Commit ede044bf authored by PIACIBELLO Cyrille's avatar PIACIBELLO Cyrille
parents 1ca97c8c 2472856f
...@@ -167,7 +167,7 @@ int main(int argc, char ** argv){ ...@@ -167,7 +167,7 @@ int main(int argc, char ** argv){
std::stringstream ss(aspectRatio); ss >>A >> B >> C ; std::stringstream ss(aspectRatio); ss >>A >> B >> C ;
unifRandonPointsOnCube(NbPoints, A,B,C,particles) ; unifRandonPointsOnCube(NbPoints, A,B,C,particles) ;
BoxWith = FMath::Max(A,FMath::Max(B,C) ); BoxWith = FMath::Max(A,FMath::Max(B,C) );
FReal halfBW = BoxWith; FReal halfBW = BoxWith*0.5;
Centre.setPosition(halfBW,halfBW,halfBW); Centre.setPosition(halfBW,halfBW,halfBW);
else if(FParameters::existParameter(argc, argv, "-unitSphere")){ else if(FParameters::existParameter(argc, argv, "-unitSphere")){
...@@ -80,6 +80,15 @@ foreach(exec ${source_tests_files}) ...@@ -80,6 +80,15 @@ foreach(exec ${source_tests_files})
endif() endif()
endif() endif()
# Test FFT dependency
file(STRINGS "${exec}" lines_fft REGEX "@FUSE_FFT")
if(lines_fft)
if( NOT ScalFMM_USE_FFT )
MESSAGE( STATUS "This needs FFT = ${exec}" )
set(compile_exec "FALSE")
endif()
endif()
# Test MPI dependency # Test MPI dependency
file(STRINGS "${exec}" lines_mpi REGEX "@FUSE_MPI") file(STRINGS "${exec}" lines_mpi REGEX "@FUSE_MPI")
if(lines_mpi) if(lines_mpi)
Supports Markdown
