Commit a603adb4 authored by ESTERIE Pierre's avatar ESTERIE Pierre
Remove fuse list for Cuda/OpenCL for now
parent 170bc77d
...@@ -384,7 +384,7 @@ if(MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse_c ...@@ -384,7 +384,7 @@ if(MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse_c
set(STARPU_COMPONENT_LIST "HWLOC") set(STARPU_COMPONENT_LIST "HWLOC")
if(SCALFMM_USE_CUDA) if(SCALFMM_USE_CUDA)
message(WARNING "This release doest not include a full support for CUDA/OpenCl.") message(WARNING "This release doest not include a full support for CUDA/OpenCl.")
list(APPEND STARPU_COMPONENT_LIST "CUDA") #list(APPEND STARPU_COMPONENT_LIST "CUDA")
endif() endif()
list(APPEND FUSE_LIST "CUDA") list(APPEND FUSE_LIST "CUDA")
if(SCALFMM_USE_MPI) if(SCALFMM_USE_MPI)
...@@ -392,7 +392,7 @@ if(MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse_c ...@@ -392,7 +392,7 @@ if(MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse_c
endif() endif()
if(SCALFMM_USE_OPENCL) if(SCALFMM_USE_OPENCL)
list(APPEND STARPU_COMPONENT_LIST "OPENCL") #list(APPEND STARPU_COMPONENT_LIST "OPENCL")
endif() endif()
list(APPEND FUSE_LIST "OPENCL") list(APPEND FUSE_LIST "OPENCL")
...@@ -403,10 +403,10 @@ if(MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse_c ...@@ -403,10 +403,10 @@ if(MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse_c
target_link_libraries(${CMAKE_PROJECT_NAME} PUBLIC starpu::starpu_dep) target_link_libraries(${CMAKE_PROJECT_NAME} PUBLIC starpu::starpu_dep)
list(APPEND FUSE_LIST "STARPU") list(APPEND FUSE_LIST "STARPU")
list(APPEND FUSE_LIST "CUDA") #list(APPEND FUSE_LIST "CUDA")
endif() endif()
list(APPEND FUSE_LIST "OPENCL") #list(APPEND FUSE_LIST "OPENCL")
endif() endif()
else(STARPU_FOUND) else(STARPU_FOUND)
message(FATAL_ERROR "StarPU not found.") message(FATAL_ERROR "StarPU not found.")
