GitLab
What's new
10
Support
Community forum
Keyboard shortcuts
solverstack
ScalFMM
e28f89c6
e28f89c6
COULAUD Olivier
new options for Intel compiler
78b6a16c
23 additions
17 deletions
+23
-17
CMakeLists.txt
CMakeLists.txt
+23
-17
CMakeLists.txt
e28f89c6
@@ -112,9 +112,9 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
IF
APPLE
IF
APPLE
set
SSE_FLAGS
"-msse4 -mfpmath=sse"
# -mtune=native -march=native
set
SSE_FLAGS
else
APPLE
else
APPLE
set
AVX_FLAGS
"-mavx"
set
AVX_FLAGS
"-mavx
-march=native
set
AVX2_FLAGS
"-mavx2"
set
AVX2_FLAGS
"-mavx2
-march=native
set
SSE_FLAGS
"-axSSE4.2"
set
SSE_FLAGS
"-axSSE4.2
-march=native
endif
APPLE
endif
APPLE
#-Wshadow -Wpointer-arith -Wcast-qual -Wconversion -Wall -Wnosign-conversion ")
else
else
@@ -178,15 +178,13 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
# Release flags #
# Release flags #
set
CMAKE_BUILD_TYPE Release
set
# force -O3 in release
set
CMAKE_CXX_FLAGS_RELEASE
-O3"
string
REPLACE
"-O2"
"-O3"
set
CMAKE_CXX_FLAGS_TYPE
set
# if compiler is intel add -ip
if
CMAKE_CXX_COMPILER_ID STREQUAL
"Intel"
if
"Intel"
set
SCALFMM_CXX_FLAGS
SCALFMM_CXX_FLAGS
-ip"
set
SCALFMM_CXX_FLAGS
SCALFMM_CXX_FLAGS
-ip -no-prec-div -no-prec-sqrt"
# set(SCALFMM_CXX_FLAGS "${SCALFMM_CXX_FLAGS} -ip -no-prec-div -no-prec-sqrt")
endif
endif
# Compile optimization
if
APPLE
if
APPLE
@@ -195,10 +193,10 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
else
APPLE
else
APPLE
# Not apple system - Check the compiler flags
if
"Intel"
if
"Intel"
set(SCALFMM_FLAGS_OPTI_RELEASE "-fp-model precise -fp-model source -fimf-precision=low -funroll-loops -ftree-vectorize"
set
CACHE STRING "Set your optimization flags for release mode.")
CACHE STRING
set
CACHE STRING
" CACHE STRING
else
else
set
"-ffast-math -funroll-loops -ftree-vectorize"
CACHE STRING
set
CACHE STRING
@@ -207,6 +205,9 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
set
SCALFMM_CXX_FLAGS
SCALFMM_CXX_FLAGS
set
SCALFMM_CXX_FLAGS
SCALFMM_CXX_FLAGS
endif
endif
MESSAGE
STATUS
" %%%%%%%%%% SCALFMM_CXX_FLAGS
SCALFMM_CXX_FLAGS
MESSAGE
STATUS
" %%%%%%%%%% CMAKE_CXX_FLAGS_RELEASE
# Attach source code to exec #
@@ -537,14 +538,19 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
COMPILE_DEFINITIONS
CMAKE_CXX_FLAGS
AVX_FLAGS
COMPILE_DEFINITIONS
CMAKE_CXX_FLAGS
AVX_FLAGS
OUTPUT_VARIABLE COMPILE_AVX_OUTPUT
if
COMPILE_AVX
if
COMPILE_AVX
message
STATUS
"%%%%%%%%%%%% COMPILE_AVX =
COMPILE_AVX
AVX_FLAGS
set
SCALFMM_CXX_FLAGS
SCALFMM_CXX_FLAGS
AVX_FLAGS
set
SCALFMM_CXX_FLAGS
SCALFMM_CXX_FLAGS
AVX_FLAGS
message
STATUS
"%%%%%%%%%%%% SCALFMM_CXX_FLAGS =
SCALFMM_CXX_FLAGS
#set( SCALFMM_USE_SSE OFF FORCE) # ne marche pas
try_compile
COMPILE_RESULT_AVSPE
CMAKE_CURRENT_BINARY_DIR
try_compile
SCALFMM_CMAKE_MODULE_PATH
/checkAVXpe.cpp
/checkAVXpe.cpp
COMPILE_DEFINITIONS
CMAKE_CXX_FLAGS
AVX_FLAGS
COMPILE_DEFINITIONS
CMAKE_CXX_FLAGS
AVX_FLAGS
if
NOT
# if( NOT ${COMPILE_RESULT_AVSPE})
set
__AVXPE_INTEL_COMPILER ON
set
endif
endif()
message
STATUS
CMAKE_CXX_FLAGS
message
STATUS
CMAKE_CXX_FLAGS
else
COMPILE_AVX
else
COMPILE_AVX
