Commit fe1ac6c4 authored by Martin Khannouz's avatar Martin Khannouz Committed by Berenger Bramas
Add two jobs and modify job to use option for the model (cube, plummer,
ellipsoid).
parent 32840c58
...@@ -27,13 +27,13 @@ export STARPU_MPI_COMM=1 ...@@ -27,13 +27,13 @@ export STARPU_MPI_COMM=1
NUMACTL="numactl --interleave=all" NUMACTL="numactl --interleave=all"
mkdir $FINAL_DIR mkdir $FINAL_DIR
echo "my jobID: " $SLURM_JOB_ID > $FINAL_DIR/stdout echo "my jobID: " $SLURM_JOB_ID > $FINAL_DIR/stdout
echo "Model: cube" >> $FINAL_DIR/stdout echo "Model: " $MODEL >> $FINAL_DIR/stdout
echo "Nb node: " $NB_NODE >> $FINAL_DIR/stdout echo "Nb node: " $NB_NODE >> $FINAL_DIR/stdout
echo "Nb thread: " $STARPU_NCPU >> $FINAL_DIR/stdout echo "Nb thread: " $STARPU_NCPU >> $FINAL_DIR/stdout
echo "Tree height: " $TREE_HEIGHT >> $FINAL_DIR/stdout echo "Tree height: " $TREE_HEIGHT >> $FINAL_DIR/stdout
echo "Group size: " $GROUP_SIZE >> $FINAL_DIR/stdout echo "Group size: " $GROUP_SIZE >> $FINAL_DIR/stdout
echo "Algorithm: explicit" >> $FINAL_DIR/stdout echo "Algorithm: explicit" >> $FINAL_DIR/stdout
echo "Total particles: " $NB_PARTICLE >> $FINAL_DIR/stdout echo "Total particles: " $NB_PARTICLE >> $FINAL_DIR/stdout
mpiexec -n $NB_NODE $NUMACTL ./Build/Tests/Release/testBlockedMpiChebyshev -nb $NB_PARTICLE -bs $GROUP_SIZE -h $TREE_HEIGHT -no-validation >> $FINAL_DIR/stdout 2>&1 mpiexec -n $NB_NODE $NUMACTL ./Build/Tests/Release/testBlockedMpiChebyshev -nb $NB_PARTICLE -bs $GROUP_SIZE -h $TREE_HEIGHT -$MODEL -no-validation >> $FINAL_DIR/stdout 2>&1
source $HOME/move_trace.sh source $HOME/move_trace.sh
echo "Algorithm: implicit" >> $FINAL_DIR/stdout echo "Algorithm: implicit" >> $FINAL_DIR/stdout
mpiexec -n $NB_NODE $NUMACTL ./Build/Tests/Release/testBlockedImplicitChebyshev -nb $NB_PARTICLE -bs $GROUP_SIZE -h $TREE_HEIGHT -no-validation >> $FINAL_DIR/stdout 2>&1 mpiexec -n $NB_NODE $NUMACTL ./Build/Tests/Release/testBlockedImplicitChebyshev -nb $NB_PARTICLE -bs $GROUP_SIZE -h $TREE_HEIGHT -no-validation -$MODEL >> $FINAL_DIR/stdout 2>&1
#!/usr/bin/env bash
## name of job
#SBATCH -J implicit-by-two
#SBATCH -p special
## Resources: (nodes, procs, tasks, walltime, ... etc)
#SBATCH -c 12
#SBATCH --time=0-00:30:00
#SBATCH --exclusive
# # output error message
#SBATCH -e implicit_%j.err
#SBATCH --mail-type=END,FAIL,TIME_LIMIT --mail-user=martin.khannouz@inria.fr
## modules to load for the job
source $HOME/env.sh
## variable for the job
export TREE_HEIGHT=8
export NB_NODE=$(($SLURM_JOB_NUM_NODES*2))
export STARPU_NCPU=12
export STARPU_FXT_PREFIX=$SLURM_JOB_ID
export FINAL_DIR="`pwd`/dir_$SLURM_JOB_ID"
export STARPU_COMM_STATS=1
export STARPU_WATCHDOG_TIMEOUT=30000000
export STARPU_WATCHDOG_CRASH=1
export STARPU_GENERATE_TRACE=0
export STARPU_SILENT=1
mkdir $FINAL_DIR
echo "Nb node: " $SLURM_JOB_NUM_NODES >> $FINAL_DIR/stdout
echo "Algorithm: implicit-two-by" >> $FINAL_DIR/stdout
echo "Max Task Submitted: " $STARPU_LIMIT_MAX_SUBMITTED_TASKS >> $FINAL_DIR/stdout
echo "Min Task Submitted: " $STARPU_LIMIT_MIN_SUBMITTED_TASKS >> $FINAL_DIR/stdout
mpiexec -n $NB_NODE --map-by socket $NUMACTL ./Build/Tests/Release/testBlockedImplicitChebyshev -nb $NB_PARTICLE -bs $GROUP_SIZE -h $TREE_HEIGHT -no-validation -$MODEL >> $FINAL_DIR/stdout 2>&1
#!/usr/bin/env bash
## name of job
#SBATCH -J implicit
#SBATCH -p special
#SBATCH -c 24
#SBATCH --exclusive
source $HOME/env.sh
export NB_NODE=$SLURM_JOB_NUM_NODES
export STARPU_NCPU=24
export STARPU_LIMIT_MAX_SUBMITTED_TASKS=8000
export STARPU_LIMIT_MIN_SUBMITTED_TASKS=2000
mkdir $FINAL_DIR
echo "Algorithm: implicit limited" >> $FINAL_DIR/stdout
...@@ -20,13 +20,13 @@ export STARPU_FXT_PREFIX=$SLURM_JOB_ID ...@@ -20,13 +20,13 @@ export STARPU_FXT_PREFIX=$SLURM_JOB_ID
echo "Nb thread: 24" >> $FINAL_DIR/stdout echo "Nb thread: 24" >> $FINAL_DIR/stdout
echo "Group size: 1" >> $FINAL_DIR/stdout echo "Group size: 1" >> $FINAL_DIR/stdout
echo "Algorithm: simple-mpi" >> $FINAL_DIR/stdout echo "Algorithm: simple-mpi" >> $FINAL_DIR/stdout
mpiexec -n $NB_NODE $NUMACTL ./Build/Tests/Release/testFmmAlgorithmThreadProc -nb $NB_PARTICLE -h $TREE_HEIGHT >> $FINAL_DIR/stdout 2>&1 mpiexec -n $NB_NODE $NUMACTL ./Build/Tests/Release/testFmmAlgorithmThreadProc -nb $NB_PARTICLE -h $TREE_HEIGHT -$MODEL >> $FINAL_DIR/stdout 2>&1
...@@ -26,13 +26,13 @@ NUMACTL="numactl --interleave=all" ...@@ -26,13 +26,13 @@ NUMACTL="numactl --interleave=all"
## Write data into an stdout file ## Write data into an stdout file
echo "Algorithm: starpu" >> $FINAL_DIR/stdout echo "Algorithm: starpu" >> $FINAL_DIR/stdout
$NUMACTL ./Build/Tests/Release/testBlockedChebyshev -nb $NB_PARTICLE -bs $GROUP_SIZE -h $TREE_HEIGHT -no-validation >> $FINAL_DIR/stdout $NUMACTL ./Build/Tests/Release/testBlockedChebyshev -nb $NB_PARTICLE -bs $GROUP_SIZE -h $TREE_HEIGHT -no-validation -$MODEL >> $FINAL_DIR/stdout
