Commit a5a3a53a authored by BRAMAS Berenger's avatar BRAMAS Berenger
wip starpu opencl but there still a problem of moving the data back
parent 1a2c4fdd
...@@ -405,26 +405,72 @@ void P2M(__global unsigned char* pole, const struct FOpenCLGroupAttachedLeaf par ...@@ -405,26 +405,72 @@ void P2M(__global unsigned char* pole, const struct FOpenCLGroupAttachedLeaf par
void M2M(__global unsigned char* pole, __global unsigned char* child[8], const int level, __global void* user_data) { void M2M(__global unsigned char* pole, __global unsigned char* child[8], const int level, __global void* user_data) {
__global long long* up = (__global long long*)(pole+FCellUpOffset);
for(int idxChild = 0 ; idxChild < 8 ; ++idxChild){
if(child[idxChild]){
const __global long long* childup = (const __global long long*)(child[idxChild]+FCellUpOffset);
(*up) += (*childup);
void M2L(__global unsigned char* const pole, const __global unsigned char* distantNeighbors[343], void M2L(__global unsigned char* const pole, const __global unsigned char* distantNeighbors[343],
const int size, const int level, __global void* user_data) { const int size, const int level, __global void* user_data) {
__global long long* down = (__global long long*)(pole+FCellDownOffset);
for(int idxNeigh = 0 ; idxNeigh < 343 ; ++idxNeigh){
if(distantNeighbors[idxNeigh]){
const __global long long* neighup = (const __global long long*)(distantNeighbors[idxNeigh]+FCellUpOffset);
(*down) += (*neighup);
void L2L(__global const unsigned char* localCell, __global unsigned char* child[8], const int level, __global void* user_data) { void L2L(__global const unsigned char* localCell, __global unsigned char* child[8], const int level, __global void* user_data) {
const __global long long* down = (const __global long long*)(localCell+FCellDownOffset);
__global long long* childdown = (__global long long*)(child[idxChild]+FCellDownOffset);
(*childdown) += (*down);
void L2P(__global const unsigned char* localCell, struct FOpenCLGroupAttachedLeaf particles, __global void* user_data){ void L2P(__global const unsigned char* localCell, struct FOpenCLGroupAttachedLeaf particles, __global void* user_data){
__global long long* partdown = particles.attributes[0];
for(int idxPart = 0 ; idxPart < particles.nbParticles ; ++idxPart){
partdown[idxPart] += (*down);
void P2P(const int3 pos, void P2P(const int3 pos,
struct FOpenCLGroupAttachedLeaf targets, const struct FOpenCLGroupAttachedLeaf sources, struct FOpenCLGroupAttachedLeaf targets, const struct FOpenCLGroupAttachedLeaf sources,
struct FOpenCLGroupAttachedLeaf directNeighborsParticles[27], int directNeighborsPositions[27], const int counter, __global void* user_data){ struct FOpenCLGroupAttachedLeaf directNeighborsParticles[27], int directNeighborsPositions[27], const int counter, __global void* user_data){
return;// TODO
long long cumul = sources.nbParticles-1;
for(int idxNeigh = 0 ; idxNeigh < 27 ; ++idxNeigh){
if(FOpenCLGroupAttachedLeaf_isAttachedToSomething(&directNeighborsParticles[idxNeigh])){
cumul += directNeighborsParticles[idxNeigh].nbParticles;
__global long long* partdown = targets.attributes[0];
for(int idxPart = 0 ; idxPart < targets.nbParticles ; ++idxPart){
partdown[idxPart] += cumul;
void P2PRemote(const int3 pos, void P2PRemote(const int3 pos,
struct FOpenCLGroupAttachedLeaf directNeighborsParticles, const int position, __global void* user_data){ struct FOpenCLGroupAttachedLeaf directNeighborsParticles, const int position, __global void* user_data){
return;// TODO
partdown[idxPart] += directNeighborsParticles.nbParticles;
MortonIndex getMortonIndex(__global const unsigned char* cell, __global void* user_data) { MortonIndex getMortonIndex(__global const unsigned char* cell, __global void* user_data) {
...@@ -475,10 +521,10 @@ __kernel void FOpenCL__bottomPassPerform(__global unsigned char* leafCellsPtr, s ...@@ -475,10 +521,10 @@ __kernel void FOpenCL__bottomPassPerform(__global unsigned char* leafCellsPtr, s
FOpenCLAssertLF(getMortonIndex(cell, userkernel) == mindex); FOpenCLAssertLF(getMortonIndex(cell, userkernel) == mindex);
struct FOpenCLGroupAttachedLeaf particles = FOpenCLGroupOfParticles_getLeaf(&containers, mindex); struct FOpenCLGroupAttachedLeaf particles = FOpenCLGroupOfParticles_getLeaf(&containers, mindex);
FOpenCLAssertLF(FOpenCLGroupAttachedLeaf_isAttachedToSomething(&particles)); FOpenCLAssertLF(FOpenCLGroupAttachedLeaf_isAttachedToSomething(&particles));
//P2M(cell, particles, userkernel); P2M(cell, particles, userkernel);
for(int idx = 0 ; idx < FCellClassSize ; ++idx){ /*for(int idx = 0 ; idx < FCellClassSize ; ++idx){
cell[idx] = 'z'; cell[idx] = 'z';
/*output[0] = blockStartIdx; /*output[0] = blockStartIdx;
output[1] = blockEndIdx; output[1] = blockEndIdx;
output[2] = particles.nbParticles; output[2] = particles.nbParticles;
