Commit 1912729f authored by PRUVOST Florent's avatar PRUVOST Florent
cmake Finds: improve the way library dirs are added in blas/lapack, remove...
cmake Finds: improve the way library dirs are added in blas/lapack, remove blas lib to search in essl
parent 622a0e43
...@@ -906,7 +906,7 @@ if (BLA_VENDOR STREQUAL "IBMESSL" OR BLA_VENDOR STREQUAL "All") ...@@ -906,7 +906,7 @@ if (BLA_VENDOR STREQUAL "IBMESSL" OR BLA_VENDOR STREQUAL "All")
BLAS BLAS
sgemm sgemm
"essl;blas" "essl"
endif() endif()
...@@ -259,9 +259,17 @@ endif() ...@@ -259,9 +259,17 @@ endif()
# extract libs paths # extract libs paths
# remark: because it is not given by find_package(BLAS) # remark: because it is not given by find_package(BLAS)
set(BLAS_LIBRARY_DIRS "") set(BLAS_LIBRARY_DIRS "")
string(REPLACE " " ";" BLAS_LIBRARIES "${BLAS_LIBRARIES}")
foreach(blas_lib ${BLAS_LIBRARIES}) foreach(blas_lib ${BLAS_LIBRARIES})
get_filename_component(a_blas_lib_dir "${blas_lib}" PATH) string(REPLACE "-L" "" blas_lib "${blas_lib}")
list(APPEND BLAS_LIBRARY_DIRS "${a_blas_lib_dir}" ) if (EXISTS "${blas_lib}")
list(APPEND BLAS_LIBRARY_DIRS "${blas_lib}" )
else()
if (EXISTS "${a_blas_lib_dir}")
endif()
endif()
endforeach() endforeach()
if (BLAS_LIBRARY_DIRS) if (BLAS_LIBRARY_DIRS)
list(REMOVE_DUPLICATES BLAS_LIBRARY_DIRS) list(REMOVE_DUPLICATES BLAS_LIBRARY_DIRS)
...@@ -154,7 +154,7 @@ macro(Check_Lapack_Libraries LIBRARIES _prefix _name _flags _list _blas _threads ...@@ -154,7 +154,7 @@ macro(Check_Lapack_Libraries LIBRARIES _prefix _name _flags _list _blas _threads
# N.B. _prefix is the prefix applied to the names of all cached variables that # N.B. _prefix is the prefix applied to the names of all cached variables that
# are generated internally and marked advanced by this macro. # are generated internally and marked advanced by this macro.
set(_libdir ${ARGN})
set(_libraries_work TRUE) set(_libraries_work TRUE)
set(${LIBRARIES}) set(${LIBRARIES})
set(_combined_name) set(_combined_name)
...@@ -211,9 +211,17 @@ endif() ...@@ -211,9 +211,17 @@ endif()
# remark: because it is not given by find_package(LAPACK) # remark: because it is not given by find_package(LAPACK)
set(LAPACK_LIBRARY_DIRS "") set(LAPACK_LIBRARY_DIRS "")
foreach(lapack_lib ${LAPACK_LIBRARIES}) string(REPLACE " " ";" LAPACK_LIBRARY_DIRS "${LAPACK_LIBRARY_DIRS}")
get_filename_component(a_lapack_lib_dir "${lapack_lib}" PATH) foreach(lapack_lib ${LAPACK_LIBRARY_DIRS})
list(APPEND LAPACK_LIBRARY_DIRS "${a_lapack_lib_dir}" ) string(REPLACE "-L" "" lapack_lib "${lapack_lib}")
if (EXISTS "${lapack_lib}")
list(APPEND LAPACK_LIBRARY_DIRS "${lapack_lib}" )
else()
if (EXISTS "${a_lapack_lib_dir}")
endif()
endif()
if (LAPACK_LIBRARY_DIRS) if (LAPACK_LIBRARY_DIRS)
list(REMOVE_DUPLICATES LAPACK_LIBRARY_DIRS) list(REMOVE_DUPLICATES LAPACK_LIBRARY_DIRS)
...@@ -17,6 +17,7 @@ ...@@ -17,6 +17,7 @@
# PASTIX depends on the following libraries: # PASTIX depends on the following libraries:
# - Threads, m, rt # - Threads, m, rt
# - MPI
# - HWLOC # - HWLOC
# - BLAS # - BLAS
