Commit bb6c85b8 authored by Martin Khannouz's avatar Martin Khannouz Committed by Berenger Bramas
Fix R script and remove previous scale
parent f070c4a2
...@@ -7,6 +7,7 @@ calc_normalized_time <- function(data, ref_name) ...@@ -7,6 +7,7 @@ calc_normalized_time <- function(data, ref_name)
dataref <- subset(data, algo == get_one_node_reference_algorithm()) dataref <- subset(data, algo == get_one_node_reference_algorithm())
# XXX: Most likely suboptimal but it works as expected! # XXX: Most likely suboptimal but it works as expected!
data$efficiency <- 0
for (i in 1:length(ref_name)) { for (i in 1:length(ref_name)) {
for (j in 1:nrow(data)) { for (j in 1:nrow(data)) {
if (data$algo[j] == ref_name[i]) { if (data$algo[j] == ref_name[i]) {
...@@ -60,7 +61,6 @@ gen_normalized_time_plot <- function(db, d_breaks, model_wanted) ...@@ -60,7 +61,6 @@ gen_normalized_time_plot <- function(db, d_breaks, model_wanted)
g <- g + xlab("Number of nodes") g <- g + xlab("Number of nodes")
g <- g + ylab("Normalized time") g <- g + ylab("Normalized time")
#g <- g + scale_x_continuous(breaks=c(1, 2, 3, 4, 5, 6, 9, 12, 16, 20, 24))
# Save generated plot. # Save generated plot.
output <- paste(get_output_directory(), "/", model_wanted, "-normalized-time.pdf", sep="") output <- paste(get_output_directory(), "/", model_wanted, "-normalized-time.pdf", sep="")
