GitLab
Support
Community forum
Keyboard shortcuts
S
ScalFMM
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
solverstack
ScalFMM
c51c84a5
c51c84a5
COULAUD Olivier
Mv files
363bcf5c
5
5 changed files
79 additions
+79
Data/noDist/Readme
Data/noDist/Readme
+0
Data/noDist/ellipsoid-bug.fma
+0
Tests/noDist/testNewCompareKernels.cpp
+0
Utils/CMakeLists.txt
+78
Utils/email-sorted
Utils/email-sorted
+1
Data/Readme
Data/
noDist/
Readme
c51c84a5
File moved
Data/ellipsoid-bug.fma
Data/
noDist/
ellipsoid-bug.fma
c51c84a5
File moved
Tests/
Kernels
Tests/
noDist
c51c84a5
File moved
0 → 100755
c51c84a5
# check if compiling into source directories
STRING
COMPARE EQUAL
CMAKE_SOURCE_DIR
CMAKE_BINARY_DIR
insource
if
insource
MESSAGE
FATAL_ERROR
PROJECT_NAME
requires an out of source build. Goto scalfmm/Build and tapes cmake ../"
endif
insource
project
Examples_scalfmm CXX
set
EXECUTABLE_OUTPUT_PATH
CMAKE_BUILD_TYPE
ADD_DEFINITIONS
ScaLFMM_CXX_FLAGS
# Find all code files
file
GLOB_RECURSE
source_tests_files
./*.cpp
# Adding the project sources dir as an include dir
INCLUDE_DIRECTORIES
CMAKE_BINARY_DIR
/Src
CMAKE_SOURCE_DIR
/Src
# Add execs - 1 cpp = 1 exec
foreach
exec
source_tests_files
get_filename_component
execname
exec
NAME_WE
set
compile_exec
"TRUE"
# Test Blas dependency
file
STRINGS
exec
lines_blas REGEX
"@FUSE_BLAS"
if
lines_blas
if
NOT ScalFMM_USE_BLAS
MESSAGE
STATUS
"This needs BLAS =
exec
set
compile_exec
"FALSE"
endif
endif
# Test FFT dependency
file
STRINGS
exec
lines_fft REGEX
"@FUSE_FFT"
if
lines_fft
if
NOT ScalFMM_USE_FFT
MESSAGE
STATUS
"This needs FFT =
exec
set
compile_exec
"FALSE"
endif
endif
# Test MPI dependency
file
STRINGS
exec
lines_mpi REGEX
"@FUSE_MPI"
if
lines_mpi
if
NOT ScalFMM_USE_MPI
MESSAGE
STATUS
"This needs MPI =
exec
set
compile_exec
"FALSE"
endif
endif
# Dependency are OK
if
compile_exec
add_executable
execname
exec
SET_TARGET_PROPERTIES
execname
PROPERTIES ENABLE_EXPORTS TRUE
target_link_libraries
execname
scalfmm_lib
SCALFMM_LIBRARIES
# Install bin
install
TARGETS
execname
DESTINATION bin
endif
endforeach
exec
ToRemove
/email-sorted
Utils
/email-sorted
c51c84a5
@@ -33,6 +33,7 @@ shujin.cao@163.com
t.ben.thompson@gmail.com
t.betcke@ucl.ac.uk
t.betcke@ucl.ac.uk
vitoreafeliciano@msn.com
wangjun5505@163.com
weygand@kit.edu
weygand@kit.edu
wgs@theworld.com
wgs@theworld.com
zcos123@gmail.com
zcos123@gmail.com
