Commit ebba3102 authored by PRUVOST Florent's avatar PRUVOST Florent
handle rpath for scalfmm drivers
parent eb63f6ec
...@@ -53,6 +53,16 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/ ...@@ -53,6 +53,16 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/
set(MORSE_CMAKE_MODULE_PATH ${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse ) set(MORSE_CMAKE_MODULE_PATH ${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse )
endif() endif()
include(MorseInit) include(MorseInit)
# Set the RPATH config
# use, i.e. don't skip the full RPATH for the build tree
set(CMAKE_SKIP_BUILD_RPATH FALSE)
# when building, don't use the install RPATH already
# (but later on when installing)
set(CMAKE_BUILD_WITH_INSTALL_RPATH TRUE)
# the RPATH to be used when installing
set(CMAKE_INSTALL_RPATH "${CMAKE_INSTALL_PREFIX}/lib")
# Options # Options
...@@ -314,17 +324,13 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/ ...@@ -314,17 +324,13 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/
if( SCALFMM_USE_MKL_AS_BLAS ) if( SCALFMM_USE_MKL_AS_BLAS )
set(BLA_VENDOR "Intel10_64lp_seq") set(BLA_VENDOR "Intel10_64lp_seq")
find_package(BLASEXT QUIET) # not REQUIRED find_package(BLASEXT QUIET) # not REQUIRED
if(BLAS_LIBRARY_DIRS)
list(APPEND CMAKE_INSTALL_RPATH "${BLAS_LIBRARY_DIRS}")
endif()
unset(LAPACK_LIBRARIES) unset(LAPACK_LIBRARIES)
if (BLAS_LIBRARIES) if (BLAS_LIBRARIES)
set(BLASLAPACK_LIBRARIES ${BLAS_LIBRARIES}) set(BLASLAPACK_LIBRARIES ${BLAS_LIBRARIES})
endif() endif()
elseif(SCALFMM_USE_EXTERNAL_BLAS) elseif(SCALFMM_USE_EXTERNAL_BLAS)
message(STATUS "BLAS SET BY EXTERNAL PROGRAM = ${BLAS_LIBRARIES}") message(STATUS "BLAS SET BY EXTERNAL PROGRAM = ${BLAS_LIBRARIES}")
list(APPEND BLASLAPACK_LIBRARIES "${BLAS_LIBRARIES}")
else() else()
find_package(BLASEXT) # not REQUIRED find_package(BLASEXT) # not REQUIRED
find_package(LAPACKEXT) # not REQUIRED find_package(LAPACKEXT) # not REQUIRED
...@@ -339,7 +345,14 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/ ...@@ -339,7 +345,14 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/
if(BLAS_FOUND) if(BLAS_FOUND)
set(SCALFMM_LIBRARIES "${SCALFMM_LIBRARIES};${BLASLAPACK_LIBRARIES}") set(SCALFMM_LIBRARIES "${SCALFMM_LIBRARIES};${BLASLAPACK_LIBRARIES}")
#message(STATUS "SCALFMM_LIBRARIES = ${SCALFMM_LIBRARIES}") if(BLAS_LIBRARY_DIRS)
endif()
if(LAPACK_FOUND AND LAPACK_LIBRARY_DIRS)
list(APPEND CMAKE_INSTALL_RPATH "${LAPACK_LIBRARY_DIRS}")
endif()
else() else()
message(WARNING "BLAS has not been found, SCALFMM will continue to compile but some applications will be disabled.") message(WARNING "BLAS has not been found, SCALFMM will continue to compile but some applications will be disabled.")
message(WARNING "If you have BLAS set BLAS_LIBDIR, BLAS_INCDIR or BLAS_DIR (CMake variables using -D or environment variables).") message(WARNING "If you have BLAS set BLAS_LIBDIR, BLAS_INCDIR or BLAS_DIR (CMake variables using -D or environment variables).")
...@@ -408,6 +421,10 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/ ...@@ -408,6 +421,10 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/
if (FFT_LIBRARIES) if (FFT_LIBRARIES)
set(SCALFMM_LIBRARIES "${SCALFMM_LIBRARIES};${FFT_LIBRARIES}") set(SCALFMM_LIBRARIES "${SCALFMM_LIBRARIES};${FFT_LIBRARIES}")
endif() endif()
if(FFTW_LIBRARY_DIRS)
list(APPEND CMAKE_INSTALL_RPATH "${FFTW_LIBRARY_DIRS}")
endif()
endif(SCALFMM_USE_MKL_AS_FFTW) endif(SCALFMM_USE_MKL_AS_FFTW)
...@@ -472,7 +489,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/ ...@@ -472,7 +489,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/
if (CUDA_LIBRARIES) if (CUDA_LIBRARIES)
set(SCALFMM_LIBRARIES "${SCALFMM_LIBRARIES};${CUDA_LIBRARIES}") set(SCALFMM_LIBRARIES "${SCALFMM_LIBRARIES};${CUDA_LIBRARIES}")
endif() endif()
set(CUDA_NEEDED_INCLUDE_DIRS ${CMAKE_CURRENT_BINARY_DIR}/Src) set(CUDA_NEEDED_INCLUDE_DIRS ${CMAKE_CURRENT_BINARY_DIR}/Src)
endif() endif()
...@@ -490,6 +507,19 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/ ...@@ -490,6 +507,19 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/
find_package(STARPU ${SCALFMM_STARPU_VERSION} REQUIRED find_package(STARPU ${SCALFMM_STARPU_VERSION} REQUIRED
COMPONENTS ${STARPU_COMPONENT_LIST}) COMPONENTS ${STARPU_COMPONENT_LIST})
if(HWLOC_FOUND AND HWLOC_LIBRARY_DIRS)
list(APPEND CMAKE_INSTALL_RPATH "${HWLOC_LIBRARY_DIRS}")
endif()
if(FXT_FOUND AND FXT_LIBRARY_DIRS)
list(APPEND CMAKE_INSTALL_RPATH "${FXT_LIBRARY_DIRS}")
endif()
if(STARPU_FOUND AND STARPU_LIBRARY_DIRS)
list(APPEND CMAKE_INSTALL_RPATH "${STARPU_LIBRARY_DIRS}")
endif()
# Append list of libraries and include dirs # Append list of libraries and include dirs
include_directories(${STARPU_INCLUDE_DIRS_DEP}) include_directories(${STARPU_INCLUDE_DIRS_DEP})
foreach (starpu_libdir ${STARPU_LIBRARY_DIRS_DEP}) foreach (starpu_libdir ${STARPU_LIBRARY_DIRS_DEP})
...@@ -666,6 +696,10 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/ ...@@ -666,6 +696,10 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/CMakeModules/morse/
if(EZTrace_FOUND) if(EZTrace_FOUND)
link_directories(${EZTrace_LIBRARY_DIRS}) link_directories(${EZTrace_LIBRARY_DIRS})
link_libraries( ${EZTrace_LIBRARIES}) link_libraries( ${EZTrace_LIBRARIES})
if (EZTrace_LIBRARY_DIRS)
list(APPEND CMAKE_INSTALL_RPATH "${EZTrace_LIBRARY_DIRS}")
endif()
IF( SCALFMM_USE_MPI ) IF( SCALFMM_USE_MPI )
link_libraries(-leztrace-autostart-mpi) link_libraries(-leztrace-autostart-mpi)
ENDIF(SCALFMM_USE_MPI) ENDIF(SCALFMM_USE_MPI)
