Commit 8eb68b68 authored by COULAUD Olivier's avatar COULAUD Olivier
Add output file for Lagrange interpolation
Bug fixed in changeFormat and in stamp2Fma
parent 483333ad
This diff is collapsed.
...@@ -97,7 +97,7 @@ int main(int argc, char ** argv){ ...@@ -97,7 +97,7 @@ int main(int argc, char ** argv){
if(FParameters::existParameter(argc, argv, FParameterDefinitions::OutputVisuFile.options)){ if(FParameters::existParameter(argc, argv, FParameterDefinitions::OutputVisuFile.options)){
std::string outfilename(FParameters::getStr(argc,argv,FParameterDefinitions::OutputFile.options, "output.vtp")); std::string outfilename(FParameters::getStr(argc,argv,FParameterDefinitions::OutputFile.options, "output.vtp"));
driverExportData(outfilename, particles , NbPoints); driverExportData(outfilename, particles , NbPoints,loader->getNbRecordPerline() );
delete particles ; delete particles ;
...@@ -55,7 +55,7 @@ void genDistusage() { ...@@ -55,7 +55,7 @@ void genDistusage() {
<< " -help to see the parameters " << std::endl << " -help to see the parameters " << std::endl
<< " Input: only one option is allowed" << std::endl << " Input: only one option is allowed" << std::endl
<< " -fin name: file name to convert (with extension .fma (ascii) or bfma (binary) " <<std::endl << " -fin name: file name to convert (with extension .fma (ascii) or bfma (binary) " <<std::endl
<< " -fdlpoly name: file name to convert with extension (.bin if binary file) " <<<<std::endl; << " -fdlpoly name: file name to convert with extension (.bin if binary file) " <<std::endl;
int main(int argc, char ** argv){ int main(int argc, char ** argv){
