Commit 4e8ffdf0 authored by COULAUD Olivier's avatar COULAUD Olivier
Prepare version 1.3
parent 3d58908a
...@@ -6,10 +6,18 @@ Copyright (c) 2011-2014 Inria, All rights reserved. ...@@ -6,10 +6,18 @@ Copyright (c) 2011-2014 Inria, All rights reserved.
This file contains the main features as well as overviews of specific This file contains the main features as well as overviews of specific
bug fixes (and other actions) for each version of ScalFMM since bug fixes (and other actions) for each version of ScalFMM since
version 1.1 version 1.1
1.3-
- Add interpolation FMM based on uniform grid points.
- Add blocked version of the algorithm to increase the granularity (task-based approach)
1.2.1
- Bug fix : Support for huge MPI message in tree construction and Parallel QuickSort (count can be greater than Int32.MaxValue)
- Bug fix : Data sharing attribute clauses for omp in Core/FAlgorithmThreadProc.hpp
1.2
1.2-
- New FMA format to read/write particles - New FMA format to read/write particles
- Add examples repository - Add examples repository
...@@ -23,7 +31,3 @@ version 1.1 ...@@ -23,7 +31,3 @@ version 1.1
- Add SSE and AVX code for 1/r kernel - Add SSE and AVX code for 1/r kernel
- CMake improvements - CMake improvements
1.2.1
