Commit 910582b5 authored by BRAMAS Berenger's avatar BRAMAS Berenger
Add copy constructor and operator from rvalue objects for the list and vectro
parent 548c9b34
...@@ -96,6 +96,34 @@ public: ...@@ -96,6 +96,34 @@ public:
copy(other); copy(other);
* Copy operator
* This will clear the current list before copying
* @param other the source list
* @return the current list as a reference
FList& operator=(FList&& other){
if(&other != this){
clear();
root = other.root;
size = other.size;
other.root = nullptr;
other.size = 0;
return *this;
* Copy constructor
* @param other the source/original list
FList(FList&& other): root(nullptr) , size(0) {
root = other.root;
size = other.size;
other.size = 0;
* To clear the list * To clear the list
* Size is 0 after calling this function * Size is 0 after calling this function
...@@ -77,6 +77,20 @@ public: ...@@ -77,6 +77,20 @@ public:
* Copy constructor
* @param other original vector
* object must have an copy constructor
FVector(FVector&& other): array(nullptr), capacity(0), index(0) {
array = other.array;
capacity = other.capacity;
index = other.index;
other.array = nullptr;
other.capacity = 0;
other.index = 0;
/** Copy operator /** Copy operator
* @param other the original vector * @param other the original vector
* @return this after copying data * @return this after copying data
...@@ -103,6 +117,23 @@ public: ...@@ -103,6 +117,23 @@ public:
return *this; return *this;
*@brief Copy operator
FVector& operator=(FVector&& other){
if(&other != this){
clear();
delete [] reinterpret_cast< char* >(array);
other.capacity = 0;
other.index = 0;
return (*this);
*@brief destructor *@brief destructor
Supports Markdown
