Commit 3d69eea7 authored by Martin Khannouz's avatar Martin Khannouz Committed by Berenger Bramas
Re do jobs structure.
Now there is one script per algorithm and kernel.
The number of node and particles are handle before.
Plus, job scripts load envirronement from a script on plafrim.
parent fcb2fc68
#!/usr/bin/env bash
## name of job
#SBATCH -J explicit_50M_10N
#SBATCH -p special
## Resources: (nodes, procs, tasks, walltime, ... etc)
#SBATCH -N 10
#SBATCH -c 24
#SBATCH --time=00:30:00
# # output error message
#SBATCH -e explicit_chebyshev_50M_10_node%j.err
#SBATCH --mail-type=END,FAIL,TIME_LIMIT --mail-user=martin.khannouz@inria.fr
## modules to load for the job
module purge
module load slurm
module add compiler/gcc/5.3.0 tools/module_cat/1.0.0 intel/mkl/64/11.2/2016.0.0
. /home/mkhannou/spack/share/spack/setup-env.sh
spack load fftw
spack load hwloc
spack load openmpi
spack load starpu@svn-trunk+fxt
## variable for the job
export GROUP_SIZE=500
export TREE_HEIGHT=8
export NB_NODE=$SLURM_JOB_NUM_NODES
export STARPU_NCPU=24
export NB_PARTICLE_PER_NODE=5000000
export STARPU_FXT_PREFIX=$SLURM_JOB_ID
export FINAL_DIR="`pwd`/dir_$SLURM_JOB_ID"
export STARPU_COMM_STATS=1
$NUMACTL=numactl --interleave=all
mkdir $FINAL_DIR
echo "my jobID: " $SLURM_JOB_ID > $FINAL_DIR/stdout
echo "Model: cube" >> $FINAL_DIR/stdout
echo "Nb node: " $NB_NODE >> $FINAL_DIR/stdout
echo "Nb thread: " $STARPU_NCPU >> $FINAL_DIR/stdout
echo "Tree height: " $TREE_HEIGHT >> $FINAL_DIR/stdout
echo "Group size: " $GROUP_SIZE >> $FINAL_DIR/stdout
echo "Algorithm: explicit" >> $FINAL_DIR/stdout
echo "Particle per node: " $NB_PARTICLE_PER_NODE >> $FINAL_DIR/stdout
echo "Total particles: " $(($NB_PARTICLE_PER_NODE*$NB_NODE)) >> $FINAL_DIR/stdout
mpiexec -n $NB_NODE $NUMACTL ./Build/Tests/Release/testBlockedMpiChebyshev -nb $NB_PARTICLE_PER_NODE -bs $GROUP_SIZE -h $TREE_HEIGHT -no-validation >> $FINAL_DIR/stdout
#Create argument list for starpu_fxt_tool
cd $FINAL_DIR
list_fxt_file=`ls ../$STARPU_FXT_PREFIX*`
#Clean to only keep trace.rec
mkdir fxt
for i in $list_fxt_file; do
mv $i fxt
done
cd ..
##Move the result into a directory where all result goes
mv $FINAL_DIR jobs_result
#!/usr/bin/env bash
## name of job
#SBATCH -J explicit_50M_1N
#SBATCH -p defq
#SBATCH -N 1
#SBATCH -c 24
#SBATCH --time=02:00:00
module purge
module load slurm
spack load fftw
spack load hwloc
spack load openmpi
export NB_PARTICLE_PER_NODE=50000000
mkdir $FINAL_DIR
cd $FINAL_DIR
mkdir fxt
mv $i fxt
done
cd ..
#!/usr/bin/env bash
## name of job
#SBATCH -J explicit_50M_2N
#SBATCH -p court
#SBATCH -N 2
#SBATCH -c 24
#SBATCH --time=04:00:00
#SBATCH -e explicit_50M_2N_%j.err
module purge
module load slurm
spack load fftw
spack load hwloc
spack load openmpi
export NB_PARTICLE_PER_NODE=25000000
mkdir $FINAL_DIR
cd $FINAL_DIR
mkdir fxt
mv $i fxt
done
cd ..
#!/usr/bin/env bash
## name of job
#SBATCH -J explicit_50M_4N
#SBATCH -p court
#SBATCH -N 4
#SBATCH -c 24
module purge
module load slurm
spack load fftw
spack load hwloc
spack load openmpi
export NB_PARTICLE_PER_NODE=12500000
mkdir $FINAL_DIR
cd $FINAL_DIR
mkdir fxt
mv $i fxt
done
cd ..
#!/usr/bin/env bash #!/usr/bin/env bash
## name of job ## name of job
#SBATCH -J explicit_50M_8N #SBATCH -J explicit
#SBATCH -p special #SBATCH -p special
## Resources: (nodes, procs, tasks, walltime, ... etc) ## Resources: (nodes, procs, tasks, walltime, ... etc)
#SBATCH -N 8
#SBATCH -c 24 #SBATCH -c 24
#SBATCH --time=00:30:00 #SBATCH --time=00:30:00
# # output error message # # output error message
#SBATCH -e explicit_50M_8N%j.err #SBATCH -e explicit_%j.err
#SBATCH --mail-type=END,FAIL,TIME_LIMIT --mail-user=martin.khannouz@inria.fr #SBATCH --mail-type=END,FAIL,TIME_LIMIT --mail-user=martin.khannouz@inria.fr
## modules to load for the job ## modules to load for the job
module purge source $HOME/env.sh
module load slurm
spack load fftw
spack load hwloc
spack load openmpi
## variable for the job ## variable for the job
export GROUP_SIZE=500 export GROUP_SIZE=500
export TREE_HEIGHT=8 export TREE_HEIGHT=8
export NB_NODE=$SLURM_JOB_NUM_NODES export NB_NODE=$SLURM_JOB_NUM_NODES
export STARPU_NCPU=24 export STARPU_NCPU=24
export NB_PARTICLE_PER_NODE=6250000
export STARPU_FXT_PREFIX=$SLURM_JOB_ID export STARPU_FXT_PREFIX=$SLURM_JOB_ID
export FINAL_DIR="`pwd`/dir_$SLURM_JOB_ID" export FINAL_DIR="`pwd`/dir_$SLURM_JOB_ID"
export STARPU_COMM_STATS=1 export STARPU_COMM_STATS=1
$NUMACTL=numactl --interleave=all export STARPU_WATCHDOG_TIMEOUT=20000000
export STARPU_WATCHDOG_CRASH=1
NUMACTL="numactl --interleave=all"
mkdir $FINAL_DIR mkdir $FINAL_DIR
echo "my jobID: " $SLURM_JOB_ID > $FINAL_DIR/stdout echo "my jobID: " $SLURM_JOB_ID > $FINAL_DIR/stdout
echo "Model: cube" >> $FINAL_DIR/stdout echo "Model: cube" >> $FINAL_DIR/stdout
...@@ -36,9 +30,8 @@ echo "Nb thread: " $STARPU_NCPU >> $FINAL_DIR/stdout ...@@ -36,9 +30,8 @@ echo "Nb thread: " $STARPU_NCPU >> $FINAL_DIR/stdout
echo "Tree height: " $TREE_HEIGHT >> $FINAL_DIR/stdout echo "Tree height: " $TREE_HEIGHT >> $FINAL_DIR/stdout
echo "Group size: " $GROUP_SIZE >> $FINAL_DIR/stdout echo "Group size: " $GROUP_SIZE >> $FINAL_DIR/stdout
echo "Algorithm: explicit" >> $FINAL_DIR/stdout echo "Algorithm: explicit" >> $FINAL_DIR/stdout
echo "Particle per node: " $NB_PARTICLE_PER_NODE >> $FINAL_DIR/stdout echo "Total particles: " $NB_PARTICLE >> $FINAL_DIR/stdout
echo "Total particles: " $(($NB_PARTICLE_PER_NODE*$NB_NODE)) >> $FINAL_DIR/stdout mpiexec -n $NB_NODE $NUMACTL ./Build/Tests/Release/testBlockedMpiChebyshev -nb $NB_PARTICLE -bs $GROUP_SIZE -h $TREE_HEIGHT -no-validation >> $FINAL_DIR/stdout 2>&1
#Create argument list for starpu_fxt_tool #Create argument list for starpu_fxt_tool
cd $FINAL_DIR cd $FINAL_DIR
...@@ -53,4 +46,3 @@ cd .. ...@@ -53,4 +46,3 @@ cd ..
##Move the result into a directory where all result goes ##Move the result into a directory where all result goes
mv $FINAL_DIR jobs_result mv $FINAL_DIR jobs_result
#!/usr/bin/env bash
## name of job
#SBATCH -J implicit_50M_10N
#SBATCH -p special
#SBATCH -N 10
#SBATCH -c 24
#SBATCH -e implicit_chebyshev_50M_10_node%j.err
module purge
module load slurm
spack load fftw
spack load hwloc
spack load openmpi
mkdir $FINAL_DIR
echo "Algorithm: implicit" >> $FINAL_DIR/stdout
mpiexec -n $NB_NODE $NUMACTL ./Build/Tests/Release/testBlockedImplicitChebyshev -nb $NB_PARTICLE_PER_NODE -bs $GROUP_SIZE -h $TREE_HEIGHT -no-validation >> $FINAL_DIR/stdout
cd $FINAL_DIR
mkdir fxt
mv $i fxt
done
cd ..
#!/usr/bin/env bash
## name of job
#SBATCH -J implicit_50M_1N
#SBATCH -p defq
#SBATCH -N 1
#SBATCH -c 24
module purge
module load slurm
spack load fftw
spack load hwloc
spack load openmpi
mkdir $FINAL_DIR
cd $FINAL_DIR
mkdir fxt
mv $i fxt
done
cd ..
#!/usr/bin/env bash
## name of job
#SBATCH -J implicit_50M_2N
#SBATCH -p special
#SBATCH -N 2
#SBATCH -c 24
#SBATCH -e implicit_50M_2N_%j.err
module purge
module load slurm
spack load fftw
spack load hwloc
spack load openmpi
mkdir $FINAL_DIR
cd $FINAL_DIR
mkdir fxt
mv $i fxt
done
cd ..
#!/usr/bin/env bash
## name of job
#SBATCH -J implicit_50M_4N
#SBATCH -p special
#SBATCH -N 4
#SBATCH -c 24
module purge
module load slurm
spack load fftw
spack load hwloc
spack load openmpi
mkdir $FINAL_DIR
cd $FINAL_DIR
mkdir fxt
mv $i fxt
done
cd ..
#SBATCH -J implicit_50M_8N #SBATCH -J implicit
#SBATCH -N 8
#SBATCH -e implicit_50M_8N_%j.err #SBATCH -e implicit_%j.err
module load slurm
spack load fftw
spack load hwloc
spack load openmpi
echo "Algorithm: implicit" >> $FINAL_DIR/stdout echo "Algorithm: implicit" >> $FINAL_DIR/stdout
echo "Total particles: " $(($NB_PARTICLE_PER_NODE*$NB_NODE)) >> $FINAL_DIR/stdout mpiexec -n $NB_NODE $NUMACTL ./Build/Tests/Release/testBlockedImplicitChebyshev -nb $NB_PARTICLE -bs $GROUP_SIZE -h $TREE_HEIGHT -no-validation >> $FINAL_DIR/stdout 2>&1
...@@ -11,14 +11,8 @@ ...@@ -11,14 +11,8 @@
#SBATCH -e starpu_50M_%j.err #SBATCH -e starpu_50M_%j.err
module load slurm
spack load fftw
spack load hwloc
spack load openmpi
##Setting variable for the job ##Setting variable for the job
...@@ -27,8 +21,10 @@ export STARPU_NCPU=24 ...@@ -27,8 +21,10 @@ export STARPU_NCPU=24
export NB_PARTICLE_PER_NODE=50000000 export NB_PARTICLE_PER_NODE=50000000
$NUMACTL=numactl --interleave=all NUMACTL="numactl --interleave=all"
## Write data into an stdout file ## Write data into an stdout file
