Commit 86e28572 authored by berenger-bramas's avatar berenger-bramas
Finalize the periodic system and add some tests to validate.
git-svn-id: svn+ssh://scm.gforge.inria.fr/svn/scalfmm/scalfmm/trunk@257 2616d619-271b-44dc-8df4-d4a8f33a7222
parent 32021c8d
...@@ -30,6 +30,7 @@ class FFmmAlgorithmPeriodic : protected FAssertable{ ...@@ -30,6 +30,7 @@ class FFmmAlgorithmPeriodic : protected FAssertable{
KernelClass* const kernels; //< The kernels KernelClass* const kernels; //< The kernels
const int OctreeHeight; const int OctreeHeight;
const int periodicLimit;
public: public:
/** The constructor need the octree and the kernels used for computation /** The constructor need the octree and the kernels used for computation
...@@ -37,8 +38,8 @@ public: ...@@ -37,8 +38,8 @@ public:
* @param inKernels the kernels to call * @param inKernels the kernels to call
* An assert is launched if one of the arguments is null * An assert is launched if one of the arguments is null
FFmmAlgorithmPeriodic(OctreeClass* const inTree, KernelClass* const inKernels) FFmmAlgorithmPeriodic(OctreeClass* const inTree, KernelClass* const inKernels, const int inPeriodicLimit = 0)
: tree(inTree) , kernels(inKernels), OctreeHeight(tree->getHeight()) { : tree(inTree) , kernels(inKernels), OctreeHeight(tree->getHeight()), periodicLimit(inPeriodicLimit) {
fassert(tree, "tree cannot be null", __LINE__, __FILE__); fassert(tree, "tree cannot be null", __LINE__, __FILE__);
fassert(kernels, "kernels cannot be null", __LINE__, __FILE__); fassert(kernels, "kernels cannot be null", __LINE__, __FILE__);
...@@ -242,8 +243,11 @@ private: ...@@ -242,8 +243,11 @@ private:
/** Periodicity */ /** Periodicity */
void processPeriodicLevels(){ void processPeriodicLevels(){
const int PeriodicLimit = 10; if( !periodicLimit ){
CellClass upperCells[PeriodicLimit]; return;
CellClass upperCells[periodicLimit];
// First M2M from level 1 to level 0 // First M2M from level 1 to level 0
...@@ -254,7 +258,7 @@ private: ...@@ -254,7 +258,7 @@ private:
// Then M2M from level 0 to level -LIMITE // Then M2M from level 0 to level -LIMITE
CellClass* virtualChild[8]; CellClass* virtualChild[8];
for(int idxLevel = 1 ; idxLevel < PeriodicLimit ; ++idxLevel){ for(int idxLevel = 1 ; idxLevel < periodicLimit ; ++idxLevel){
for(int idxChild = 0 ; idxChild < 8 ; ++idxChild){ for(int idxChild = 0 ; idxChild < 8 ; ++idxChild){
virtualChild[idxChild] = &upperCells[idxLevel-1]; virtualChild[idxChild] = &upperCells[idxLevel-1];
...@@ -282,7 +286,7 @@ private: ...@@ -282,7 +286,7 @@ private:
const CellClass* neighbors[189]; const CellClass* neighbors[189];
const int counter = 189; const int counter = 189;
for(int idxLevel = 0 ; idxLevel < PeriodicLimit ; ++idxLevel ){ for(int idxLevel = 0 ; idxLevel < periodicLimit ; ++idxLevel ){
for(int idxNeigh = 0 ; idxNeigh < 189 ; ++idxNeigh){ for(int idxNeigh = 0 ; idxNeigh < 189 ; ++idxNeigh){
neighbors[idxNeigh] = &upperCells[idxLevel]; neighbors[idxNeigh] = &upperCells[idxLevel];
...@@ -295,7 +299,7 @@ private: ...@@ -295,7 +299,7 @@ private:
memset(virtualChild, 0, sizeof(CellClass*) * 8); memset(virtualChild, 0, sizeof(CellClass*) * 8);
for(int idxLevel = PeriodicLimit - 1 ; idxLevel > 0 ; --idxLevel){ for(int idxLevel = periodicLimit - 1 ; idxLevel > 0 ; --idxLevel){
virtualChild[0] = &upperCells[idxLevel-1]; virtualChild[0] = &upperCells[idxLevel-1];
kernels->L2L( &upperCells[idxLevel], virtualChild, -idxLevel); kernels->L2L( &upperCells[idxLevel], virtualChild, -idxLevel);
...@@ -85,10 +85,9 @@ int main(int argc, char ** argv){ ...@@ -85,10 +85,9 @@ int main(int argc, char ** argv){
std::cout << ">> This executable has to be used to test the FMM algorithm.\n"; std::cout << ">> This executable has to be used to test the FMM algorithm.\n";
const int NbLevels = FParameters::getValue(argc,argv,"-h", 9); const int NbLevels = FParameters::getValue(argc,argv,"-h", 7);
const int SizeSubLevels = FParameters::getValue(argc,argv,"-sh", 3); const int SizeSubLevels = FParameters::getValue(argc,argv,"-sh", 3);
const long NbPart = FParameters::getValue(argc,argv,"-nb", 2000000); const long NbPartPerBoxes = FParameters::getValue(argc,argv,"-nb", 3);
const FReal FRandMax = FReal(RAND_MAX);
FTic counter; FTic counter;
...@@ -97,22 +96,41 @@ int main(int argc, char ** argv){ ...@@ -97,22 +96,41 @@ int main(int argc, char ** argv){
OctreeClass tree(NbLevels, SizeSubLevels, 1.0, F3DPosition(0.5,0.5,0.5)); const FReal BoxWidth = 1.0;
const FReal BoxCenter = 0.5;
OctreeClass tree(NbLevels, SizeSubLevels, BoxWidth, F3DPosition(BoxCenter,BoxCenter,BoxCenter));
std::cout << "Creating & Inserting " << NbPart << " particles ..." << std::endl; std::cout << "Creating & Inserting " << NbPartPerBoxes << " particles per boxes ..." << std::endl;
std::cout << "\tHeight : " << NbLevels << " \t sub-height : " << SizeSubLevels << std::endl; std::cout << "\tHeight : " << NbLevels << " \t sub-height : " << SizeSubLevels << std::endl;
counter.tic(); counter.tic();
long NbPart = 0;
const long NbSmallBoxesPerSide = (1 << (NbLevels-1));
const FReal SmallBoxWidth = BoxWidth / FReal(NbSmallBoxesPerSide);
const FReal SmallBoxWidthDiv2 = SmallBoxWidth / 2;
NbPart = NbSmallBoxesPerSide * NbSmallBoxesPerSide * NbSmallBoxesPerSide * NbPartPerBoxes;
FTestParticle particleToFill; FTestParticle particleToFill;
for(int idxPart = 0 ; idxPart < NbPart ; ++idxPart){
particleToFill.setPosition(FReal(rand())/FRandMax,FReal(rand())/FRandMax,FReal(rand())/FRandMax); for(int idxX = 0 ; idxX < NbSmallBoxesPerSide ; ++idxX){
for(int idxY = 0 ; idxY < NbSmallBoxesPerSide ; ++idxY){
for(int idxZ = 0 ; idxZ < NbSmallBoxesPerSide ; ++idxZ){
particleToFill.setPosition(FReal(idxX)*SmallBoxWidth + SmallBoxWidthDiv2,
FReal(idxY)*SmallBoxWidth + SmallBoxWidthDiv2,
FReal(idxZ)*SmallBoxWidth + SmallBoxWidthDiv2);
for(int idxPart = 0 ; idxPart < NbPartPerBoxes ; ++idxPart){
tree.insert(particleToFill); tree.insert(particleToFill);
counter.tac(); counter.tac();
std::cout << "Done " << "(@Creating and Inserting Particles = " << counter.elapsed() << "s)." << std::endl; std::cout << "Done " << "(@Creating and Inserting Particles = " << counter.elapsed() << "s)." << std::endl;
...@@ -123,10 +141,11 @@ int main(int argc, char ** argv){ ...@@ -123,10 +141,11 @@ int main(int argc, char ** argv){
std::cout << "Working on particles ..." << std::endl; std::cout << "Working on particles ..." << std::endl;
const int PeriodicDeep = 1;
// FTestKernels FBasicKernels // FTestKernels FBasicKernels
KernelClass kernels; KernelClass kernels;
//FFmmAlgorithm FFmmAlgorithmThread //FFmmAlgorithm FFmmAlgorithmThread
FmmClass algo(&tree,&kernels); FmmClass algo( &tree, &kernels, PeriodicDeep);
algo.execute(); algo.execute();
...@@ -137,6 +156,107 @@ int main(int argc, char ** argv){ ...@@ -137,6 +156,107 @@ int main(int argc, char ** argv){
//ValidateFMMAlgo<OctreeClass, ParticleClass, CellClass, ContainerClass, LeafClass>(&tree); //ValidateFMMAlgo<OctreeClass, ParticleClass, CellClass, ContainerClass, LeafClass>(&tree);
{ // Check that each particle has been summed with all other
long counterNbPart = 0;
typename OctreeClass::Iterator octreeIterator(&tree);
octreeIterator.gotoBottomLeft();
do{
// on each leaf we should have the same number of particles
if(octreeIterator.getCurrentCell()->getDataUp() != octreeIterator.getCurrentListSrc()->getSize()
|| NbPartPerBoxes != octreeIterator.getCurrentCell()->getDataUp() ){
std::cout << "Problem P2M NbPartPerBoxes = " << NbPartPerBoxes <<
" Data up = " << octreeIterator.getCurrentCell()->getDataUp() <<
" Size = " << octreeIterator.getCurrentListSrc()->getSize() << "\n";
// we also count the number of particles.
counterNbPart += octreeIterator.getCurrentListSrc()->getSize();
} while(octreeIterator.moveRight());
if( counterNbPart != NbPart){
std::cout << "Problem global nb part, counter = " << counterNbPart << " created = " << NbPart << std::endl;
{ // Ceck if there is number of NbPart summed at level 1
long long particlesPerBox = NbPartPerBoxes;
for(int idxLevel = NbLevels - 1 ; idxLevel >= 1 ; --idxLevel ){
do{
if(octreeIterator.getCurrentCell()->getDataUp() != particlesPerBox){
std::cout << "Problem M2M particlesPerBox = " << particlesPerBox <<
" level = " << idxLevel << "\n";
octreeIterator.moveUp();
octreeIterator.gotoLeft();
particlesPerBox *= 8;
if( PeriodicDeep ){
long long int counterL2L = 0;
long long int particlesPerBox = NbPartPerBoxes * FMath::pow(8,NbLevels-1);
long long int counterUp[PeriodicDeep];
for( int idxLevel = 0 ; idxLevel < PeriodicDeep ; ++idxLevel ){
counterUp[idxLevel] = particlesPerBox;
long long int counterM2L[PeriodicDeep];
counterM2L[idxLevel] = counterUp[idxLevel] * 189;
for( int idxLevel = PeriodicDeep - 1 ; idxLevel >= 0 ; --idxLevel ){
counterL2L += counterM2L[idxLevel];
long long int particlesPerBox = NbPartPerBoxes * FMath::pow(8,NbLevels-2);
for(int idxLevel = 1 ; idxLevel < NbLevels ; ++idxLevel ){
counterL2L = particlesPerBox * 189 + counterL2L;
do{
if(octreeIterator.getCurrentCell()->getDataDown() != counterL2L){
std::cout << "Problem L2L counterL2L = " << counterL2L <<
" Data Down = " << octreeIterator.getCurrentCell()->getDataDown() <<
octreeIterator.moveDown();
particlesPerBox /= 8;
do{
typename ContainerClass::BasicIterator iter(*octreeIterator.getCurrentListTargets());
const long long int sumParticles = octreeIterator.getCurrentCell()->getDataDown() + (26 * NbPartPerBoxes) + (NbPartPerBoxes - 1);
while( iter.hasNotFinished() ){
if( sumParticles != iter.data().getDataDown()){
std::cout << "P2P probleme, should be " << sumParticles <<
" iter.data().getDataDown() "<< iter.data().getDataDown() << std::endl;
iter.gotoNext();
