Commit 77783e92 authored by Martin Khannouz's avatar Martin Khannouz Committed by Berenger Bramas
Add algorithm to reproduce explicit mapping of data whatever the filling
of the octree.
parent 31681394
...@@ -1682,12 +1682,12 @@ protected: ...@@ -1682,12 +1682,12 @@ protected:
#else #else
//"P2P_out-nb_i_p_nb_i_p_s" //"P2P_out-nb_i_p_nb_i_p_s"
STARPU_NAME, taskNames->print("P2P_out", "%d, %lld, %lld, %d, %lld, %lld, %d, %lld, %lld, %lld, %lld, %d\n", STARPU_NAME, taskNames->print("P2P_out", "%d, %lld, %lld, %d, %lld, %lld, %d, %lld, %lld, %lld, %lld, %d\n",
tree->getParticleGroup(idxGroup)->getNumberOfLeavesInBlock(),
tree->getParticleGroup(idxGroup)->getSizeOfInterval(),
tree->getParticleGroup(idxGroup)->getNbParticlesInGroup(),
tree->getParticleGroup(interactionid)->getNumberOfLeavesInBlock(), tree->getParticleGroup(interactionid)->getNumberOfLeavesInBlock(),
tree->getParticleGroup(interactionid)->getSizeOfInterval(), tree->getParticleGroup(interactionid)->getSizeOfInterval(),
tree->getParticleGroup(interactionid)->getNbParticlesInGroup(), tree->getParticleGroup(interactionid)->getNbParticlesInGroup(),
outsideInteractions->size(), outsideInteractions->size(),
tree->getParticleGroup(interactionid)->getStartingIndex(), tree->getParticleGroup(interactionid)->getStartingIndex(),
tree->getParticleGroup(interactionid)->getEndingIndex(), tree->getParticleGroup(interactionid)->getEndingIndex(),
...@@ -38,25 +38,6 @@ using namespace std; ...@@ -38,25 +38,6 @@ using namespace std;
#include "../../Src/Files/FFmaGenericLoader.hpp" #include "../../Src/Files/FFmaGenericLoader.hpp"
#include "../../Src/Core/FFmmAlgorithm.hpp" #include "../../Src/Core/FFmmAlgorithm.hpp"
std::vector<MortonIndex> getMortonIndex(const char* const mapping_filename);
void timeAverage(int mpi_rank, int nproc, double elapsedTime);
int main(int argc, char* argv[]){
setenv("STARPU_NCPU","1",1);
const FParameterNames LocalOptionBlocSize {
{"-bs"},
"The size of the block of the blocked tree"
const FParameterNames Mapping {
{"-map"} ,
"mapping  \\o/."
FHelpDescribeAndExit(argc, argv, "Test the blocked tree by counting the particles.",
FParameterDefinitions::OctreeHeight, FParameterDefinitions::NbParticles,
FParameterDefinitions::OctreeSubHeight, FParameterDefinitions::InputFile, LocalOptionBlocSize, Mapping);
//int provided = 0;
//MPI_Init_thread(&argc,&argv, MPI_THREAD_SERIALIZED, &provided);
typedef double FReal; typedef double FReal;
// Initialize the types // Initialize the types
...@@ -81,6 +62,33 @@ int main(int argc, char* argv[]){ ...@@ -81,6 +62,33 @@ int main(int argc, char* argv[]){
// FFmmAlgorithmTask FFmmAlgorithmThread // FFmmAlgorithmTask FFmmAlgorithmThread
typedef FFmmAlgorithm<OctreeClass, CellClass, ContainerClass, KernelClass, LeafClass > FmmClass; typedef FFmmAlgorithm<OctreeClass, CellClass, ContainerClass, KernelClass, LeafClass > FmmClass;
#define LOAD_FILE
#ifndef LOAD_FILE
typedef FRandomLoader<FReal> LoaderClass;
#else
typedef FFmaGenericLoader<FReal> LoaderClass;
#endif
void sortParticle(FPoint<FReal> * allParticlesToSort, int treeHeight, int groupSize, vector<vector<int>> & sizeForEachGroup, LoaderClass& loader, int nproc);
void createNodeRepartition(std::vector<MortonIndex> distributedMortonIndex, std::vector<std::vector<std::vector<MortonIndex>>>& nodeRepartition, int nproc, int treeHeight);
{"-bs"},
{"-map"} ,
"mapping  \\o/."
//int provided = 0;
// Get params // Get params
const int NbLevels = FParameters::getValue(argc,argv,FParameterDefinitions::OctreeHeight.options, 5); const int NbLevels = FParameters::getValue(argc,argv,FParameterDefinitions::OctreeHeight.options, 5);
...@@ -91,14 +99,13 @@ int main(int argc, char* argv[]){ ...@@ -91,14 +99,13 @@ int main(int argc, char* argv[]){
#ifndef STARPU_USE_MPI #ifndef STARPU_USE_MPI
cout << "Pas de mpi -_-\" " << endl; cout << "Pas de mpi -_-\" " << endl;
#endif #endif
#define LOAD_FILE
#ifndef LOAD_FILE #ifndef LOAD_FILE
const FSize NbParticles = FParameters::getValue(argc,argv,FParameterDefinitions::NbParticles.options, FSize(20)); const FSize NbParticles = FParameters::getValue(argc,argv,FParameterDefinitions::NbParticles.options, FSize(20));
FRandomLoader<FReal> loader(NbParticles, 1.0, FPoint<FReal>(0,0,0), 0); LoaderClass loader(NbParticles, 1.0, FPoint<FReal>(0,0,0), 0);
#else #else
// Load the particles // Load the particles
const char* const filename = FParameters::getStr(argc,argv,FParameterDefinitions::InputFile.options, "../Data/test20k.fma"); const char* const filename = FParameters::getStr(argc,argv,FParameterDefinitions::InputFile.options, "../Data/test20k.fma");
FFmaGenericLoader<FReal> loader(filename); LoaderClass loader(filename);
#endif #endif
FAssertLF(loader.isOpen()); FAssertLF(loader.isOpen());
...@@ -106,12 +113,18 @@ int main(int argc, char* argv[]){ ...@@ -106,12 +113,18 @@ int main(int argc, char* argv[]){
OctreeClass tree(NbLevels, FParameters::getValue(argc,argv,FParameterDefinitions::OctreeSubHeight.options, 2), OctreeClass tree(NbLevels, FParameters::getValue(argc,argv,FParameterDefinitions::OctreeSubHeight.options, 2),
loader.getBoxWidth(), loader.getCenterOfBox()); loader.getBoxWidth(), loader.getCenterOfBox());
FTestParticleContainer<FReal> allParticles; FTestParticleContainer<FReal> allParticles;
FPoint<FReal> allParticlesToSort[loader.getNumberOfParticles()];
for(FSize idxPart = 0 ; idxPart < loader.getNumberOfParticles() ; ++idxPart){ for(FSize idxPart = 0 ; idxPart < loader.getNumberOfParticles() ; ++idxPart){
FPoint<FReal> particlePosition; loader.fillParticle(&allParticlesToSort[idxPart]);//Same with file or not
loader.fillParticle(&particlePosition);//Same with file or not
allParticles.push(particlePosition);
tree.insert(particlePosition);
vector<vector<int>> sizeForEachGroup;
sortParticle(allParticlesToSort, NbLevels, groupSize, sizeForEachGroup, loader, 8);
allParticles.push(allParticlesToSort[idxPart]);
tree.insert(allParticlesToSort[idxPart]);
// Put the data into the tree // Put the data into the tree
//GroupOctreeClass groupedTree(NbLevels, groupSize, &tree); //GroupOctreeClass groupedTree(NbLevels, groupSize, &tree);
...@@ -242,3 +255,136 @@ void timeAverage(int mpi_rank, int nproc, double elapsedTime) ...@@ -242,3 +255,136 @@ void timeAverage(int mpi_rank, int nproc, double elapsedTime)
MPI_Send(&elapsedTime, 1, MPI_DOUBLE, 0, 0, MPI_COMM_WORLD); MPI_Send(&elapsedTime, 1, MPI_DOUBLE, 0, 0, MPI_COMM_WORLD);
void sortParticle(FPoint<FReal> * allParticles, int treeHeight, int groupSize, vector<vector<int>> & sizeForEachGroup, LoaderClass& loader, int nproc)
//Structure pour trier
struct ParticleSortingStruct{
FPoint<FReal> position;
MortonIndex mindex;
// Création d'un tableau de la structure pour trier puis remplissage du tableau
const int nbParticles = loader.getNumberOfParticles();
ParticleSortingStruct* particlesToSort = new ParticleSortingStruct[nbParticles];
for(FSize idxPart = 0 ; idxPart < nbParticles ; ++idxPart){
const FTreeCoordinate host = FCoordinateComputer::GetCoordinateFromPosition<FReal>(loader.getCenterOfBox(), loader.getBoxWidth(),
treeHeight,
const MortonIndex particleIndex = host.getMortonIndex(treeHeight-1);
particlesToSort[idxPart].mindex = particleIndex;
particlesToSort[idxPart].position = allParticles[idxPart];
//Trie du nouveau tableau
FQuickSort<ParticleSortingStruct, FSize>::QsOmp(particlesToSort, nbParticles, [](const ParticleSortingStruct& v1, const ParticleSortingStruct& v2){
return v1.mindex <= v2.mindex;
//Replace tout dans l'ordre dans le tableau d'origine
allParticles[idxPart] = particlesToSort[idxPart].position;
//Compte le nombre de feuilles
sizeForEachGroup.resize(treeHeight);
MortonIndex previousLeaf = -1;
int countLeaf = 0;
if(particlesToSort[idxPart].mindex != previousLeaf)
previousLeaf = particlesToSort[idxPart].mindex;
++countLeaf;
//Réparti les feuilles par process mpi
int bonusGroup = countLeaf%nproc; //Number of node in the bonus group
int leafPerNode = (int)floor((double)countLeaf / (double)nproc);
//Calcul de la taille des groupes au niveau des feuilles
for(int processId = 0; processId < nproc; ++processId)
int size_last;
int countGroup;
int leafOnProcess = leafPerNode;
if(processId < bonusGroup)
leafOnProcess = leafPerNode+1;
size_last = leafOnProcess%groupSize;
countGroup = (leafOnProcess - size_last)/groupSize;
for(int i = 0; i < countGroup; ++i)
sizeForEachGroup[treeHeight-1].push_back(groupSize);
sizeForEachGroup[treeHeight-1].push_back(size_last);
std::vector<MortonIndex> distributedMortonIndex;
//Calcul du working interval au niveau des feuilles
previousLeaf = -1;
countLeaf = 0;
int processId = 0;
distributedMortonIndex.push_back(previousLeaf);
++countLeaf;
if((countLeaf == leafPerNode+1 && processId < bonusGroup) || (countLeaf == leafPerNode && processId >= bonusGroup))
distributedMortonIndex.push_back(particlesToSort[nbParticles - 1].mindex);
//Calcul des working interval à chaque niveau
std::vector<std::vector<std::vector<MortonIndex>>> nodeRepartition;
createNodeRepartition(distributedMortonIndex, nodeRepartition, nproc, treeHeight);
//Pour chaque niveau calcul de la taille des groupe
for(int idxLevel = treeHeight - 2; idxLevel > 0; --idxLevel)
processId = 0;
int countParticleInTheGroup = 0;
MortonIndex previousMortonCell = -1;
for(int idxPart = 0; idxPart < nbParticles; ++idxPart)
MortonIndex mortonCell = particlesToSort[idxPart].mindex >> 3*(treeHeight - idxLevel);
if(nodeRepartition[idxLevel][processId][1] <= mortonCell) //Si l'indice est dans le working interval
if(mortonCell != previousMortonCell) //Si c'est un nouvelle indice
++countParticleInTheGroup; //On le compte dans le groupe
previousMortonCell = mortonCell;
if(countParticleInTheGroup == groupSize) //Si le groupe est plein on ajoute le compte
sizeForEachGroup[idxLevel].push_back(groupSize);
else //Si l'on change d'interval de process on ajoute ce que l'on a compté
sizeForEachGroup[idxLevel].push_back(countParticleInTheGroup);
countParticleInTheGroup = 1;
++processId;
void createNodeRepartition(std::vector<MortonIndex> distributedMortonIndex, std::vector<std::vector<std::vector<MortonIndex>>>& nodeRepartition, int nproc, int treeHeight) {
nodeRepartition.resize(treeHeight, std::vector<std::vector<MortonIndex>>(nproc, std::vector<MortonIndex>(2)));
for(int node_id = 0; node_id < nproc; ++node_id){
nodeRepartition[treeHeight-1][node_id][0] = distributedMortonIndex[node_id*2];
nodeRepartition[treeHeight-1][node_id][1] = distributedMortonIndex[node_id*2+1];
for(int idxLevel = treeHeight - 2; idxLevel >= 0 ; --idxLevel){
nodeRepartition[idxLevel][0][0] = nodeRepartition[idxLevel+1][0][0] >> 3;
nodeRepartition[idxLevel][0][1] = nodeRepartition[idxLevel+1][0][1] >> 3;
for(int node_id = 1; node_id < nproc; ++node_id){
nodeRepartition[idxLevel][node_id][0] = FMath::Max(nodeRepartition[idxLevel+1][node_id][0] >> 3, nodeRepartition[idxLevel][node_id-1][0]+1); //Berenger phd :)
nodeRepartition[idxLevel][node_id][1] = nodeRepartition[idxLevel+1][node_id][1] >> 3;
