Commit ca4d9b44 authored by BRAMAS Berenger's avatar BRAMAS Berenger
Update cmake to factorize librairies research
parent 27d3ea79
cmake_minimum_required (VERSION 2.8) cmake_minimum_required (VERSION 2.8.5)
# check if compiling into source directories # check if compiling into source directories
STRING(COMPARE EQUAL "${CMAKE_SOURCE_DIR}" "${CMAKE_BINARY_DIR}" insource) STRING(COMPARE EQUAL "${CMAKE_SOURCE_DIR}" "${CMAKE_BINARY_DIR}" insource)
...@@ -31,7 +31,6 @@ OPTION( SCALFMM_ATTACHE_SOURCE "Set to ON to compile with -g" OFF ) ...@@ -31,7 +31,6 @@ OPTION( SCALFMM_ATTACHE_SOURCE "Set to ON to compile with -g" OFF )
OPTION( SCALFMM_USE_STARPU "Set to ON to use starpu" OFF ) OPTION( SCALFMM_USE_STARPU "Set to ON to use starpu" OFF )
# Test if openmp is here # Test if openmp is here
set(CMAKE_MODULE_PATH ${CMAKE_SOURCE_DIR}/CMake) set(CMAKE_MODULE_PATH ${CMAKE_SOURCE_DIR}/CMake)
find_package(OpenMP) find_package(OpenMP)
...@@ -89,9 +88,25 @@ ADD_DEFINITIONS(-Wall -Wshadow -Wpointer-arith -Wcast-qual -Wconversion) ...@@ -89,9 +88,25 @@ ADD_DEFINITIONS(-Wall -Wshadow -Wpointer-arith -Wcast-qual -Wconversion)
CONFIGURE_FILE( ${CMAKE_SOURCE_DIR}/Src/ScalFmmConfig.h.cmake CONFIGURE_FILE( ${CMAKE_SOURCE_DIR}/Src/ScalFmmConfig.h.cmake
${CMAKE_BINARY_DIR}/Src/ScalFmmConfig.h ) ${CMAKE_BINARY_DIR}/Src/ScalFmmConfig.h )
# Use Mem stats
MESSAGE( STATUS "SCALFMM_USE_MEM_STATS = ${SCALFMM_USE_MEM_STATS}" )
include(FindOpenMP)
if(OPENMP_FOUND)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} ${OpenMP_CXX_FLAGS}")
set(CMAKE_EXE_LINKER_FLAGS "${CMAKE_EXE_LINKER_FLAGS} ${OpenMP_EXE_LINKER_FLAGS}")
endif()
# Add CBLAS
set(CMAKE_EXE_LINKER_FLAGS "${CMAKE_EXE_LINKER_FLAGS} ${CBLAS_LIBRARIES}")
# Build - lib # Build - lib
add_subdirectory(Src) add_subdirectory(Src)
# Link with scalfmm lib
set(scalfmm_lib scalfmm)
# Build - Tests # Build - Tests
MESSAGE( STATUS "SCALFMM_BUILD_TESTS = ${SCALFMM_BUILD_TESTS}" ) MESSAGE( STATUS "SCALFMM_BUILD_TESTS = ${SCALFMM_BUILD_TESTS}" )
if( SCALFMM_BUILD_TESTS ) if( SCALFMM_BUILD_TESTS )
...@@ -105,9 +120,6 @@ if( SCALFMM_BUILD_UTESTS ) ...@@ -105,9 +120,6 @@ if( SCALFMM_BUILD_UTESTS )
add_subdirectory(UTests) add_subdirectory(UTests)
endif() endif()
# Use Mem stats
# Build - doc # Build - doc
add_subdirectory(Doc) add_subdirectory(Doc)
cmake_minimum_required(VERSION 2.8) cmake_minimum_required(VERSION 2.8.5)
...@@ -29,6 +29,8 @@ add_library( ...@@ -29,6 +29,8 @@ add_library(
target_link_libraries( target_link_libraries(
scalfmm scalfmm
${BLAS_LIBRARIES} ${BLAS_LIBRARIES}
${LAPACK_LIBRARIES}
${STARPU_LIBRARIES}
# Adding the entire project dir as an include dir # Adding the entire project dir as an include dir
...@@ -9,19 +9,6 @@ endif(insource) ...@@ -9,19 +9,6 @@ endif(insource)
project(Tests_scalfmm CXX) project(Tests_scalfmm CXX)
set(EXECUTABLE_OUTPUT_PATH ${CMAKE_BUILD_TYPE}) set(EXECUTABLE_OUTPUT_PATH ${CMAKE_BUILD_TYPE})
include(FindOpenMP)
if(OPENMP_FOUND)
endif()
# Add CBLAS
# Find all code files # Find all code files
file( file(
GLOB_RECURSE GLOB_RECURSE
cmake_minimum_required (VERSION 2.6) cmake_minimum_required (VERSION 2.8.5)
project(UTests_scalfmm CXX) project(UTests_scalfmm CXX)
include(FindOpenMP)
if(OPENMP_FOUND)
endif()
# Add CBLAS
file( file(
