GitLab
Support
Community forum
Keyboard shortcuts
S
ScalFMM
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
solverstack
ScalFMM
91a33fb1
91a33fb1
COULAUD Olivier
Add Unif and Lagrange in the package_source
Remove data install when ONMY_LIB is selected
70a4fc46
10 additions
6 deletions
+10
-6
CMakeLists.txt
CMakeLists.txt
+10
-6
CMakeLists.txt
91a33fb1
@@ -57,7 +57,7 @@ OPTION( ScalFMM_USE_AVX "Set to ON to compile with AVX support"
OPTION
ScalFMM_USE_ASSERT
"Set to ON to enable safe tests during execution"
ON
OPTION
ScalFMM_USE_ASSERT
ON
OPTION
ScalFMM_USE_MIC_NATIVE
"Set to ON to compile in native mode for MIC"
OFF
OPTION
OFF
OPTION
ScalFMM_BUILD_ONLY_LIB
"Set to ON to compile only the lib (examples are not compiled) "
OFF
OPTION
OFF
OPTION
ScalFMM_ONLY_DEVEL
"Set to ON to compile Development tools (only scalfmm team)"
OFF
OPTION( ScalFMM_ONLY_DEVEL "Set to ON to compile Development tools (only scalfmm team)" OFF )
# Set scalfmm to default libraries
SET
SCALFMM_LIBRARIES
SET
SCALFMM_LIBRARIES
SET
ScaLFMM_CXX_FLAGS
SET
ScaLFMM_CXX_FLAGS
@@ -415,11 +415,14 @@ CONFIGURE_FILE(${ScalFMM_SOURCE_DIR}/ScalFMMConfig.cmake.in
INSTALL
FILES
INSTALL
FILES
ScalFMM_BINARY_DIR
ScalFMM_BINARY_DIR
DESTINATION lib/
DESTINATION lib/
i
INSTALL
FILES
IF
NOT ScalFMM_BUILD_ONLY_LIB
ScalFMM_SOURCE_DIR
/Data/test20k.fma
INSTALL
FILES
DESTINATION Data/
ScalFMM_SOURCE_DIR
/Data/test20k.fma
DESTINATION Data/
endif
# build a CPack driven installer package #
@@ -445,7 +448,8 @@ SET(PACK_PACKAGE_VERSION "${ScalFMM_MAJOR_VERSION}.${ScalFMM_MINOR_VERSION}-${CP
SET
CPACK_SOURCE_GENERATOR
"TGZ"
SET
"TGZ"
SET
CPACK_SOURCE_PACKAGE_FILE_NAME
"ScalFMM-
CPACK_PACKAGE_VERSION_PATCH
SET
"ScalFMM-
SET
CPACK_SOURCE_IGNORE_FILES
.git;.DS_Store;.*~;/*.aux;/*.idx;/*.log;/*.out;/*.toc;/*.ilg;/*.ind;scalfmm.pro*;org.eclipse.core.resources.prefs;.cproject;.project"
SET
LIST
APPEND CPACK_SOURCE_IGNORE_FILES
CMAKE_BINARY_DIR
CMAKE_SOURCE_DIR
/Utils/;Notes;Deprecated;/Build*;/noDist/;/Bench;ToRemove;Olivier;tages;Uniform;GroupTree;Adaptive;testUnif*;/*Lagrange*"
LIST
CMAKE_BINARY_DIR
CMAKE_SOURCE_DIR
/Utils/;Notes;Deprecated;/Build*;/noDist/;/Bench;ToRemove;Olivier"
# Uniform;GroupTree;Adaptive;testUnif*;/*Lagrange*")
#LIST(APPEND CPACK_SOURCE_IGNORE_FILES "Stages;Uniform;Adaptive;testUnif*;*Lagrange*" )
INCLUDE
CPack
INCLUDE
CPack
