Commit d43f61a0 authored by aetcheve's avatar aetcheve
modif cmake install
parent 0f451d65
...@@ -36,7 +36,7 @@ MESSAGE(STATUS " CXX ${CMAKE_CXX_COMPILER_ID}" ) ...@@ -36,7 +36,7 @@ MESSAGE(STATUS " CXX ${CMAKE_CXX_COMPILER_ID}" )
# Options # Options
OPTION( SCALFMM_USE_MPI "Set to ON to build ScaFMM with MPI" OFF ) OPTION( SCALFMM_USE_MPI "Set to ON to build ScaFMM with MPI" OFF )
OPTION( SCALFMM_USE_BLAS "Set to ON to build ScaFMM with BLAS" ON ) OPTION( SCALFMM_USE_BLAS "Set to ON to build ScaFMM with BLAS" OFF )
OPTION( SCALFMM_USE_TRACE "Set to ON to print trace or use itac trace" OFF ) OPTION( SCALFMM_USE_TRACE "Set to ON to print trace or use itac trace" OFF )
OPTION( SCALFMM_BUILD_TESTS "Set to ON to build fonctionnalities Tests" OFF ) OPTION( SCALFMM_BUILD_TESTS "Set to ON to build fonctionnalities Tests" OFF )
OPTION( SCALFMM_BUILD_UTESTS "Set to ON to build UTests" OFF ) OPTION( SCALFMM_BUILD_UTESTS "Set to ON to build UTests" OFF )
...@@ -97,8 +97,8 @@ if( SCALFMM_USE_BLAS ) ...@@ -97,8 +97,8 @@ if( SCALFMM_USE_BLAS )
elseif(SCALFMM_USE_EXTERNAL_BLAS) elseif(SCALFMM_USE_EXTERNAL_BLAS)
MESSAGE(STATUS "BLAS SET BY EXTERNAL PROGRAM = ${BLAS_LIBRARIES}") MESSAGE(STATUS "BLAS SET BY EXTERNAL PROGRAM = ${BLAS_LIBRARIES}")
else() else()
INCLUDE(FindBLAS) #INCLUDE(FindBLAS)
INCLUDE(FindLAPACK) #INCLUDE(FindLAPACK)
endif() endif()
#SET(SCALFMM_LIBRARIES "${SCALFMM_LIBRARIES} ${BLAS_LIBRARIES} ${LAPACK_LIBRARIES}") #SET(SCALFMM_LIBRARIES "${SCALFMM_LIBRARIES} ${BLAS_LIBRARIES} ${LAPACK_LIBRARIES}")
SET(SCALFMM_LIBRARIES ${SCALFMM_LIBRARIES} ${BLAS_LIBRARIES} ${LAPACK_LIBRARIES}) SET(SCALFMM_LIBRARIES ${SCALFMM_LIBRARIES} ${BLAS_LIBRARIES} ${LAPACK_LIBRARIES})
...@@ -33,8 +33,8 @@ SET(ScalFMM_USE_MEM_STATS "@SCALFMM_USE_MEM_STATS@") ...@@ -33,8 +33,8 @@ SET(ScalFMM_USE_MEM_STATS "@SCALFMM_USE_MEM_STATS@")
SET(ScalFMM_LIBRARIES "-L${ScalFMM_LIBRARIES_DIR} -l${ScalFMM_LIBRARY_NAME} ${ScalFMM_LIBRARIES_ADD}" ) SET(ScalFMM_LIBRARIES -L${ScalFMM_LIBRARIES_DIR} -l${ScalFMM_LIBRARY_NAME} ${ScalFMM_LIBRARIES_ADD} )
SET(ScalFMM_INCLUDE_DIRS "${ScalFMM_INCLUDE_DIR} SET(ScalFMM_INCLUDE_DIRS ${ScalFMM_INCLUDE_DIR}
${ScalFMM_INCLUDE_DIR}/Utils ${ScalFMM_INCLUDE_DIR}/Utils
${ScalFMM_INCLUDE_DIR}/Components ${ScalFMM_INCLUDE_DIR}/Components
${ScalFMM_INCLUDE_DIR}/Arranger ${ScalFMM_INCLUDE_DIR}/Arranger
...@@ -43,7 +43,7 @@ SET(ScalFMM_INCLUDE_DIRS "${ScalFMM_INCLUDE_DIR} ...@@ -43,7 +43,7 @@ SET(ScalFMM_INCLUDE_DIRS "${ScalFMM_INCLUDE_DIR}
${ScalFMM_INCLUDE_DIR}/Extensions ${ScalFMM_INCLUDE_DIR}/Extensions
${ScalFMM_INCLUDE_DIR}/Files ${ScalFMM_INCLUDE_DIR}/Files
${ScalFMM_INCLUDE_DIR}/Kernels ${ScalFMM_INCLUDE_DIR}/Kernels
${ScalFMM_INCLUDE_DIR}/Chebyshev") ${ScalFMM_INCLUDE_DIR}/Chebyshev)
#SCALFMM_BUILD_TESTS => OFF #SCALFMM_BUILD_TESTS => OFF
#SCALFMM_BUILD_UTESTS => OFF #SCALFMM_BUILD_UTESTS => OFF
\ No newline at end of file
...@@ -42,8 +42,9 @@ install( TARGETS scalfmm ARCHIVE DESTINATION lib ) ...@@ -42,8 +42,9 @@ install( TARGETS scalfmm ARCHIVE DESTINATION lib )
# Install header # Install header
SET(my_include_dirs "." SET(my_include_dirs "."
"Arranger" "Core" "Utils" "Arranger" "Core" "Utils"
"Chebyshev" "Components" "Extensions" "Kernels/Chebyshev" "Components" "Extensions"
"Containers" "Files" "Kernels/Spherical") "Containers" "Files" "Kernels/Spherical"
"Kernels/P2P" "Kernels/Taylor" "Kernels/ROtation")
FOREACH(my_dir ${my_include_dirs}) FOREACH(my_dir ${my_include_dirs})
file(GLOB file(GLOB
...@@ -17,7 +17,8 @@ ...@@ -17,7 +17,8 @@
#define FBASICPARTICLECONTAINER_HPP #define FBASICPARTICLECONTAINER_HPP
#include "FAbstractParticleContainer.hpp" #include "FAbstractParticleContainer.hpp"
#include "FMath.hpp"
#include "FPoint.hpp"
#include <type_traits> #include <type_traits>
...@@ -104,7 +105,7 @@ public: ...@@ -104,7 +105,7 @@ public:
* @brief getPositions * @brief getPositions
* @return a FReal*[3] to get access to the positions * @return a FReal*[3] to get access to the positions
const FReal*const*const getPositions() const { const FReal* getPositions() const {
return positions; return positions;
...@@ -112,7 +113,7 @@ public: ...@@ -112,7 +113,7 @@ public:
* @brief getWPositions * @brief getWPositions
* @return get the position in write mode * @return get the position in write mode
FReal*const*const getWPositions() { FReal*const* getWPositions() {
