Commit 58c7d39e authored by Berenger Bramas's avatar Berenger Bramas
make it compile
parent 98d24a41
...@@ -124,8 +124,7 @@ void unifRandomPointsInBall(const FSize N, const FReal R, FReal* points) { ...@@ -124,8 +124,7 @@ void unifRandomPointsInBall(const FSize N, const FReal R, FReal* points) {
* \param points array of size 4*N and stores data as follow x,y,z,0,x,y,z,0.... * \param points array of size 4*N and stores data as follow x,y,z,0,x,y,z,0....
template <class FReal> template <class FReal>
void nonunifRandomPointsOnElipsoid(const FSize N, const FReal& a, const FReal& b, void nonunifRandomPointsOnElipsoid(const FSize N, const FReal& a, const FReal& b, const FReal& c, FReal* points)
#ifdef SCALFMM_OLD_ELLIPSOID #ifdef SCALFMM_OLD_ELLIPSOID
FReal u, v, cosu; FReal u, v, cosu;
...@@ -193,6 +192,11 @@ void nonunifRandomPointsOnElipsoid(const FSize N, const FReal& a, const FReal& b ...@@ -193,6 +192,11 @@ void nonunifRandomPointsOnElipsoid(const FSize N, const FReal& a, const FReal& b
void nonunifRandomPointsOnElipsoid(const FSize N, const FReal& a, const FReal& b, FReal* points){
nonunifRandomPointsOnElipsoid(N, a, b, FReal(1), points);
* \brief Generate N points uniformly distributed on the ellipsoid of aspect ratio a:a:c * \brief Generate N points uniformly distributed on the ellipsoid of aspect ratio a:a:c
...@@ -65,7 +65,7 @@ int main(int argc, char* argv[]){ ...@@ -65,7 +65,7 @@ int main(int argc, char* argv[]){
#ifdef SCALFMM_USE_STARPU #ifdef SCALFMM_USE_STARPU
typedef FStarPUAllCpuCapacities<FTestKernels< GroupCellClass, GroupContainerClass >> GroupKernelClass; typedef FStarPUAllCpuCapacities<FTestKernels< GroupCellClass, GroupContainerClass >> GroupKernelClass;
typedef FStarPUCpuWrapper<typename GroupOctreeClass::CellGroupClass, GroupCellClass, GroupKernelClass, typename GroupOctreeClass::ParticleGroupClass, GroupContainerClass> GroupCpuWrapper; typedef FStarPUCpuWrapper<typename GroupOctreeClass::CellGroupClass, GroupCellClass, GroupKernelClass, typename GroupOctreeClass::ParticleGroupClass, GroupContainerClass> GroupCpuWrapper;
typedef FGroupTaskStarPUAlgorithm<GroupOctreeClass, typename GroupOctreeClass::CellGroupClass, GroupKernelClass, typename GroupOctreeClass::ParticleGroupClass, GroupCpuWrapper > GroupAlgorithm; typedef FGroupTaskStarPUAlgorithm<GroupOctreeClass, typename GroupOctreeClass::CellGroupClass, GroupKernelClass, typename GroupOctreeClass::ParticleGroupClass, GroupCpuWrapper, GroupContainerClass > GroupAlgorithm;
#elif defined(SCALFMM_USE_OMP4) #elif defined(SCALFMM_USE_OMP4)
typedef FTestKernels< GroupCellClass, GroupContainerClass > GroupKernelClass; typedef FTestKernels< GroupCellClass, GroupContainerClass > GroupKernelClass;
typedef FGroupTaskDepAlgorithm<GroupOctreeClass, typename GroupOctreeClass::CellGroupClass, GroupCellClass, typedef FGroupTaskDepAlgorithm<GroupOctreeClass, typename GroupOctreeClass::CellGroupClass, GroupCellClass,
...@@ -193,7 +193,7 @@ int main(int argc, char* argv[]){ ...@@ -193,7 +193,7 @@ int main(int argc, char* argv[]){
...@@ -71,7 +71,7 @@ int main(int argc, char* argv[]){ ...@@ -71,7 +71,7 @@ int main(int argc, char* argv[]){
typedef FStarPUAllCpuCapacities<FChebSymKernel<FReal,GroupCellClass,GroupContainerClass,MatrixKernelClass,ORDER>> GroupKernelClass; typedef FStarPUAllCpuCapacities<FChebSymKernel<FReal,GroupCellClass,GroupContainerClass,MatrixKernelClass,ORDER>> GroupKernelClass;
typedef FChebSymKernel<FReal,GroupCellClass,GroupContainerClass,MatrixKernelClass,ORDER> GroupKernelClass; typedef FChebSymKernel<FReal,GroupCellClass,GroupContainerClass,MatrixKernelClass,ORDER> GroupKernelClass;
...@@ -74,7 +74,7 @@ int main(int argc, char* argv[]){ ...@@ -74,7 +74,7 @@ int main(int argc, char* argv[]){
...@@ -101,10 +101,10 @@ int main(int argc, char* argv[]){ ...@@ -101,10 +101,10 @@ int main(int argc, char* argv[]){
#ifdef RANDOM_PARTICLES #ifdef RANDOM_PARTICLES
setSeed(1); setSeed(1);
FReal * tmpParticles = new FReal[4*loader.getNumberOfParticles()]; FReal * tmpParticles = new FReal[4*loader.getNumberOfParticles()];
if(FParameters::existParameter(argc, argv, "-ellipsoid")) { if(FParameters::existParameter(argc, argv, "-ellipsoid")) {
nonunifRandomPointsOnElipsoid(loader.getNumberOfParticles(), loader.getBoxWidth()/2, loader.getBoxWidth()/4, tmpParticles); nonunifRandomPointsOnElipsoid(loader.getNumberOfParticles(), loader.getBoxWidth()/2, loader.getBoxWidth()/4, tmpParticles);
else if(FParameters::existParameter(argc, argv, "-plummer")) { else if(FParameters::existParameter(argc, argv, "-plummer")) {
//The M argument is not used in the algorithm of the plummer distribution //The M argument is not used in the algorithm of the plummer distribution
unifRandomPlummer(loader.getNumberOfParticles(), loader.getBoxWidth()/2, tmpParticles) ; unifRandomPlummer(loader.getNumberOfParticles(), loader.getBoxWidth()/2, tmpParticles) ;
...@@ -28,7 +28,7 @@ using namespace std; ...@@ -28,7 +28,7 @@ using namespace std;
#include "../../Src/GroupTree/Core/FP2PGroupParticleContainer.hpp" #include "../../Src/GroupTree/Core/FP2PGroupParticleContainer.hpp"
#include "../../Src/GroupTree/Core/FGroupTaskAlgorithm.hpp" #include "../../Src/GroupTree/Core/FGroupTaskAlgorithm.hpp"
#include "../../Src/BalanceTree/FLeafBalance.hpp" #include "../../Src/Utils/FLeafBalance.hpp"
#include "../../Src/Utils/FParameterNames.hpp" #include "../../Src/Utils/FParameterNames.hpp"
...@@ -34,7 +34,7 @@ using namespace std; ...@@ -34,7 +34,7 @@ using namespace std;
#include "../../Src/Kernels/Chebyshev/FChebCell.hpp" //For validation #include "../../Src/Kernels/Chebyshev/FChebCell.hpp" //For validation
#include "../../Src/Core/FFmmAlgorithm.hpp" //For validation #include "../../Src/Core/FFmmAlgorithm.hpp" //For validation
...@@ -36,7 +36,7 @@ using namespace std; ...@@ -36,7 +36,7 @@ using namespace std;
...@@ -57,7 +57,7 @@ int main(int argc, char* argv[]){ ...@@ -57,7 +57,7 @@ int main(int argc, char* argv[]){
typedef FStarPUAllCpuCapacities<FRotationKernel< FReal, GroupCellClass, GroupContainerClass , P>> GroupKernelClass; typedef FStarPUAllCpuCapacities<FRotationKernel< FReal, GroupCellClass, GroupContainerClass , P>> GroupKernelClass;
typedef FRotationKernel< FReal, GroupCellClass, GroupContainerClass , P> GroupKernelClass; typedef FRotationKernel< FReal, GroupCellClass, GroupContainerClass , P> GroupKernelClass;
...@@ -619,7 +619,7 @@ struct RunContainer{ ...@@ -619,7 +619,7 @@ struct RunContainer{
if(FParameters::existParameter(argc, argv, LocalOptionGroupStarPU.options)){ if(FParameters::existParameter(argc, argv, LocalOptionGroupStarPU.options)){
typedef FStarPUAllCpuCapacities<FRotationKernel<FReal,GroupCellClass,GroupContainerClass,ORDER>> GroupKernelClass; typedef FStarPUAllCpuCapacities<FRotationKernel<FReal,GroupCellClass,GroupContainerClass,ORDER>> GroupKernelClass;
std::cout << "Using FGroupTaskStarPUAlgorithm" << std::endl; std::cout << "Using FGroupTaskStarPUAlgorithm" << std::endl;
GroupKernelClass groupkernel(NbLevels, loader.getBoxWidth(), loader.getCenterOfBox()); GroupKernelClass groupkernel(NbLevels, loader.getBoxWidth(), loader.getCenterOfBox());
GroupAlgorithm groupalgo(&groupedTree,&groupkernel); GroupAlgorithm groupalgo(&groupedTree,&groupkernel);
typedef FStarPUAllCpuCapacities<FTaylorKernel< FReal,GroupCellClass, GroupContainerClass , P,1>> GroupKernelClass; typedef FStarPUAllCpuCapacities<FTaylorKernel< FReal,GroupCellClass, GroupContainerClass , P,1>> GroupKernelClass;
typedef FTaylorKernel< FReal,GroupCellClass, GroupContainerClass , P,1> GroupKernelClass; typedef FTaylorKernel< FReal,GroupCellClass, GroupContainerClass , P,1> GroupKernelClass;
...@@ -107,7 +107,7 @@ int main(int argc, char* argv[]){ ...@@ -107,7 +107,7 @@ int main(int argc, char* argv[]){
typedef FStarPUAllCpuCapacities<FUnifKernel<FReal,GroupCellClass,GroupContainerClass,MatrixKernelClass,ORDER>> GroupKernelClass; typedef FStarPUAllCpuCapacities<FUnifKernel<FReal,GroupCellClass,GroupContainerClass,MatrixKernelClass,ORDER>> GroupKernelClass;
// Get params // Get params
const int NbLevels = FParameters::getValue(argc,argv,FParameterDefinitions::OctreeHeight.options, 5); const int NbLevels = FParameters::getValue(argc,argv,FParameterDefinitions::OctreeHeight.options, 5);
...@@ -643,7 +643,7 @@ struct RunContainer{ ...@@ -643,7 +643,7 @@ struct RunContainer{
typedef FUnifKernel<FReal,GroupCellClass,GroupContainerClass,MatrixKernelClass,ORDER> GroupKernelClass; typedef FUnifKernel<FReal,GroupCellClass,GroupContainerClass,MatrixKernelClass,ORDER> GroupKernelClass;
