HPP
#define FCHEBCELLPOD_HPP #define FCHEBCELLPOD_HPP
#include "../Core/FBasicCellPOD.hpp" #include "FBasicCellPOD.hpp"
#include "../StarPUUtils/FStarPUDefaultAlign.hpp" #include "../Src/GroupTree/StarPUUtils/FStarPUDefaultAlign.hpp"
#include "../../Kernels/Chebyshev/FChebTensor.hpp" #include "../../Src/Kernels/Chebyshev/FChebTensor.hpp"
typedef FBasicCellPOD FChebCellPODCore; typedef FBasicCellPOD FChebCellPODCore;
#ifndef SCALFMM_STARPU_ALGO_HPP_ #ifndef SCALFMM_STARPU_ALGO_HPP_
#define SCALFMM_STARPU_ALGO_HPP_ #define SCALFMM_STARPU_ALGO_HPP_
//@FUSE_STARPU
#include <algorithm> #include <algorithm>
#include <cmath> // Used to round box differences #include <cmath> // Used to round box differences
#include <functional> #include <functional>
...@@ -9,7 +11,7 @@ ...@@ -9,7 +11,7 @@
#include <unordered_map> #include <unordered_map>
#include <starpu/1.2/starpu.h> #include <starpu.h>
#include "Core/FCoreCommon.hpp" #include "Core/FCoreCommon.hpp"
#include "Containers/FTreeCoordinate.hpp" #include "Containers/FTreeCoordinate.hpp"
...@@ -8,7 +8,9 @@ ...@@ -8,7 +8,9 @@
#ifndef _SCALFMM_STARPU_NODE_DATA_HANDLES_HPP_ #ifndef _SCALFMM_STARPU_NODE_DATA_HANDLES_HPP_
#define _SCALFMM_STARPU_NODE_DATA_HANDLES_HPP_ #define _SCALFMM_STARPU_NODE_DATA_HANDLES_HPP_
#include <starpu/1.2/starpu.h> // @FUSE_STARPU
#include <starpu.h>
#include <utility> #include <utility>
...@@ -43,9 +43,10 @@ class FOctree : public FNoCopyable { ...@@ -43,9 +43,10 @@ class FOctree : public FNoCopyable {
public: public:
using FRealType = FReal; using FRealType = FReal;
using CellClassType = CellClass; using CellClassType = CellClass;
using ContainerClassType = ContainerClass; using ContainerClassType = ContainerClass; //< The type of the container used to store particles in the Octree
using LeafClassType = LeafClass_; //< The type of the Leaf used in the Octree using LeafClassType = LeafClass_; //< The type of the Leaf used in the Octree
using LeafClass = LeafClass_; //< The type of the Leaf used in the Octree using LeafClass = LeafClass_; //< The type of the Leaf used in the Octree
using LeafClass_T = LeafClass_; //< The type of the Leaf used in the Octree
protected: protected:
typedef FOctree<FReal, CellClass , ContainerClass, LeafClass, CellAllocatorClass> OctreeType; typedef FOctree<FReal, CellClass , ContainerClass, LeafClass, CellAllocatorClass> OctreeType;
...@@ -29,6 +29,27 @@ enum FFmmOperations { ...@@ -29,6 +29,27 @@ enum FFmmOperations {
FFmmNearAndFarFields = (FFmmNearField|FFmmFarField) FFmmNearAndFarFields = (FFmmNearField|FFmmFarField)
std::string FFmmOperations_string(/*enum FFmmOperations*/ const unsigned int & value){
//if (value & FFmmNearAndFarFields) return std::string("FFmmNearAndFarFields") ;
//if (value & FFmmFarField) return std::string("FFmmFarField") ;
//if (value & FFmmNearField) return std::string("FFmmNearField" );
std::string op("");
if (value & FFmmP2P)
op += " FFmmP2P |";
if (value & FFmmP2M)
op += " FFmmP2M |";
if (value & FFmmM2M)
op += " FFmmM2M |";
if (value & FFmmM2L)
op += " FFmmM2L |";
if (value & FFmmL2L)
op += " FFmmL2L |";
if (value & FFmmL2P)
op += " FFmmL2P |";
op.erase(op.size()-2,op.size()-1);
return op;
* \brief Algorithm interface * \brief Algorithm interface
...@@ -98,7 +119,6 @@ protected: ...@@ -98,7 +119,6 @@ protected:
FAssertLF(FAbstractAlgorithm::upperWorkingLevel <= FAbstractAlgorithm::lowerWorkingLevel); FAssertLF(FAbstractAlgorithm::upperWorkingLevel <= FAbstractAlgorithm::lowerWorkingLevel);
FAssertLF(2 <= FAbstractAlgorithm::upperWorkingLevel); FAssertLF(2 <= FAbstractAlgorithm::upperWorkingLevel);
virtual void executeCore(const unsigned operationsToProceed) = 0; virtual void executeCore(const unsigned operationsToProceed) = 0;
public: public:
...@@ -24,6 +24,8 @@ ...@@ -24,6 +24,8 @@
template <class FReal> template <class FReal>
class FAbstractLoader { class FAbstractLoader {
public: public:
using dataType= FReal ;
/** Default destructor */ /** Default destructor */
virtual ~FAbstractLoader(){ virtual ~FAbstractLoader(){
#ifndef _F_BLOCKED_MPI_INTERPOLATION_HPP_
#define _F_BLOCKED_MPI_INTERPOLATION_HPP_
#include "../../Src/GroupTree/Core/FGroupTree.hpp"
#include "../../Src/Components/FSimpleLeaf.hpp"
#include "../../Src/Components/FSymbolicData.hpp"
#include "../../Src/Containers/FVector.hpp"
#include "../../Src/Kernels/P2P/FP2PParticleContainer.hpp"
#include "../../Src/Utils/FMath.hpp"
#include "../../Src/Utils/FMemUtils.hpp"
#include "../../Src/Utils/FParameters.hpp"
#include "../../Src/Files/FRandomLoader.hpp"
#include "../../Src/Files/FFmaGenericLoader.hpp"
#include "../../Src/GroupTree/Core/FGroupSeqAlgorithm.hpp"
#include "../../Src/GroupTree/Core/FGroupTaskAlgorithm.hpp"
#include "../../Src/GroupTree/Core/FGroupTaskStarpuAlgorithm.hpp"
#include "../../Src/GroupTree/Core/FP2PGroupParticleContainer.hpp"
#include "../../Src/Utils/FParameterNames.hpp"
#include "../../Src/Components/FTestParticleContainer.hpp"
#include "../../Src/Components/FTestCell.hpp"
#include "../../Src/Components/FTestKernels.hpp"
#include "../../Src/Core/FFmmAlgorithmThreadProc.hpp"
#include "../../Src/Files/FMpiTreeBuilder.hpp"
#include "../../Src/GroupTree/Core/FGroupTaskStarpuMpiAlgorithm.hpp"
#include "../../Src/Core/FFmmAlgorithm.hpp" //For validation
#include "../../Src/Files/FMpiFmaGenericLoader.hpp"
#include "../../Src/Containers/FCoordinateComputer.hpp"
#include "../../Src/GroupTree/StarPUUtils/FStarPUKernelCapacities.hpp"
#include <memory>
using namespace std;
namespace blockedMpiInterpolation{
//Function header
void timeAverage(int mpi_rank, int nproc, double elapsedTime);
FSize getNbParticlesPerNode(FSize mpi_count, FSize mpi_rank, FSize total);
template<
class GroupCellClass,
class GroupCellUpClass,
class GroupCellDownClass,
class GroupCellSymbClass,
class KernelClass,
class MatrixKernelClass
auto execute_algorithm(int argc, char* argv[]){
//Define parameters
const FParameterNames LocalOptionBlocSize { {"-bs"}, "The size of the block of the blocked tree"};
const FParameterNames LocalOptionEllipsoid = {{"-ellipsoid"} , " non uniform distribution on an ellipsoid of aspect ratio given by a=0.5 b=0.25 c=0.125"};
const FParameterNames LocalOptionCube = {{"-cube", "-uniform"} , " uniform distribution on cube (default)"};
// Define types
using FReal = double;
using GroupContainerClass =
FP2PGroupParticleContainer<FReal>;
using GroupOctreeClass =
FGroupTree< FReal, GroupCellSymbClass, GroupCellUpClass, GroupCellDownClass, GroupContainerClass, 1, 4, FReal>;
using GroupKernelClass =
FStarPUAllCpuCapacities<KernelClass>;
using GroupCpuWrapper =
FStarPUCpuWrapper<typename GroupOctreeClass::CellGroupClass, GroupCellClass, GroupKernelClass, typename GroupOctreeClass::ParticleGroupClass, GroupContainerClass> ;
using GroupAlgorithm =
FGroupTaskStarPUMpiAlgorithm<GroupOctreeClass, typename GroupOctreeClass::CellGroupClass, GroupKernelClass, typename GroupOctreeClass::ParticleGroupClass, GroupCpuWrapper> ;
// Init MPI_COM
FMpi mpiComm(argc,argv);
// Init timer
FTic timer;
// Getting parameters
const int groupSize =
FParameters::getValue(argc,argv,LocalOptionBlocSize.options, 250);
const unsigned int TreeHeight =
FParameters::getValue(argc, argv, FParameterDefinitions::OctreeHeight.options, 5);
const FSize totalNbParticles =
FParameters::getValue(argc,argv,FParameterDefinitions::NbParticles.options, FSize(20));
const FSize NbParticles =
getNbParticlesPerNode(mpiComm.global().processCount(), mpiComm.global().processId(), totalNbParticles);
// init particles position and physical value
struct TestParticle{
FPoint<FReal> position;
FReal physicalValue;
const FPoint<FReal>& getPosition(){
return position;
const unsigned int getWriteDataSize(void) const {
return sizeof(FReal);
const unsigned int getWriteDataNumber(void) const {
return 3;
const FReal* getPtrFirstData(void) const {
return position.data();
// LOADING PARTICLE
#ifndef LOAD_FILE
FRandomLoader<FReal> loader(NbParticles, 1.0, FPoint<FReal>(0,0,0), mpiComm.global().processId());
FAssertLF(loader.isOpen());
TestParticle* allParticles = new TestParticle[loader.getNumberOfParticles()];
memset(allParticles,0,(unsigned int) (sizeof(TestParticle)* loader.getNumberOfParticles()));
for(FSize idxPart = 0 ; idxPart < loader.getNumberOfParticles() ; ++idxPart){
loader.fillParticle(&allParticles[idxPart].position);
allParticles[idxPart].physicalValue = 0.1;
#else
const char* const filename = FParameters::getStr(argc,argv,FParameterDefinitions::InputFile.options, "../Data/test20k.fma");
FMpiFmaGenericLoader<FReal> loader(filename,mpiComm.global());
TestParticle* allParticles = new TestParticle[loader.getMyNumberOfParticles()];
memset(allParticles,0,(unsigned int) (sizeof(TestParticle)* loader.getMyNumberOfParticles()));
for(FSize idxPart = 0 ; idxPart < loader.getMyNumberOfParticles() ; ++idxPart){
loader.fillParticle(&allParticles[idxPart].position,&allParticles[idxPart].physicalValue);
#endif
FVector<TestParticle> myParticles;
FLeafBalance balancer;
FMpiTreeBuilder< FReal,
TestParticle >::DistributeArrayToContainer(
mpiComm.global(),
allParticles,
loader.getNumberOfParticles(),
loader.getBoxWidth(),
TreeHeight,
&myParticles,
&balancer);
// Each proc need to know the righest morton index
const FTreeCoordinate host = FCoordinateComputer::GetCoordinateFromPosition<FReal>(
TreeHeight,
myParticles[myParticles.getSize()-1].position );
const MortonIndex myLeftLimite = host.getMortonIndex();
MortonIndex leftLimite = -1;
if(mpiComm.global().processId() != 0){
FMpi::Assert(MPI_Recv(&leftLimite, sizeof(leftLimite), MPI_BYTE,
mpiComm.global().processId()-1, 0,
mpiComm.global().getComm(), MPI_STATUS_IGNORE), __LINE__);
if(mpiComm.global().processId() != mpiComm.global().processCount()-1){
FMpi::Assert(MPI_Send(const_cast<MortonIndex*>(&myLeftLimite), sizeof(myLeftLimite), MPI_BYTE,
mpiComm.global().processId()+1, 0,
mpiComm.global().getComm()), __LINE__);
FLOG(std::cout << "My last index is " << leftLimite << "\n");
FLOG(std::cout << "My left limite is " << myLeftLimite << "\n");
// Put the data into the tree
FP2PParticleContainer<FReal> myParticlesInContainer;
for(FSize idxPart = 0 ; idxPart < myParticles.getSize() ; ++idxPart){
myParticlesInContainer.push(myParticles[idxPart].position,
myParticles[idxPart].physicalValue);
GroupOctreeClass groupedTree(TreeHeight, loader.getBoxWidth(), loader.getCenterOfBox(), groupSize,
&myParticlesInContainer, true, leftLimite);
timer.tac();
std::cerr << "Done " << "(@Creating and Inserting Particles = " << timer.elapsed() << "s)." << std::endl;
int operationsToProceed = FFmmP2P | FFmmP2M | FFmmM2M | FFmmM2L | FFmmL2L | FFmmL2P;
const MatrixKernelClass MatrixKernel;
// Create Matrix Kernel
GroupKernelClass groupkernel(TreeHeight, loader.getBoxWidth(), loader.getCenterOfBox(), &MatrixKernel);
// Run the algorithm
GroupAlgorithm groupalgo(mpiComm.global(), &groupedTree,&groupkernel);
mpiComm.global().barrier();
timer.tic();
starpu_fxt_start_profiling();
groupalgo.execute(operationsToProceed);
starpu_fxt_stop_profiling();
timer.tac();
timeAverage(mpiComm.global().processId(), mpiComm.global().processCount(), timer.elapsed());
return &groupedTree;
void timeAverage(int mpi_rank, int nproc, double elapsedTime){
if(mpi_rank == 0){
double sumElapsedTimeMin = elapsedTime;
double sumElapsedTimeMax = elapsedTime;
for(int i = 1; i < nproc; ++i){
double tmp;
MPI_Recv(&tmp, 1, MPI_DOUBLE, i, 0, MPI_COMM_WORLD, MPI_STATUS_IGNORE);
if(tmp < sumElapsedTimeMin)
sumElapsedTimeMin = tmp;
if(tmp > sumElapsedTimeMax)
sumElapsedTimeMax = tmp;
std::cout << "Min time per node (MPI) : " << sumElapsedTimeMin << "s" << std::endl;
std::cout << "Max time per node (MPI) : " << sumElapsedTimeMax << "s" << std::endl;
} else {
MPI_Send(&elapsedTime, 1, MPI_DOUBLE, 0, 0, MPI_COMM_WORLD);
MPI_Barrier(MPI_COMM_WORLD);
FSize getNbParticlesPerNode(FSize mpi_count, FSize mpi_rank, FSize total){
if(mpi_rank < (total%mpi_count))
return ((total - (total%mpi_count))/mpi_count)+1;
return ((total - (total%mpi_count))/mpi_count);
#endif
...@@ -199,7 +199,6 @@ private: ...@@ -199,7 +199,6 @@ private:
FReal * tmpVal; ///< Temporary array to read data FReal * tmpVal; ///< Temporary array to read data
/// Count of other data pieces to read in a particle record after the 4 first ones. /// Count of other data pieces to read in a particle record after the 4 first ones.
unsigned int otherDataToRead; unsigned int otherDataToRead;
void open_file(const std::string filename, const bool binary) { void open_file(const std::string filename, const bool binary) {
if(binary) { if(binary) {
this->file = new std::fstream (filename.c_str(),std::ifstream::in| std::ios::binary); this->file = new std::fstream (filename.c_str(),std::ifstream::in| std::ios::binary);
...@@ -216,6 +215,7 @@ private: ...@@ -216,6 +215,7 @@ private:
public: public:
using dataType= FReal ; // Just to what kind of data we handle
* This constructor opens a file using the given mode and reads its * This constructor opens a file using the given mode and reads its
* header. The file will be kept opened until destruction of the object. * header. The file will be kept opened until destruction of the object.
...@@ -543,8 +543,8 @@ template <class FReal> ...@@ -543,8 +543,8 @@ template <class FReal>
class FFmaGenericWriter { class FFmaGenericWriter {
std::fstream *file; ///< the stream used to read the file std::fstream *file; ///< the stream used to write the file
bool binaryFile ; ///< if true the file to read is in binary mode bool _binaryFile ; ///< if true the file is in binary mode
public: public:
...@@ -555,11 +555,11 @@ public: ...@@ -555,11 +555,11 @@ public:
* @param filename the name of the file to open. * @param filename the name of the file to open.
FFmaGenericWriter(const std::string & filename): binaryFile(false) { FFmaGenericWriter(const std::string & filename): _binaryFile(false) {
std::string ext(".bfma"); std::string ext(".bfma");
// open particle file // open particle file
if(filename.find(".bfma") !=std::string::npos) { if(filename.find(".bfma") !=std::string::npos) {
binaryFile = true; _binaryFile = true;
this->file = new std::fstream (filename.c_str(),std::ifstream::out| std::ios::binary); this->file = new std::fstream (filename.c_str(),std::ifstream::out| std::ios::binary);
else if(filename.find(".fma")!=std::string::npos ) { else if(filename.find(".fma")!=std::string::npos ) {
...@@ -583,7 +583,7 @@ public: ...@@ -583,7 +583,7 @@ public:
* @param binary true if the file to open is in binary mode * @param binary true if the file to open is in binary mode
FFmaGenericWriter(const std::string & filename, const bool binary ) : file(nullptr), binaryFile(binary) FFmaGenericWriter(const std::string & filename, const bool binary ) : file(nullptr), _binaryFile(binary)
...@@ -616,6 +616,14 @@ public: ...@@ -616,6 +616,14 @@ public:
* To know if opened file is in binary mode
* @return true ifopened file is in binary mode
bool isBinary() const{
return this->_binaryFile;
* Writes the header of the FMA file * Writes the header of the FMA file
* \warning All values inside typePart should be of the same type (float or double) * \warning All values inside typePart should be of the same type (float or double)
...@@ -633,7 +641,7 @@ public: ...@@ -633,7 +641,7 @@ public:
typeFReal[1] = ndata; typeFReal[1] = ndata;
FReal x = boxWidth * FReal(0.5); FReal x = boxWidth * FReal(0.5);
if(this->binaryFile) { if(this->_binaryFile) {
this->writerBinaryHeader(centerOfBox,x,nbParticles,typeFReal); this->writerBinaryHeader(centerOfBox,x,nbParticles,typeFReal);
else { else {
...@@ -656,7 +664,7 @@ public: ...@@ -656,7 +664,7 @@ public:
const unsigned int dataType, const unsigned int nbDataPerRecord) { const unsigned int dataType, const unsigned int nbDataPerRecord) {
unsigned int typeFReal[2] = {dataType , nbDataPerRecord }; unsigned int typeFReal[2] =
