Commit 5fb7f826 authored by BRAMAS Berenger's avatar BRAMAS Berenger
Let the Starpu threaded version use real adresse of the data block (as in the...
Let the Starpu threaded version use real adresse of the data block (as in the starpu mpi) but NOT as the omp for now
parent 25601461
...@@ -220,7 +220,8 @@ protected: ...@@ -220,7 +220,8 @@ protected:
for(int idxGroup = 0 ; idxGroup < tree->getNbCellGroupAtLevel(idxLevel) ; ++idxGroup){ for(int idxGroup = 0 ; idxGroup < tree->getNbCellGroupAtLevel(idxLevel) ; ++idxGroup){
const CellContainerClass* currentCells = tree->getCellGroup(idxLevel, idxGroup); const CellContainerClass* currentCells = tree->getCellGroup(idxLevel, idxGroup);
starpu_variable_data_register(&handles[idxLevel][idxGroup], 0, (uintptr_t)currentCells, sizeof(*currentCells)); // TODO starpu_variable_data_register(&handles[idxLevel][idxGroup], 0,
(uintptr_t)currentCells->getRawBuffer(), currentCells->getBufferSizeInByte());
...@@ -228,7 +229,8 @@ protected: ...@@ -228,7 +229,8 @@ protected:
handles[idxLevel].resize(tree->getNbParticleGroup()); handles[idxLevel].resize(tree->getNbParticleGroup());
for(int idxGroup = 0 ; idxGroup < tree->getNbParticleGroup() ; ++idxGroup){ for(int idxGroup = 0 ; idxGroup < tree->getNbParticleGroup() ; ++idxGroup){
ParticleGroupClass* containers = tree->getParticleGroup(idxGroup); ParticleGroupClass* containers = tree->getParticleGroup(idxGroup);
starpu_variable_data_register(&handles[idxLevel][idxGroup], 0, (uintptr_t)containers, sizeof(*containers)); // TODO starpu_variable_data_register(&handles[idxLevel][idxGroup], 0,
(uintptr_t)containers->getRawBuffer(), containers->getBufferSizeInByte());
...@@ -428,12 +430,14 @@ protected: ...@@ -428,12 +430,14 @@ protected:
static void bottomPassCallback(void *buffers[], void *cl_arg){ static void bottomPassCallback(void *buffers[], void *cl_arg){
CellContainerClass* leafCells = reinterpret_cast<CellContainerClass*>(STARPU_VARIABLE_GET_PTR(buffers[0])); CellContainerClass leafCells((unsigned char*)STARPU_VARIABLE_GET_PTR(buffers[0]),
ParticleGroupClass* containers = reinterpret_cast<ParticleGroupClass*>(STARPU_VARIABLE_GET_PTR(buffers[1])); STARPU_VARIABLE_GET_ELEMSIZE(buffers[0]));
ParticleGroupClass containers((unsigned char*)STARPU_VARIABLE_GET_PTR(buffers[1]),
STARPU_VARIABLE_GET_ELEMSIZE(buffers[1]));
ThisClass* worker = nullptr; ThisClass* worker = nullptr;
starpu_codelet_unpack_args(cl_arg, &worker); starpu_codelet_unpack_args(cl_arg, &worker);
worker->bottomPassPerform(leafCells, containers); worker->bottomPassPerform(&leafCells, &containers);
void bottomPassPerform(CellContainerClass* leafCells, ParticleGroupClass* containers){ void bottomPassPerform(CellContainerClass* leafCells, ParticleGroupClass* containers){
...@@ -506,7 +510,8 @@ protected: ...@@ -506,7 +510,8 @@ protected:
static void upwardPassCallback(void *buffers[], void *cl_arg){ static void upwardPassCallback(void *buffers[], void *cl_arg){
CellContainerClass* currentCells = reinterpret_cast<CellContainerClass*>(STARPU_VARIABLE_GET_PTR(buffers[0])); CellContainerClass currentCells((unsigned char*)STARPU_VARIABLE_GET_PTR(buffers[0]),
int nbSubCellGroups = 0; int nbSubCellGroups = 0;
...@@ -516,10 +521,15 @@ protected: ...@@ -516,10 +521,15 @@ protected:
CellContainerClass* subCellGroups[9]; CellContainerClass* subCellGroups[9];
memset(subCellGroups, 0, 9*sizeof(CellContainerClass*)); memset(subCellGroups, 0, 9*sizeof(CellContainerClass*));
for(int idxSubGroup = 0; idxSubGroup < nbSubCellGroups ; ++idxSubGroup){ for(int idxSubGroup = 0; idxSubGroup < nbSubCellGroups ; ++idxSubGroup){
subCellGroups[idxSubGroup] = reinterpret_cast<CellContainerClass*>(STARPU_VARIABLE_GET_PTR(buffers[idxSubGroup+1])); subCellGroups[idxSubGroup] = new CellContainerClass((unsigned char*)STARPU_VARIABLE_GET_PTR(buffers[idxSubGroup+1]),
STARPU_VARIABLE_GET_ELEMSIZE(buffers[idxSubGroup+1]));
worker->upwardPassPerform(currentCells, subCellGroups, nbSubCellGroups, idxLevel); worker->upwardPassPerform(&currentCells, subCellGroups, nbSubCellGroups, idxLevel);
delete subCellGroups[idxSubGroup];
void upwardPassPerform(CellContainerClass*const currentCells, void upwardPassPerform(CellContainerClass*const currentCells,
...@@ -593,13 +603,14 @@ protected: ...@@ -593,13 +603,14 @@ protected:
static void transferInPassCallback(void *buffers[], void *cl_arg){ static void transferInPassCallback(void *buffers[], void *cl_arg){
int idxLevel = 0; int idxLevel = 0;
starpu_codelet_unpack_args(cl_arg, &worker, &idxLevel); starpu_codelet_unpack_args(cl_arg, &worker, &idxLevel);
worker->transferInPassPerform(currentCells, idxLevel); worker->transferInPassPerform(&currentCells, idxLevel);
void transferInPassPerform(CellContainerClass*const currentCells, const int idxLevel){ void transferInPassPerform(CellContainerClass*const currentCells, const int idxLevel){
...@@ -638,15 +649,17 @@ protected: ...@@ -638,15 +649,17 @@ protected:
static void transferInoutPassCallback(void *buffers[], void *cl_arg){ static void transferInoutPassCallback(void *buffers[], void *cl_arg){
CellContainerClass* externalCells = reinterpret_cast<CellContainerClass*>(STARPU_VARIABLE_GET_PTR(buffers[1])); STARPU_VARIABLE_GET_ELEMSIZE(buffers[0]));
CellContainerClass externalCells((unsigned char*)STARPU_VARIABLE_GET_PTR(buffers[1]),
const std::vector<OutOfBlockInteraction>* outsideInteractions; const std::vector<OutOfBlockInteraction>* outsideInteractions;
starpu_codelet_unpack_args(cl_arg, &worker, &idxLevel, &outsideInteractions); starpu_codelet_unpack_args(cl_arg, &worker, &idxLevel, &outsideInteractions);
worker->transferInoutPassPerform(currentCells, externalCells, idxLevel, outsideInteractions); worker->transferInoutPassPerform(&currentCells, &externalCells, idxLevel, outsideInteractions);
...@@ -731,7 +744,8 @@ protected: ...@@ -731,7 +744,8 @@ protected:
static void downardPassCallback(void *buffers[], void *cl_arg){ static void downardPassCallback(void *buffers[], void *cl_arg){
...@@ -741,10 +755,15 @@ protected: ...@@ -741,10 +755,15 @@ protected:
worker->downardPassPerform(currentCells, subCellGroups, nbSubCellGroups, idxLevel); worker->downardPassPerform(&currentCells, subCellGroups, nbSubCellGroups, idxLevel);
void downardPassPerform(CellContainerClass*const currentCells, void downardPassPerform(CellContainerClass*const currentCells,
...@@ -814,12 +833,13 @@ protected: ...@@ -814,12 +833,13 @@ protected:
static void directInPassCallback(void *buffers[], void *cl_arg){ static void directInPassCallback(void *buffers[], void *cl_arg){
ParticleGroupClass* containers = reinterpret_cast<ParticleGroupClass*>(STARPU_VARIABLE_GET_PTR(buffers[0])); ParticleGroupClass containers((unsigned char*)STARPU_VARIABLE_GET_PTR(buffers[0]),
worker->directInPassPerform(containers); worker->directInPassPerform(&containers);
void directInPassPerform(ParticleGroupClass* containers){ void directInPassPerform(ParticleGroupClass* containers){
...@@ -857,14 +877,16 @@ protected: ...@@ -857,14 +877,16 @@ protected:
static void directInoutPassCallback(void *buffers[], void *cl_arg){ static void directInoutPassCallback(void *buffers[], void *cl_arg){
ParticleGroupClass* externalContainers = reinterpret_cast<ParticleGroupClass*>(STARPU_VARIABLE_GET_PTR(buffers[1])); STARPU_VARIABLE_GET_ELEMSIZE(buffers[0]));
ParticleGroupClass externalContainers((unsigned char*)STARPU_VARIABLE_GET_PTR(buffers[1]),
const std::vector<OutOfBlockInteraction>* outsideInteractions = nullptr; const std::vector<OutOfBlockInteraction>* outsideInteractions = nullptr;
starpu_codelet_unpack_args(cl_arg, &worker, &outsideInteractions); starpu_codelet_unpack_args(cl_arg, &worker, &outsideInteractions);
worker->directInoutPassPerform(containers, externalContainers, outsideInteractions); worker->directInoutPassPerform(&containers, &externalContainers, outsideInteractions);
void directInoutPassPerform(ParticleGroupClass* containers, ParticleGroupClass* containersOther, void directInoutPassPerform(ParticleGroupClass* containers, ParticleGroupClass* containersOther,
...@@ -907,12 +929,14 @@ protected: ...@@ -907,12 +929,14 @@ protected:
static void mergePassCallback(void *buffers[], void *cl_arg){ static void mergePassCallback(void *buffers[], void *cl_arg){
worker->mergePassPerform(leafCells, containers); worker->mergePassPerform(&leafCells, &containers);
void mergePassPerform(CellContainerClass* leafCells, ParticleGroupClass* containers){ void mergePassPerform(CellContainerClass* leafCells, ParticleGroupClass* containers){
...@@ -733,7 +733,7 @@ protected: ...@@ -733,7 +733,7 @@ protected:
starpu_variable_data_register(&handles[idxLevel][idxGroup], 0, starpu_variable_data_register(&handles[idxLevel][idxGroup], 0,
(uintptr_t)currentCells->getRawBuffer(), currentCells->getBufferSizeInByte()); // TODO (uintptr_t)currentCells->getRawBuffer(), currentCells->getBufferSizeInByte());
...@@ -742,7 +742,7 @@ protected: ...@@ -742,7 +742,7 @@ protected:
(uintptr_t)containers->getRawBuffer(), containers->getBufferSizeInByte()); // TODO (uintptr_t)containers->getRawBuffer(), containers->getBufferSizeInByte());
