Commit db0406ae authored by BRAMAS Berenger's avatar BRAMAS Berenger
Remove the test of NULL pointer when MPI is enabled because it shows warnings from the MPI lib
parent e1125676
...@@ -95,7 +95,9 @@ if(CMAKE_CXX_COMPILER_ID STREQUAL "Intel") ...@@ -95,7 +95,9 @@ if(CMAKE_CXX_COMPILER_ID STREQUAL "Intel")
#-Wshadow -Wpointer-arith -Wcast-qual -Wconversion -Wall -Wnosign-conversion ") #-Wshadow -Wpointer-arith -Wcast-qual -Wconversion -Wall -Wnosign-conversion ")
else() else()
# NOT INTEL # NOT INTEL
SET(ScaLFMM_CXX_FLAGS "${ScaLFMM_CXX_FLAGS} -Wzero-as-null-pointer-constant") if(NOT ${ScalFMM_USE_MPI})
endif()
SET(AVX_FLAGS "-mtune=native -march=native") SET(AVX_FLAGS "-mtune=native -march=native")
IF (APPLE) IF (APPLE)
SET(SSE_FLAGS "-msse3 -mfpmath=sse") # -mtune=native -march=native SET(SSE_FLAGS "-msse3 -mfpmath=sse") # -mtune=native -march=native
