Commit 91d5c7d6 authored by COULAUD Olivier's avatar COULAUD Olivier
Fix typo
parent d904be81
...@@ -653,7 +653,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/") ...@@ -653,7 +653,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
if(PKG_CONFIG_FOUND) if(PKG_CONFIG_FOUND)
set(PKG_CONFIG_USE_CMAKE_PREFIX_PATH "ON") set(PKG_CONFIG_USE_CMAKE_PREFIX_PATH "ON")
pkg_search_module( EZTrace REQUIRED eztrace) pkg_search_module( EZTrace REQUIRED eztrace)
if(PEZTrace_FOUND) if(EZTrace_FOUND)
link_directories(${EZTrace_LIBRARY_DIRS}) link_directories(${EZTrace_LIBRARY_DIRS})
link_libraries( ${EZTrace_LIBRARIES}) link_libraries( ${EZTrace_LIBRARIES})
IF( SCALFMM_USE_MPI ) IF( SCALFMM_USE_MPI )
