Commit 53f031e0 authored by COULAUD Olivier's avatar COULAUD Olivier
Remove non utf8 character
parent 23efff7b
...@@ -23,7 +23,10 @@ make ...@@ -23,7 +23,10 @@ make
# And access executables in scalfmm/Build/Tests/{Release,Debug}/..... # And access executables in scalfmm/Build/Tests/{Release,Debug}/.....
To compile with StarPU you can pass, as an example: To compile with StarPU you can pass, as an example:
cmake .. -DSCALFMM_USE_STARPU=ON -DSCALFMM_USE_CUDA=OFF -DSCALFMM_USE_OPENCL=OFF -DHWLOC_DIR=/home/berenger/Téléchargements/hwloc-1.10.0/install/ -DSTARPU_DIR=/home/berenger/Téléchargements/starpu-work/StarPU/installwithfxt cmake .. -DSCALFMM_USE_STARPU=ON -DSCALFMM_USE_CUDA=OFF -DSCALFMM_USE_OPENCL=OFF \
-DHWLOC_DIR=/home/berenger/Download/hwloc-1.10.0/install/ \
-DSTARPU_DIR=/home/berenger/Download/starpu-work/StarPU/installwithfxt
...@@ -58,14 +61,14 @@ Contact the developers at : scalfmm-public-support@lists.gforge.inria.fr ...@@ -58,14 +61,14 @@ Contact the developers at : scalfmm-public-support@lists.gforge.inria.fr
What inside : What inside :
× Src : The Core of Scalfmm is under the Src directory. Users should not need to modify the source. - Src : The Core of Scalfmm is under the Src directory. Users should not need to modify the source.
One can want to implement its own kernel or even its own parallelization whithout modifying the sources. One can want to implement its own kernel or even its own parallelization whithout modifying the sources.
× Data : example of particles distributions - Data : example of particles distributions
× Examples : examples of very common usage of Scalfmm - Examples : examples of very common usage of Scalfmm
× Doc : should contains the generated Doc - Doc : should contains the generated Doc
× UTests : contains some unit tests (it can be a good example to understand some features) - UTests : contains some unit tests (it can be a good example to understand some features)
× Tests : examples to know how to use scalfmm/put particles in the tree/iterate on the tree... - Tests : examples to know how to use scalfmm/put particles in the tree/iterate on the tree...
× Utils : some scripts to work with the data files. - Utils : some scripts to work with the data files.
