Commit b57cf433 authored by mkhannouz's avatar mkhannouz Committed by Berenger Bramas
Fix compilation issue in testBlockedChebyshev
parent 2eadc337
...@@ -69,7 +69,6 @@ int main(int argc, char* argv[]){ ...@@ -69,7 +69,6 @@ int main(int argc, char* argv[]){
typedef FChebCellPODLocal<FReal,ORDER> GroupCellDownClass; typedef FChebCellPODLocal<FReal,ORDER> GroupCellDownClass;
typedef FChebCellPOD<FReal,ORDER> GroupCellClass; typedef FChebCellPOD<FReal,ORDER> GroupCellClass;
typedef FP2PGroupParticleContainer<FReal> GroupContainerClass; typedef FP2PGroupParticleContainer<FReal> GroupContainerClass;
typedef FGroupTree< FReal, GroupCellClass, GroupCellSymbClass, GroupCellUpClass, GroupCellDownClass, GroupContainerClass, 1, 4, FReal> GroupOctreeClass; typedef FGroupTree< FReal, GroupCellClass, GroupCellSymbClass, GroupCellUpClass, GroupCellDownClass, GroupContainerClass, 1, 4, FReal> GroupOctreeClass;
#ifdef SCALFMM_USE_STARPU #ifdef SCALFMM_USE_STARPU
...@@ -103,7 +102,7 @@ int main(int argc, char* argv[]){ ...@@ -103,7 +102,7 @@ int main(int argc, char* argv[]){
setSeed(1); setSeed(1);
FReal * tmpParticles = new FReal[4*loader.getNumberOfParticles()]; FReal * tmpParticles = new FReal[4*loader.getNumberOfParticles()];
if(FParameters::existParameter(argc, argv, "-ellipsoid")) { if(FParameters::existParameter(argc, argv, "-ellipsoid")) {
nonunifRandomPointsOnElipsoid(loader.getNumberOfParticles(), loader.getBoxWidth()/2, loader.getBoxWidth()/4, loader.getBoxWidth()/8, tmpParticles); nonunifRandomPointsOnElipsoid(loader.getNumberOfParticles(), loader.getBoxWidth()/2, loader.getBoxWidth()/4, tmpParticles);
else if(FParameters::existParameter(argc, argv, "-plummer")) { else if(FParameters::existParameter(argc, argv, "-plummer")) {
//The M argument is not used in the algorithm of the plummer distribution //The M argument is not used in the algorithm of the plummer distribution
