Commit 9d5a03e4 authored by Berenger Bramas's avatar Berenger Bramas
Update M2L
parent b6a71aab
...@@ -406,23 +406,27 @@ public: ...@@ -406,23 +406,27 @@ public:
size_t extractGetSizeSymbUp(const std::vector<int>& cellsToExtract) const { size_t extractGetSizeSymbUp(const std::vector<int>& cellsToExtract) const {
return cellsToExtract.size() * sizeof(SymboleCellClass) * sizeof(PoleCellClass); return cellsToExtract.size() * (sizeof(SymboleCellClass) + sizeof(PoleCellClass));
void extractDataUp(const std::vector<int>& cellsToExtract, void extractDataUp(const std::vector<int>& cellsToExtract,
unsigned char* outputBuffer, const size_t outputBufferSize) const { unsigned char* outputBuffer, const size_t outputBufferSize) const {
FAssertLF(outputBuffer || outputBufferSize == 0);
size_t idxValue = 0; size_t idxValue = 0;
for(size_t idxEx = 0 ; idxEx < cellsToExtract.size() ; ++idxEx){ for(size_t idxEx = 0 ; idxEx < cellsToExtract.size() ; ++idxEx){
const int idCell = cellsToExtract[idxEx]; const int idCell = cellsToExtract[idxEx];
FAssertLF(idCell < blockHeader->numberOfCellsInBlock);
memcpy(&outputBuffer[idxValue], memcpy(&outputBuffer[idxValue],
&blockCells[idCell], &blockCells[idCell],
sizeof(SymboleCellClass)); sizeof(SymboleCellClass));
idxValue += sizeof(SymboleCellClass); idxValue += sizeof(SymboleCellClass);
FAssertLF(idxValue <= outputBufferSize);
&cellMultipoles[idCell], &cellMultipoles[idCell],
sizeof(PoleCellClass)); sizeof(PoleCellClass));
idxValue += sizeof(PoleCellClass); idxValue += sizeof(PoleCellClass);
FAssertLF(idxValue == outputBufferSize); FAssertLF(idxValue == outputBufferSize);
...@@ -445,7 +449,7 @@ public: ...@@ -445,7 +449,7 @@ public:
size_t extractGetSizeSymbDown(const std::vector<int>& cellsToExtract) const { size_t extractGetSizeSymbDown(const std::vector<int>& cellsToExtract) const {
return cellsToExtract.size() * sizeof(SymboleCellClass) * sizeof(LocalCellClass); return cellsToExtract.size() * (sizeof(SymboleCellClass) + sizeof(LocalCellClass));
void extractDataDown(const std::vector<int>& cellsToExtract, void extractDataDown(const std::vector<int>& cellsToExtract,
...@@ -852,9 +852,10 @@ protected: ...@@ -852,9 +852,10 @@ protected:
cell_extract_up.where |= STARPU_CPU; cell_extract_up.where |= STARPU_CPU;
memset(&cell_insert_up, 0, sizeof(cell_insert_up)); memset(&cell_insert_up, 0, sizeof(cell_insert_up));
cell_extract_up.nbuffers = 3; cell_insert_up.nbuffers = 3;
cell_insert_up.modes[0] = STARPU_R; cell_insert_up.modes[0] = STARPU_R;
cell_insert_up.modes[1] = STARPU_RW; cell_insert_up.modes[1] = STARPU_RW;
cell_insert_up.modes[2] = STARPU_RW;
cell_insert_up.name = "cell_insert_up"; cell_insert_up.name = "cell_insert_up";
cell_insert_up.cpu_funcs[0] = ThisClass::InsertCellUp; cell_insert_up.cpu_funcs[0] = ThisClass::InsertCellUp;
cell_insert_up.where |= STARPU_CPU; cell_insert_up.where |= STARPU_CPU;
...@@ -889,29 +890,29 @@ protected: ...@@ -889,29 +890,29 @@ protected:
static void InsertCellUp(void *buffers[], void *cl_arg){ static void InsertCellUp(void *buffers[], void *cl_arg){
CellContainerClass currentCells((unsigned char*)STARPU_VECTOR_GET_PTR(buffers[1]), CellContainerClass currentCells((unsigned char*)STARPU_VECTOR_GET_PTR(buffers[1]),
STARPU_VECTOR_GET_NX(buffers[1]), STARPU_VECTOR_GET_NX(buffers[1]),
nullptr, (unsigned char*)STARPU_VECTOR_GET_PTR(buffers[2]),
(unsigned char*)STARPU_VECTOR_GET_PTR(buffers[2])); nullptr);
unsigned char* inBuffer = (unsigned char*)STARPU_VECTOR_GET_PTR(buffers[0]);
size_t size = STARPU_VECTOR_GET_NX(buffers[0]);
CellExtractedHandles* interactionBufferPtr; CellExtractedHandles* interactionBufferPtr;
starpu_codelet_unpack_args(cl_arg, &interactionBufferPtr); starpu_codelet_unpack_args(cl_arg, &interactionBufferPtr);
currentCells.restoreDataUp(interactionBufferPtr->cellsToExtract, inBuffer, size); currentCells.restoreDataUp(interactionBufferPtr->cellsToExtract,
(unsigned char*)STARPU_VECTOR_GET_PTR(buffers[0]),
STARPU_VECTOR_GET_NX(buffers[0]));
static void ExtractCellUp(void *buffers[], void *cl_arg){ static void ExtractCellUp(void *buffers[], void *cl_arg){
CellContainerClass currentCells((unsigned char*)STARPU_VECTOR_GET_PTR(buffers[0]), CellContainerClass currentCells((unsigned char*)STARPU_VECTOR_GET_PTR(buffers[0]),
STARPU_VECTOR_GET_NX(buffers[0]), STARPU_VECTOR_GET_NX(buffers[0]),
nullptr, (unsigned char*)STARPU_VECTOR_GET_PTR(buffers[1]),
(unsigned char*)STARPU_VECTOR_GET_PTR(buffers[1])); nullptr);
unsigned char* inBuffer = (unsigned char*)STARPU_VECTOR_GET_PTR(buffers[2]);
size_t size = STARPU_VECTOR_GET_NX(buffers[2]);
currentCells.extractDataUp(interactionBufferPtr->cellsToExtract, inBuffer, size); currentCells.extractDataUp(interactionBufferPtr->cellsToExtract,
STARPU_VECTOR_GET_NX(buffers[2]));
void initCodeletMpi(){ void initCodeletMpi(){
...@@ -1549,8 +1550,9 @@ protected: ...@@ -1549,8 +1550,9 @@ protected:
interactionBuffer.size = tree->getCellGroup(idxLevel,interactionid)->extractGetSizeSymbUp(interactionBuffer.cellsToExtract); interactionBuffer.size = tree->getCellGroup(idxLevel,interactionid)->extractGetSizeSymbUp(interactionBuffer.cellsToExtract);
// I allocate only if I will use it to extract // I allocate only if I will use it to extract
if(starpu_mpi_data_get_rank(cellHandles[idxLevel][interactionid].symb)){ if(starpu_mpi_data_get_rank(cellHandles[idxLevel][interactionid].symb) == mpi_rank){
interactionBuffer.data.reset(new unsigned char[interactionBuffer.size]); interactionBuffer.data.reset(new unsigned char[interactionBuffer.size]);
FAssertLF(interactionBuffer.data);
else{ else{
interactionBuffer.data.reset(nullptr); interactionBuffer.data.reset(nullptr);
...@@ -1655,7 +1657,7 @@ protected: ...@@ -1655,7 +1657,7 @@ protected:
interactionBuffer.size = tree->getCellGroup(idxLevel,idxGroup)->extractGetSizeSymbUp(interactionBuffer.cellsToExtract); interactionBuffer.size = tree->getCellGroup(idxLevel,idxGroup)->extractGetSizeSymbUp(interactionBuffer.cellsToExtract);
if(starpu_mpi_data_get_rank(cellHandles[idxLevel][idxGroup].symb)){ if(starpu_mpi_data_get_rank(cellHandles[idxLevel][idxGroup].symb) == mpi_rank){
else{ else{
...@@ -1725,8 +1727,8 @@ protected: ...@@ -1725,8 +1727,8 @@ protected:
#endif #endif
STARPU_R, cellHandles[idxLevel][interactionid].symb, STARPU_R, cellHandles[idxLevel][interactionid].symb,
(STARPU_RW | STARPU_COMMUTE_IF_SUPPORTED), cellHandles[idxLevel][interactionid].down, (STARPU_RW | STARPU_COMMUTE_IF_SUPPORTED), cellHandles[idxLevel][interactionid].down,
STARPU_RW, duplicateB.symb, STARPU_R, duplicateB.symb,
STARPU_RW, duplicateB.other, STARPU_R, duplicateB.other,
#ifdef STARPU_USE_TASK_NAME #ifdef STARPU_USE_TASK_NAME
#ifndef SCALFMM_SIMGRID_TASKNAMEPARAMS #ifndef SCALFMM_SIMGRID_TASKNAMEPARAMS
STARPU_NAME, m2lOuterTaskNames[idxLevel].get(), STARPU_NAME, m2lOuterTaskNames[idxLevel].get(),
