Commit c9a00713 authored by BRAMAS Berenger's avatar BRAMAS Berenger
update the kernel copies and use a more clean code
parent f8253c77
...@@ -77,11 +77,11 @@ public: ...@@ -77,11 +77,11 @@ public:
FAssertLF(leafLevelSeparationCriteria < 3, "Separation criteria should be < 3"); FAssertLF(leafLevelSeparationCriteria < 3, "Separation criteria should be < 3");
this->kernels = new KernelClass*[MaxThreads]; this->kernels = new KernelClass*[MaxThreads];
#pragma omp parallel for schedule(static) #pragma omp parallel num_threads(MaxThreads)
for(int idxThread = 0 ; idxThread < MaxThreads ; ++idxThread){ {
#pragma omp critical (InitFFmmAlgorithmSectionTask) #pragma omp critical (InitFFmmAlgorithmSectionTask)
this->kernels[idxThread] = new KernelClass(*inKernels); this->kernels[omp_get_thread_num()] = new KernelClass(*inKernels);
...@@ -66,13 +66,13 @@ public: ...@@ -66,13 +66,13 @@ public:
#pragma omp critical (InitFFmmAlgorithmTask) #pragma omp critical (InitFFmmAlgorithmTask)
FAbstractAlgorithm::setNbLevelsInTree(tree->getHeight()); FAbstractAlgorithm::setNbLevelsInTree(tree->getHeight());
...@@ -85,11 +85,11 @@ public: ...@@ -85,11 +85,11 @@ public:
FAssertLF(0 < userChunkSize, "Chunk size should be > 0"); FAssertLF(0 < userChunkSize, "Chunk size should be > 0");
#pragma omp critical (InitFFmmAlgorithmThread) #pragma omp critical (InitFFmmAlgorithmThread)
...@@ -62,11 +62,11 @@ public: ...@@ -62,11 +62,11 @@ public:
#pragma omp critical (InitFFmmAlgorithmThreadBalance) #pragma omp critical (InitFFmmAlgorithmThreadBalance)
...@@ -157,11 +157,11 @@ public: ...@@ -157,11 +157,11 @@ public:
#pragma omp critical (InitFFmmAlgorithmThreadProc) #pragma omp critical (InitFFmmAlgorithmThreadProc)
...@@ -117,11 +117,11 @@ public: ...@@ -117,11 +117,11 @@ public:
void setKernel(KernelClass*const inKernels){ void setKernel(KernelClass*const inKernels){
#pragma omp critical (InitFFmmAlgorithmThreadProcPeriodic) #pragma omp critical (InitFFmmAlgorithmThreadProcPeriodic)
...@@ -71,11 +71,11 @@ public: ...@@ -71,11 +71,11 @@ public:
#pragma omp critical (InitFFmmAlgorithmThreadTsm) #pragma omp critical (InitFFmmAlgorithmTsm)
