Commit d2d773f3 authored by BRAMAS Berenger's avatar BRAMAS Berenger
Remove some warnings and add the patch for the omp to starpu auto version
parent c46cba15
...@@ -111,8 +111,12 @@ else() ...@@ -111,8 +111,12 @@ else()
# NOT INTEL # NOT INTEL
if(NOT ${ScalFMM_USE_MPI}) if(NOT ${ScalFMM_USE_MPI})
SET(ScaLFMM_CXX_FLAGS "${ScaLFMM_CXX_FLAGS} -Wzero-as-null-pointer-constant") SET(ScaLFMM_CXX_FLAGS "${ScaLFMM_CXX_FLAGS} -Wzero-as-null-pointer-constant")
else() else()
SET(ScaLFMM_CXX_FLAGS "${ScaLFMM_CXX_FLAGS} -Wno-literal-suffix") include(CheckCCompilerFlag)
check_c_compiler_flag(-Wno-literal-suffix HAS_NO_LITERAL_SUFFIX_FLAG)
if(HAS_NO_LITERAL_SUFFIX_FLAG)
endif()
endif() endif()
SET(AVX_FLAGS "-mtune=native -march=native") SET(AVX_FLAGS "-mtune=native -march=native")
IF (APPLE) IF (APPLE)
...@@ -118,7 +118,7 @@ int main(int argc, char* argv[]) ...@@ -118,7 +118,7 @@ int main(int argc, char* argv[])
#ifdef _OPENMP #ifdef _OPENMP
omp_set_num_threads(NbThreads); omp_set_num_threads(NbThreads);
#else #else
std::cout << "\n>> Sequential version.\n" << std:: std::cout << "\n>> Sequential version.\n" << std::endl;
#endif #endif
std::cout << "Parameters "<< std::endl std::cout << "Parameters "<< std::endl
...@@ -22,6 +22,16 @@ enum FSmartPointerType{ ...@@ -22,6 +22,16 @@ enum FSmartPointerType{
FSmartPointerMemory FSmartPointerMemory
template <FSmartPointerType MemoryType, class ClassType>
inline typename std::enable_if<(MemoryType == FSmartArrayMemory), void>::type FSmartDeletePointer(ClassType* ptr){
delete ptr;
inline typename std::enable_if<(MemoryType == FSmartPointerMemory), void>::type FSmartDeletePointer(ClassType* ptr){
delete[] ptr;
/** This class is a basic smart pointer class /** This class is a basic smart pointer class
* Use as FSmartPointer<int> array = new int[5]; * Use as FSmartPointer<int> array = new int[5];
* FSmartPointer<int, PointerMemory> pt = new int; * FSmartPointer<int, PointerMemory> pt = new int;
...@@ -87,8 +97,7 @@ public: ...@@ -87,8 +97,7 @@ public:
if(counter){ if(counter){
(*counter) -= 1; (*counter) -= 1;
if( (*counter) == 0 ){ if( (*counter) == 0 ){
if(MemoryType == FSmartArrayMemory) delete[] pointer; FSmartDeletePointer<MemoryType>(pointer);
else if(MemoryType == FSmartPointerMemory) delete pointer;
delete counter; delete counter;
pointer = nullptr; pointer = nullptr;
...@@ -26,6 +26,14 @@ ...@@ -26,6 +26,14 @@
#include <smmintrin.h> // SSE4 #include <smmintrin.h> // SSE4
#endif #endif
#ifndef _mm_set_pd1
// Looks like clang's emmintrin.h doesn't have this alternate name.
// But _mm_set1_pd is an equivalent to _mm_set_pd1.
#define _mm_set_pd1 _mm_set1_pd
#endif
#ifdef __SSEPE_INTEL_COMPILER #ifdef __SSEPE_INTEL_COMPILER
inline __m128d& operator+=(__m128d& v1, const __m128d& v2){ inline __m128d& operator+=(__m128d& v1, const __m128d& v2){
...@@ -231,8 +231,9 @@ int main(int argc, char ** argv){ ...@@ -231,8 +231,9 @@ int main(int argc, char ** argv){
typedef FRotationKernel< CellClass, ContainerClass,7 > KernelClass; typedef FRotationKernel< CellClass, ContainerClass,7 > KernelClass;
typedef FFmmAlgorithmThreadProc<OctreeClass, CellClass, ContainerClass, KernelClass, LeafClass > FmmClass; typedef FFmmAlgorithmThreadProc<OctreeClass, CellClass, ContainerClass, KernelClass, LeafClass > FmmClass;
#ifdef VALIDATE_FMM
typedef FFmmAlgorithmThread<OctreeClass, CellClass, ContainerClass, KernelClass, LeafClass > FmmClassNoProc; typedef FFmmAlgorithmThread<OctreeClass, CellClass, ContainerClass, KernelClass, LeafClass > FmmClassNoProc;
#endif
///////////////////////What we do///////////////////////////// ///////////////////////What we do/////////////////////////////
std::cout << ">> This executable has to be used to test Proc Rotation algorithm.\n"; std::cout << ">> This executable has to be used to test Proc Rotation algorithm.\n";
...@@ -125,7 +125,6 @@ int main(int argc, char ** argv){ ...@@ -125,7 +125,6 @@ int main(int argc, char ** argv){
// COMPUTATION // COMPUTATION
FReal denergy = 0.0;
// computation // computation
...@@ -64,7 +64,6 @@ int main(int argc, char ** argv){ ...@@ -64,7 +64,6 @@ int main(int argc, char ** argv){
typedef FSphericalBlockBlasKernel< CellClass, ContainerClass > KernelClass; typedef FSphericalBlockBlasKernel< CellClass, ContainerClass > KernelClass;
...@@ -122,7 +122,7 @@ class TestMpiQs : public FUTesterMpi<TestMpiQs> { ...@@ -122,7 +122,7 @@ class TestMpiQs : public FUTesterMpi<TestMpiQs> {
void TestSmallSort(){ void TestSmallSort(){
const int myRank = app.global().processId(); //const int myRank = app.global().processId();
const int nbProcess = app.global().processCount(); const int nbProcess = app.global().processCount();
const int nbElements = nbProcess; const int nbElements = nbProcess;
...@@ -170,7 +170,7 @@ class TestMpiQs : public FUTesterMpi<TestMpiQs> { ...@@ -170,7 +170,7 @@ class TestMpiQs : public FUTesterMpi<TestMpiQs> {
void TestSameSort(){ void TestSameSort(){
const int nbElements = nbProcess * 100; const int nbElements = nbProcess * 100;
...@@ -219,8 +219,8 @@ class TestMpiQs : public FUTesterMpi<TestMpiQs> { ...@@ -219,8 +219,8 @@ class TestMpiQs : public FUTesterMpi<TestMpiQs> {
void TestBigSort(){ void TestBigSort(){
const int nbProcess = app.global().processCount(); //const int nbProcess = app.global().processCount();
const int nbElements = 500; const int nbElements = 500;
std::unique_ptr<long[]> elements(new long[nbElements]); std::unique_ptr<long[]> elements(new long[nbElements]);
...@@ -245,8 +245,8 @@ class TestMpiQs : public FUTesterMpi<TestMpiQs> { ...@@ -245,8 +245,8 @@ class TestMpiQs : public FUTesterMpi<TestMpiQs> {
void TestPivotSort(){ void TestPivotSort(){
...@@ -138,7 +138,7 @@ int main(int argc, char ** argv){ ...@@ -138,7 +138,7 @@ int main(int argc, char ** argv){
double boxsize[3] ; double boxsize[3] ;
FPoint centre ; FPoint centre ;
FSize numberofParticles ; FSize numberofParticles = 0;
double energy = 0.0 ; double energy = 0.0 ;
FmaRWParticle<8,8>* particlesIn ; //= new FmaRWParticle<8,8>[numberofParticles]; FmaRWParticle<8,8>* particlesIn ; //= new FmaRWParticle<8,8>[numberofParticles];
if( FParameters::existParameter(argc, argv, "-energy") ){ if( FParameters::existParameter(argc, argv, "-energy") ){
...@@ -203,7 +203,7 @@ int main(int argc, char ** argv){ ...@@ -203,7 +203,7 @@ int main(int argc, char ** argv){
// const --> then shared // const --> then shared
double totalCharge = 0.0, readEnergy; double totalCharge = 0.0, readEnergy = 0.0;
for(int idxPart = 0 ; idxPart < numberofParticles; ++idxPart){ for(int idxPart = 0 ; idxPart < numberofParticles; ++idxPart){
...@@ -241,7 +241,7 @@ int main(int argc, char ** argv){ ...@@ -241,7 +241,7 @@ int main(int argc, char ** argv){
else if( FParameters::existParameter(argc, argv, "-FMM2Ewald") ){ else if( FParameters::existParameter(argc, argv, "-FMM2Ewald") ){
preScaleEnergy = 1.0 ; postScaleEnergy = scaleEnergy ; preScaleForce = 1.0; postScaleForce = scaleForce ; preScaleEnergy = 1.0 ; postScaleEnergy = scaleEnergy ; preScaleForce = 1.0; postScaleForce = scaleForce ;
coeffCorrection = coeffCorrection; //coeffCorrection = coeffCorrection;
else { else {
std::cout << " -Ewald2FMM or -FMM2Ewald should be set"<<std::endl; std::cout << " -Ewald2FMM or -FMM2Ewald should be set"<<std::endl;
