Commit 1f8b0063 authored by COULAUD Olivier's avatar COULAUD Olivier
Change Policy CMP0004 to NEW ; add modification for version 1.5.1
parent f5e3a5ce
...@@ -4,7 +4,7 @@ if(CMAKE_MAJOR_VERSION GREATER 1 AND CMAKE_MINOR_VERSION GREATER 7 AND CMAKE_PAT ...@@ -4,7 +4,7 @@ if(CMAKE_MAJOR_VERSION GREATER 1 AND CMAKE_MINOR_VERSION GREATER 7 AND CMAKE_PAT
cmake_policy(SET CMP0022 OLD) cmake_policy(SET CMP0022 OLD)
endif() endif()
cmake_policy(SET CMP0004 OLD) cmake_policy(SET CMP0004 NEW)
set(CMAKE_DISABLE_IN_SOURCE_BUILD ON) set(CMAKE_DISABLE_IN_SOURCE_BUILD ON)
