Commit c11b93f9 authored by BRAMAS Berenger's avatar BRAMAS Berenger
prepare the usage of symbolic and numeric block in the OMP4
parent 7f3efcf9
...@@ -19,7 +19,8 @@ ...@@ -19,7 +19,8 @@
#include <omp.h> #include <omp.h>
template <class OctreeClass, class CellContainerClass, class CellClass, class KernelClass, class ParticleGroupClass, class ParticleContainerClass> template <class OctreeClass, class CellContainerClass, class CellClass,
class SymboleCellClass, class PoleCellClass, class LocalCellClass, class KernelClass, class ParticleGroupClass, class ParticleContainerClass>
class FGroupTaskDepAlgorithm { class FGroupTaskDepAlgorithm {
protected: protected:
template <class OtherBlockClass> template <class OtherBlockClass>
...@@ -42,8 +43,14 @@ public: ...@@ -42,8 +43,14 @@ public:
FAssertLF(inKernels, "kernels cannot be null"); FAssertLF(inKernels, "kernels cannot be null");
kernels = new KernelClass*[MaxThreads]; kernels = new KernelClass*[MaxThreads];
#pragma omp parallel for schedule(static)
for(int idxThread = 0 ; idxThread < MaxThreads ; ++idxThread){ for(int idxThread = 0 ; idxThread < MaxThreads ; ++idxThread){
this->kernels[idxThread] = new KernelClass(*inKernels); // We want to ensure that each thread allocate data close to him
// and that only one thread at a time call the copy constructor
#pragma omp critical (FGroupTaskDepAlgorithm_InitKernels)
FLOG(FLog::Controller << "FGroupTaskDepAlgorithm (Max Thread " << MaxThreads << ")\n"); FLOG(FLog::Controller << "FGroupTaskDepAlgorithm (Max Thread " << MaxThreads << ")\n");
...@@ -68,7 +68,8 @@ int main(int argc, char* argv[]){ ...@@ -68,7 +68,8 @@ int main(int argc, char* argv[]){
typedef FTestKernels< GroupCellClass, GroupContainerClass > GroupKernelClass; typedef FTestKernels< GroupCellClass, GroupContainerClass > GroupKernelClass;
// Set the number of threads // Set the number of threads
omp_set_num_threads(FParameters::getValue(argc,argv,FParameterDefinitions::NbThreads.options, omp_get_max_threads())); omp_set_num_threads(FParameters::getValue(argc,argv,FParameterDefinitions::NbThreads.options, omp_get_max_threads()));
typedef FGroupTaskDepAlgorithm<GroupOctreeClass, typename GroupOctreeClass::CellGroupClass, GroupCellClass, GroupKernelClass, typename GroupOctreeClass::ParticleGroupClass, GroupContainerClass > GroupAlgorithm; typedef FGroupTaskDepAlgorithm<GroupOctreeClass, typename GroupOctreeClass::CellGroupClass, GroupCellClass,
GroupCellSymbClass, GroupCellUpClass, GroupCellDownClass, GroupKernelClass, typename GroupOctreeClass::ParticleGroupClass, GroupContainerClass > GroupAlgorithm;
#else #else
//typedef FGroupSeqAlgorithm<GroupOctreeClass, typename GroupOctreeClass::CellGroupClass, GroupCellClass, GroupKernelClass, typename GroupOctreeClass::ParticleGroupClass, GroupContainerClass > GroupAlgorithm; //typedef FGroupSeqAlgorithm<GroupOctreeClass, typename GroupOctreeClass::CellGroupClass, GroupCellClass, GroupKernelClass, typename GroupOctreeClass::ParticleGroupClass, GroupContainerClass > GroupAlgorithm;
...@@ -77,7 +77,8 @@ int main(int argc, char* argv[]){ ...@@ -77,7 +77,8 @@ int main(int argc, char* argv[]){
typedef FChebSymKernel<GroupCellClass,GroupContainerClass,MatrixKernelClass,ORDER> GroupKernelClass; typedef FChebSymKernel<GroupCellClass,GroupContainerClass,MatrixKernelClass,ORDER> GroupKernelClass;
GroupCellSymbClass, GroupCellUpClass, GroupCellDownClass,, GroupKernelClass, typename GroupOctreeClass::ParticleGroupClass, GroupContainerClass > GroupAlgorithm;
#else #else
...@@ -63,7 +63,8 @@ int main(int argc, char* argv[]){ ...@@ -63,7 +63,8 @@ int main(int argc, char* argv[]){
typedef FRotationKernel< GroupCellClass, GroupContainerClass , P> GroupKernelClass; typedef FRotationKernel< GroupCellClass, GroupContainerClass , P> GroupKernelClass;
#else #else
typedef FTaylorKernel< GroupCellClass, GroupContainerClass , P,1> GroupKernelClass; typedef FTaylorKernel< GroupCellClass, GroupContainerClass , P,1> GroupKernelClass;
#else #else
...@@ -112,7 +112,8 @@ int main(int argc, char* argv[]){ ...@@ -112,7 +112,8 @@ int main(int argc, char* argv[]){
#else #else
...@@ -78,7 +78,8 @@ int main(int argc, char* argv[]){ ...@@ -78,7 +78,8 @@ int main(int argc, char* argv[]){
typedef FUnifKernel<GroupCellClass,GroupContainerClass,MatrixKernelClass,ORDER> GroupKernelClass; typedef FUnifKernel<GroupCellClass,GroupContainerClass,MatrixKernelClass,ORDER> GroupKernelClass;
#else #else
