Commit 8e220e79 authored by COULAUD Olivier's avatar COULAUD Olivier
Add eztrace
parent 248de7af
......@@ -69,6 +69,7 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
option( SCALFMM_USE_ASSERT "Set to ON to enable safe tests during execution" ON )
option( SCALFMM_USE_MIC_NATIVE "Set to ON to compile in native mode for MIC" OFF )
option( SCALFMM_ONLY_DEVEL "Set to ON to compile Development tools (only scalfmm team)" ON )
option( SCALFMM_USE_EZTRACE "Set to ON to compile with eztrace framwork" OFF )
if( SCALFMM_ONLY_DEVEL )
option( OPENMP_SUPPORT_COMMUTE "Set to ON to let tasks commute (KSTAR/StarPU compiler only)" OFF )
option( SCALFMM_USE_STARPU "Set to ON to build SCALFMM with StarPU" OFF )
......@@ -114,8 +115,8 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
IF (APPLE)
set(SSE_FLAGS "-msse4 -mfpmath=sse") # -mtune=native -march=native
else(APPLE)
set(AVX_FLAGS "-mavx -march=native")
set(AVX2_FLAGS "-mavx2 -march=native")
set(AVX_FLAGS "-mavx")
set(AVX2_FLAGS "-march=core-avx2")
set(SSE_FLAGS "-axSSE4.2 -march=native")
endif(APPLE)
#-Wshadow -Wpointer-arith -Wcast-qual -Wconversion -Wall -Wnosign-conversion ")
......@@ -619,9 +620,27 @@ if (MORSE_DISTRIB_DIR OR EXISTS "${CMAKE_SOURCE_DIR}/CMakeModules/morse/")
list(APPEND FUSE_LIST "MIC")
# Set EZTRACE
If(SCALFMM_USE_EZTRACE)
find_package (PkgConfig)
if(PKG_CONFIG_FOUND)
MESSAGE(WARNING "PKG-CONFIG found")
set(PKG_CONFIG_USE_CMAKE_PREFIX_PATH "ON")
set(CMAKE_PREFIX_PATH "/cm/shared/dev/apps/trace/eztrace/1.0/lib/pkgconfig/")
pkg_search_module( EZTrace REQUIRED eztrace)
link_directories(${EZTrace_LIBRARY_DIRS})
# link_libraries(/cm/shared/dev/apps/trace/eztrace/1.0/lib/libeztrace.so /cm/shared/dev/apps/trace/eztrace/1.0/lib/libeztrace-memory.so)# ${EZTrace_LIBRARIES})
link_libraries( ${EZTrace_LIBRARIES} -leztrace-memory)
include_directories(${EZTrace_INCLUDE_DIRS})
MESSAGE(WARNING "EZTRACE: ${EZTrace_INCLUDE_DIRS} ${EZTrace_LIBRARY_DIRS} ${EZTrace_LIBRARIES}")
else(PKG_CONFIG_FOUND)
MESSAGE(WARNING "PKG-CONFIG not found- EZTRACE Is set to NONE")
set(SCALFMM_USE_EZTRACE OFF)
endif(PKG_CONFIG_FOUND)
endif(SCALFMM_USE_EZTRACE)
# END SETTING VARIABLES #
......@@ -209,7 +209,18 @@ protected:
/** M2L */
void transferPass(){
/** M2L */
#ifdef SCALFMM_USE_EZTRACE
eztrace_start();
#endif
this->transferPassWithFinalize() ;
eztrace_stop();
#endif
void transferPassWithFinalize(){
FLOG( FLog::Controller.write("\tStart Downward Pass (M2L)\n").write(FLog::Flush); );
FLOG(FTic counterTime);
Supports Markdown
