Commit 3b11a857 authored by BRAMAS Berenger's avatar BRAMAS Berenger
update read me and remove periodic spherical test
parent 7df6087c
...@@ -22,6 +22,9 @@ ccmake .. ...@@ -22,6 +22,9 @@ ccmake ..
make make
# And access executables in scalfmm/Build/Tests/{Release,Debug}/..... # And access executables in scalfmm/Build/Tests/{Release,Debug}/.....
To compile with StarPU you can pass, as an example:
cmake .. -DSCALFMM_USE_STARPU=ON -DSCALFMM_USE_CUDA=OFF -DSCALFMM_USE_OPENCL=OFF -DHWLOC_DIR=/home/berenger/Téléchargements/hwloc-1.10.0/install/ -DSTARPU_DIR=/home/berenger/Téléchargements/starpu-work/StarPU/installwithfxt
This diff is collapsed.
