Commit 7318012f authored by COULAUD Olivier's avatar COULAUD Olivier
remove ../../Src/ include
parent 1377e389
...@@ -13,13 +13,14 @@ version 1.1 ...@@ -13,13 +13,14 @@ version 1.1
- Adaptive FMM is available in shared memory paradigm (OpenMP and StarPU) - Adaptive FMM is available in shared memory paradigm (OpenMP and StarPU)
- scoped enum (FParticleTYpe (target,source), OPM4_Priorities, ...) is used - scoped enum (FParticleTYpe (target,source), OPM4_Priorities, ...) is used
- StarPU works with Duplicated and Let trees with MPI (STF approach) - StarPU works with Duplicated and Let trees with MPI (STF approach)
- Remove all warnings with gcc 7.2 - Remove all warnings with gcc 7.2 still some with 8.1
- std::complex is used for equispaced points interpolation - std::complex is used for equispaced points interpolation
- Fix bug with intel compiler and target/source - Fix bug with intel compiler and target/source
- Improvement in CmakeLists - FUSE is working again - - Improvement in CmakeLists - FUSE is working again -
- Compile with Intel and CLang (with a lot of warnings) - Compile with Intel and CLang (with a lot of warnings)
- Now morse_cmake is a git submodule - Now morse_cmake is a git submodule
- Fix several bugs in pseudo-periodic algorithms (sequential and parallel) - Fix several bugs in pseudo-periodic algorithms (sequential and parallel)
- Improve install step
1.5 1.5
...@@ -24,23 +24,23 @@ ...@@ -24,23 +24,23 @@
#include <stdlib.h> #include <stdlib.h>
#include <time.h> #include <time.h>
#include "../../Src/Utils/FTic.hpp" #include "Utils/FTic.hpp"
#include "../../Src/Utils/FMath.hpp" #include "Utils/FMath.hpp"
#include "../../Src/Utils/FParameters.hpp" #include "Utils/FParameters.hpp"
#include "../../Src/Containers/FVector.hpp" #include "Containers/FVector.hpp"
#include "../../Src/Utils/FAssert.hpp" #include "Utils/FAssert.hpp"
#include "../../Src/Utils/FPoint.hpp" #include "Utils/FPoint.hpp"
#include "../../Src/Kernels/Chebyshev/FChebInterpolator.hpp" #include "Kernels/Chebyshev/FChebInterpolator.hpp"
#include "../../Src/Kernels/Interpolation/FInterpMatrixKernel.hpp" #include "Kernels/Interpolation/FInterpMatrixKernel.hpp"
#include "../../Src/Components/FSimpleLeaf.hpp" #include "Components/FSimpleLeaf.hpp"
#include "../../Src/Kernels/P2P/FP2PParticleContainer.hpp" #include "Kernels/P2P/FP2PParticleContainer.hpp"
#include "../../Src/Utils/FParameterNames.hpp" #include "Utils/FParameterNames.hpp"
template <class FReal> template <class FReal>
...@@ -7,11 +7,11 @@ ...@@ -7,11 +7,11 @@
#include <string> #include <string>
#include "../../Src/Utils/FGlobal.hpp" #include "Utils/FGlobal.hpp"
#include "../../Src/Containers/FTreeCoordinate.hpp" #include "Containers/FTreeCoordinate.hpp"
* In this file we show the morton indexed for each boxes * In this file we show the morton indexed for each boxes
...@@ -5,24 +5,24 @@ ...@@ -5,24 +5,24 @@
#include <cstdio> #include <cstdio>
#include <cstdlib> #include <cstdlib>
#include "../../Src/Containers/FOctree.hpp" #include "Containers/FOctree.hpp"
#include "../../Src/Components/FBasicParticleContainer.hpp" #include "Components/FBasicParticleContainer.hpp"
#include "../../Src/Components/FBasicCell.hpp" #include "Components/FBasicCell.hpp"
#include "../../Src/Arranger/FBasicParticleContainerIndexedMover.hpp" #include "Arranger/FBasicParticleContainerIndexedMover.hpp"
#include "../../Src/Kernels/P2P/FP2PParticleContainerIndexed.hpp" #include "Kernels/P2P/FP2PParticleContainerIndexed.hpp"
#include "../../Src/Arranger/FOctreeArranger.hpp" #include "Arranger/FOctreeArranger.hpp"
// Simply create particles and try the kernels // Simply create particles and try the kernels
