Commit e3ce6854 authored by BRAMAS Berenger's avatar BRAMAS Berenger
add tooltip in graphviz
parent a768410d
...@@ -298,7 +298,7 @@ public: ...@@ -298,7 +298,7 @@ public:
fprintf(fdot,"digraph BST {\n"); fprintf(fdot,"digraph BST {\n");
for(int idxCluster = dim-2 ; idxCluster >= 0 ; --idxCluster){ for(int idxCluster = dim-2 ; idxCluster >= 0 ; --idxCluster){
fprintf(fdot,"\t %d [label=\"%d Size=%d Dist=%e\"];\n", fprintf(fdot,"\t %d [label=\"%d Size=%d Dist=%e\", tooltip=\"\"];\n",
(-idxCluster-1)+dim-2, idxCluster, sizeOfClusters[idxCluster], croot[idxCluster].distance); (-idxCluster-1)+dim-2, idxCluster, sizeOfClusters[idxCluster], croot[idxCluster].distance);
fprintf(fdot,"\t %d -> %d;\n", (-idxCluster-1)+dim-2, croot[idxCluster].left+dim-2); fprintf(fdot,"\t %d -> %d;\n", (-idxCluster-1)+dim-2, croot[idxCluster].left+dim-2);
fprintf(fdot,"\t %d -> %d;\n", (-idxCluster-1)+dim-2, croot[idxCluster].right+dim-2); fprintf(fdot,"\t %d -> %d;\n", (-idxCluster-1)+dim-2, croot[idxCluster].right+dim-2);
...@@ -63,7 +63,7 @@ int main(int argc, char** argv){ ...@@ -63,7 +63,7 @@ int main(int argc, char** argv){
tcluster.saveToXml(outputdir, "ccl.xml"); tcluster.saveToXml(outputdir, "ccl.xml");
tcluster.saveToDot(outputdir, "ccl.dot"); tcluster.saveToDot(outputdir, "gccl.dot");
return 0; return 0;
