Commit e659df5c authored by COULAUD Olivier's avatar COULAUD Olivier
Merge branch 'develop'
parents fa3f2193 ed30f0a0
...@@ -12,6 +12,7 @@ set(CMAKE_DISABLE_IN_SOURCE_BUILD ON) ...@@ -12,6 +12,7 @@ set(CMAKE_DISABLE_IN_SOURCE_BUILD ON)
# Project Declaration # Project Declaration
project(SCALFMM C CXX) project(SCALFMM C CXX)
# Adds the CMAKE_DEPENDENT_OPTION command
INCLUDE( CMakeDependentOption ) INCLUDE( CMakeDependentOption )
# check if compiling into source directories # check if compiling into source directories
string(COMPARE EQUAL "${CMAKE_SOURCE_DIR}" "${CMAKE_BINARY_DIR}" insource) string(COMPARE EQUAL "${CMAKE_SOURCE_DIR}" "${CMAKE_BINARY_DIR}" insource)
...@@ -26,7 +27,7 @@ include(GetCpuInfos) ...@@ -26,7 +27,7 @@ include(GetCpuInfos)
GetCpuInfos() GetCpuInfos()
# Adds the CMAKE_DEPENDENT_OPTION command # Adds the CMAKE_DEPENDENT_OPTION command
INCLUDE(CMakeDependentOption) #INCLUDE(CMakeDependentOption)
# Version Number # Version Number
...@@ -89,6 +90,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/") ...@@ -89,6 +90,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
option( SCALFMM_DISABLE_NATIVE_OMP4 "Set to ON to disable the gcc/intel omp4" OFF ) option( SCALFMM_DISABLE_NATIVE_OMP4 "Set to ON to disable the gcc/intel omp4" OFF )
option( SCALFMM_TIME_OMPTASKS "Set to ON to time omp4 tasks and generate output file" OFF ) option( SCALFMM_TIME_OMPTASKS "Set to ON to time omp4 tasks and generate output file" OFF )
endif() endif()
message(STATUS "AVANT ${CMAKE_CXX_COMPILER_ID}" )
if( SCALFMM_USE_MPI ) if( SCALFMM_USE_MPI )
try_compile(COMPILE_INTEL ${CMAKE_CURRENT_BINARY_DIR} try_compile(COMPILE_INTEL ${CMAKE_CURRENT_BINARY_DIR}
${SCALFMM_CMAKE_MODULE_PATH}/compileTestIntel.cpp ${SCALFMM_CMAKE_MODULE_PATH}/compileTestIntel.cpp
...@@ -101,6 +103,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/") ...@@ -101,6 +103,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
# Set scalfmm to default libraries # Set scalfmm to default libraries
set(SCALFMM_LIBRARIES "") set(SCALFMM_LIBRARIES "")
set(SCALFMM_CXX_FLAGS "-std=c++11 -fpic -Wall") set(SCALFMM_CXX_FLAGS "-std=c++11 -fpic -Wall")
MESSAGE(STATUS "FLAGS =$CALFMM_CXX_FLAGS")
# Test if openmp is here # Test if openmp is here
...@@ -150,7 +153,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/") ...@@ -150,7 +153,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
endif() endif()
endif() endif()
IF (APPLE) IF (APPLE)
set(SSE_FLAGS "-msse4 -mfpmath=sse") # -mtune=native -march=native # set(SSE_FLAGS "-msse4 -mfpmath=sse") # -mtune=native -march=native
set(SSE_FLAGS "-msse3 -mfpmath=sse") set(SSE_FLAGS "-msse3 -mfpmath=sse")
set(AVX_FLAGS "-mtune=native -march=avx") set(AVX_FLAGS "-mtune=native -march=avx")
set(AVX2_FLAGS "-mtune=native -march=native -mmic") set(AVX2_FLAGS "-mtune=native -march=native -mmic")
...@@ -648,7 +651,12 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/") ...@@ -648,7 +651,12 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
link_libraries( ${EZTrace_LIBRARIES} -leztrace-memory) link_libraries( ${EZTrace_LIBRARIES} -leztrace-memory)
include_directories(${EZTrace_INCLUDE_DIRS}) include_directories(${EZTrace_INCLUDE_DIRS})
MESSAGE(STATUS "EZTRACE: ${EZTrace_INCLUDE_DIRS} ${EZTrace_LIBRARY_DIRS} ${EZTrace_LIBRARIES}") MESSAGE(STATUS "EZTRACE: ${EZTrace_INCLUDE_DIRS} ${EZTrace_LIBRARY_DIRS} ${EZTrace_LIBRARIES}")
CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_M2L "Set to ON to trace M2L operator" ON "SCALFMM_USE_EZTRACE" OFF ) CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_ALGO "Set to ON to trace the full algorithm (all operators)" ON "SCALFMM_USE_EZTRACE" OFF )
CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_P2M "Set to ON to trace P2M operator" OFF "SCALFMM_USE_EZTRACE" OFF )
CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_M2M "Set to ON to trace M2M operator" OFF "SCALFMM_USE_EZTRACE" OFF )
CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_M2L "Set to ON to trace M2L operator" OFF "SCALFMM_USE_EZTRACE" OFF )
CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_L2L "Set to ON to trace L2L operator" OFF "SCALFMM_USE_EZTRACE" OFF )
CMAKE_DEPENDENT_OPTION(SCALFMM_TRACE_P2P "Set to ON to trace P2P operator" OFF "SCALFMM_USE_EZTRACE" OFF )
else(PKG_CONFIG_FOUND) else(PKG_CONFIG_FOUND)
MESSAGE(WARNING "PKG-CONFIG not found- EZTRACE Is set to NONE") MESSAGE(WARNING "PKG-CONFIG not found- EZTRACE Is set to NONE")
...@@ -188,7 +188,10 @@ protected: ...@@ -188,7 +188,10 @@ protected:
void executeCore(const unsigned operationsToProceed) override { void executeCore(const unsigned operationsToProceed) override {
// Count leaf // Count leaf
this->numberOfLeafs = 0; #ifdef SCALFMM_TRACE_ALGO
eztrace_start();
#endif
Interval myFullInterval; Interval myFullInterval;
{//Building the interval with the first and last leaves (and count the number of leaves) {//Building the interval with the first and last leaves (and count the number of leaves)
...@@ -280,11 +283,17 @@ protected: ...@@ -280,11 +283,17 @@ protected:
if( (operationsToProceed & FFmmP2P) || (operationsToProceed & FFmmL2P) ) directPass((operationsToProceed & FFmmP2P),(operationsToProceed & FFmmL2P)); if( (operationsToProceed & FFmmP2P) || (operationsToProceed & FFmmL2P) ) directPass((operationsToProceed & FFmmP2P),(operationsToProceed & FFmmL2P));
Timers[NearTimer].tac(); Timers[NearTimer].tac();
eztrace_stop();
#endif
// delete array // delete array
delete [] iterArray; delete [] iterArray;
delete [] iterArrayComm; delete [] iterArrayComm;
iterArray = nullptr; iterArray = nullptr;
iterArrayComm = nullptr; iterArrayComm = nullptr;
eztrace_stop();
#endif
