Commit 8bd7dbf0 authored by BLANCHARD Pierre's avatar BLANCHARD Pierre
Add private Addon for H-Matrices.
parent 2cbf6a19
# check if compiling into source directories
STRING(COMPARE EQUAL "${CMAKE_SOURCE_DIR}" "${CMAKE_BINARY_DIR}" insource)
if(insource)
MESSAGE(FATAL_ERROR "${PROJECT_NAME} requires an out of source build. Goto ./Build and tapes cmake ../")
endif(insource)
project(ADDONS_HMAT_SCALFMM CXX C)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} ${SCALFMM_CXX_FLAGS}")
# Active language
ENABLE_LANGUAGE(CXX C)
MESSAGE(STATUS " CXX ${CMAKE_CXX_COMPILER_ID}" )
# if ask to build addon
if(SCALFMM_ADDON_HMAT)
# first build lib scalfmmhmat
set(LIBRARY_OUTPUT_PATH ../lib/${CMAKE_BUILD_TYPE})
# Searching all cpp file
file( GLOB_RECURSE source_lib_files Src/*.cpp )
# Adding cpp files to project
add_library( scalfmmhmat STATIC ${source_lib_files} )
# Add blas library (even if it is set to off)
target_link_libraries( scalfmmhmat scalfmm)
# Adding the entire project dir as an include dir
INCLUDE_DIRECTORIES(
${CMAKE_BINARY_DIR}/Src
${CMAKE_SOURCE_DIR}/Src
${SCALFMM_INCLUDES}
# Install lib
install( TARGETS scalfmmhmat ARCHIVE DESTINATION lib )
# Install header
SET(my_include_dirs "Src")
file( GLOB hpp_in_dir Src/*.hpp Src/*.h)
INSTALL( FILES ${hpp_in_dir} DESTINATION include/ScalFmm/HMat )
file( GLOB_RECURSE source_tests_files Tests/*.c )
INCLUDE_DIRECTORIES( ${CMAKE_BINARY_DIR}/Src )
# Then build test files
foreach(exec ${source_tests_files})
get_filename_component(
execname ${exec}
NAME_WE
set(compile_exec "TRUE")
foreach(fuse_key ${FUSE_LIST})
file(STRINGS "${exec}" lines_fuse REGEX "@FUSE_${fuse_key}")
if(lines_fuse)
if( NOT SCALFMM_USE_${fuse_key} )
MESSAGE( STATUS "This needs ${fuse_key} = ${exec}" )
set(compile_exec "FALSE")
endif()
endif()
endforeach()
# Dependency are OK
if( compile_exec )
add_executable( ${execname} ${exec} )
# link to scalfmm and scalfmmhmat
${execname}
${scalfmm_lib}
scalfmmhmat
# ${BLAS_LIBRARIES}
# ${LAPACK_LIBRARIES}
${SCALFMM_LIBRARIES}
endif()
endforeach(exec)
endif()
...@@ -229,8 +229,8 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/ ...@@ -229,8 +229,8 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/
#set(SCALFMM_FLAGS_OPTI_RELEASE "-fp-model precise -fp-model source -fimf-precision=low -funroll-loops -ftree-vectorize" #set(SCALFMM_FLAGS_OPTI_RELEASE "-fp-model precise -fp-model source -fimf-precision=low -funroll-loops -ftree-vectorize"
set(SCALFMM_FLAGS_OPTI_RELEASE "-funroll-loops -ftree-vectorize" set(SCALFMM_FLAGS_OPTI_RELEASE "-funroll-loops -ftree-vectorize"
CACHE STRING "Set your optimization flags for release mode.") CACHE STRING "Set your optimization flags for release mode.")
# set(SCALFMM_FLAGS_OPTI_RELEASE "-funroll-loops -ftree-vectorize" CACHE STRING # set(SCALFMM_FLAGS_OPTI_RELEASE "-funroll-loops -ftree-vectorize" CACHE STRING
# "Set your optimization flags for release mode.") # "Set your optimization flags for release mode.")
else() else()
set(SCALFMM_FLAGS_OPTI_RELEASE "-ffast-math -funroll-loops -ftree-vectorize" CACHE STRING set(SCALFMM_FLAGS_OPTI_RELEASE "-ffast-math -funroll-loops -ftree-vectorize" CACHE STRING
"Set your optimization flags for release mode.") "Set your optimization flags for release mode.")
...@@ -654,18 +654,18 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/ ...@@ -654,18 +654,18 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/
link_libraries( ${EZTrace_LIBRARIES}) link_libraries( ${EZTrace_LIBRARIES})
IF( SCALFMM_USE_MPI ) IF( SCALFMM_USE_MPI )
link_libraries(-leztrace-autostart-mpi) link_libraries(-leztrace-autostart-mpi)
ENDIF(SCALFMM_USE_MPI) ENDIF(SCALFMM_USE_MPI)
include_directories(${EZTrace_INCLUDE_DIRS}) include_directories(${EZTrace_INCLUDE_DIRS})
MESSAGE(STATUS "EZTRACE: ${EZTrace_INCLUDE_DIRS} ${EZTrace_LIBRARY_DIRS} ${EZTrace_LIBRARIES}") MESSAGE(STATUS "EZTRACE: ${EZTrace_INCLUDE_DIRS} ${EZTrace_LIBRARY_DIRS} ${EZTrace_LIBRARIES}")
CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_ALGO "Set to ON to trace the full algorithm (all operators)" ON "SCALFMM_USE_EZTRACE" OFF ) CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_ALGO "Set to ON to trace the full algorithm (all operators)" ON "SCALFMM_USE_EZTRACE" OFF )
CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_P2M "Set to ON to trace P2M operator" OFF "SCALFMM_USE_EZTRACE" OFF ) CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_P2M "Set to ON to trace P2M operator" OFF "SCALFMM_USE_EZTRACE" OFF )
CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_M2M "Set to ON to trace M2M operator" OFF "SCALFMM_USE_EZTRACE" OFF ) CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_M2M "Set to ON to trace M2M operator" OFF "SCALFMM_USE_EZTRACE" OFF )
CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_M2L "Set to ON to trace M2L operator" OFF "SCALFMM_USE_EZTRACE" OFF ) CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_M2L "Set to ON to trace M2L operator" OFF "SCALFMM_USE_EZTRACE" OFF )
CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_L2L "Set to ON to trace L2L operator" OFF "SCALFMM_USE_EZTRACE" OFF ) CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_L2L "Set to ON to trace L2L operator" OFF "SCALFMM_USE_EZTRACE" OFF )
CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_P2P "Set to ON to trace P2P operator" OFF "SCALFMM_USE_EZTRACE" OFF ) CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_P2P "Set to ON to trace P2P operator" OFF "SCALFMM_USE_EZTRACE" OFF )
else(EZTrace_FOUND) else(EZTrace_FOUND)
MESSAGE(WARNING "Eztrace not found - EZTRACE Is set to OFF") MESSAGE(WARNING "Eztrace not found - EZTRACE Is set to OFF")
set(SCALFMM_USE_EZTRACE OFF) set(SCALFMM_USE_EZTRACE OFF)
endif(EZTrace_FOUND) endif(EZTrace_FOUND)
else(PKG_CONFIG_FOUND) else(PKG_CONFIG_FOUND)
MESSAGE(WARNING "PKG-CONFIG not found - EZTRACE Is set to OFF") MESSAGE(WARNING "PKG-CONFIG not found - EZTRACE Is set to OFF")
...@@ -680,13 +680,13 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/ ...@@ -680,13 +680,13 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/
if((WIN32 OR (${CMAKE_SYSTEM_NAME} MATCHES "Windows")) AND SCALFMM_USE_SIGNALS) if((WIN32 OR (${CMAKE_SYSTEM_NAME} MATCHES "Windows")) AND SCALFMM_USE_SIGNALS)
# We are on Windows and we cannot catch signals # We are on Windows and we cannot catch signals
message( FATAL_ERROR "Catching the signals requieres an UNIX system." ) message( FATAL_ERROR "Catching the signals requieres an UNIX system." )
else() else()
IF( NOT APPLE) IF( NOT APPLE)
SET(SCALFMM_CXX_FLAGS "${SCALFMM_CXX_FLAGS} -rdynamic") SET(SCALFMM_CXX_FLAGS "${SCALFMM_CXX_FLAGS} -rdynamic")
ENDIF() ENDIF()
endif() endif()
...@@ -822,7 +822,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/ ...@@ -822,7 +822,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/
set(CPACK_SOURCE_GENERATOR "TGZ") set(CPACK_SOURCE_GENERATOR "TGZ")
set(CPACK_SOURCE_PACKAGE_FILE_NAME "SCALFMM-${SCALFMM_MAJOR_VERSION}.${SCALFMM_MINOR_VERSION}-${CPACK_PACKAGE_VERSION_PATCH}") set(CPACK_SOURCE_PACKAGE_FILE_NAME "SCALFMM-${SCALFMM_MAJOR_VERSION}.${SCALFMM_MINOR_VERSION}-${CPACK_PACKAGE_VERSION_PATCH}")
set(CPACK_SOURCE_IGNORE_FILES "\\\\.git;.DS_Store;.*~;/*.aux;/*.idx;/*.log;/*.out;/*.toc;/*.ilg;scalfmm.pro*;org.eclipse.core.resources.prefs;.cproject;.project") set(CPACK_SOURCE_IGNORE_FILES "\\\\.git;.DS_Store;.*~;/*.aux;/*.idx;/*.log;/*.out;/*.toc;/*.ilg;scalfmm.pro*;org.eclipse.core.resources.prefs;.cproject;.project")
list(APPEND CPACK_SOURCE_IGNORE_FILES "${CMAKE_CURRENT_BINARY_DIR};${CMAKE_CURRENT_SOURCE_DIR}/Utils/;Notes;Deprecated;/Build*;/noDist/;/Bench;ToRemove;Olivier") list(APPEND CPACK_SOURCE_IGNORE_FILES "${CMAKE_CURRENT_BINARY_DIR};${CMAKE_CURRENT_SOURCE_DIR}/Utils/;Notes;Deprecated;/Build*;/noDist/;/Bench;ToRemove;Olivier;Addons/HMat")
# Uniform;GroupTree;Adaptive;testUnif*;/*Lagrange*") # Uniform;GroupTree;Adaptive;testUnif*;/*Lagrange*")
#list(APPEND CPACK_SOURCE_IGNORE_FILES "Stages;Uniform;Adaptive;testUnif*;*Lagrange*" ) #list(APPEND CPACK_SOURCE_IGNORE_FILES "Stages;Uniform;Adaptive;testUnif*;*Lagrange*" )
