Une nouvelle version du portail de gestion des comptes externes sera mise en production lundi 09 août. Elle permettra d'allonger la validité d'un compte externe jusqu'à 3 ans. Pour plus de détails sur cette version consulter : https://doc-si.inria.fr/x/FCeS
Commit 7dcb5cc7 authored by BRAMAS Berenger's avatar BRAMAS Berenger
Add a draft for the blocked tree
parent bdfd2987
#include "../../Src/Utils/FAssert.hpp"
#include "../../Src/Containers/FTreeCoordinate.hpp"
#include <list>
#include <functional>
template <class CellClass>
class FBlockedTree {
protected:
* @brief The FBlockOfCells class manages the cells in block allocation.
class FBlockOfCells {
/** One header is allocated at the beginning of each block */
struct BlockHeader{
MortonIndex startingIndex;
MortonIndex endingIndex;
int numberOfCellsInBlock;
int blockIndexesTableSize;
//< This value is for not used cells
static const int CellIsEmptyFlag = -1;
protected:
//< Pointer to a block memory
unsigned char* memoryBuffer;
//< Pointer to the header inside the block memory
BlockHeader* blockHeader;
//< Pointer to the indexes table inside the block memory
int* blockIndexesTable;
//< Pointer to the cells inside the block memory
CellClass* blockCells;
public:
* @brief FBlockOfCells
* @param inStartingIndex first cell morton index
* @param inEndingIndex last cell morton index + 1
* @param inNumberOfCells total number of cells in the interval (should be <= inEndingIndex-inEndingIndex)
FBlockOfCells(const MortonIndex inStartingIndex, const MortonIndex inEndingIndex, const int inNumberOfCells)
: memoryBuffer(0), blockHeader(0), blockIndexesTable(0), blockCells(0){
// Find the number of cell to allocate in the blocks
const int blockIndexesTableSize = int(inEndingIndex-inStartingIndex);
FAssertLF(inNumberOfCells <= blockIndexesTableSize);
// Total number of bytes in the block
const size_t memoryToAlloc = sizeof(BlockHeader) + (blockIndexesTableSize*sizeof(int)) + (inNumberOfCells*sizeof(CellClass));
// Allocate
memoryBuffer = new unsigned char[memoryToAlloc];
FAssertLF(memoryBuffer);
memset(memoryBuffer, 0, memoryToAlloc);
// Move the pointers to the correct position
blockHeader = reinterpret_cast<BlockHeader*>(memoryBuffer);
blockIndexesTable = reinterpret_cast<int*>(memoryBuffer+sizeof(BlockHeader));
blockCells = reinterpret_cast<CellClass*>(memoryBuffer+sizeof(BlockHeader)+(blockIndexesTableSize*sizeof(int)));
// Init header
blockHeader->startingIndex = inStartingIndex;
blockHeader->endingIndex = inEndingIndex;
blockHeader->numberOfCellsInBlock = inNumberOfCells;
blockHeader->blockIndexesTableSize = blockIndexesTableSize;
// Set all index to not used
for(int idxCellPtr = 0 ; idxCellPtr < blockIndexesTableSize ; ++idxCellPtr){
blockIndexesTable[idxCellPtr] = CellIsEmptyFlag;
/** Call the destructor of cells and dealloc block memory */
~FBlockOfCells(){
for(int idxCellPtr = 0 ; idxCellPtr < blockHeader->blockIndexesTableSize ; ++idxCellPtr){
if(blockIndexesTable[idxCellPtr] != CellIsEmptyFlag){
(&blockCells[blockIndexesTable[idxCellPtr]])->~CellClass();
delete[] memoryBuffer;
/** The index of the fist cell (set from the constructor) */
MortonIndex getStartingIndex() const {
return blockHeader->startingIndex;
/** The index of the last cell + 1 (set from the constructor) */
MortonIndex getEndingIndex() const {
return blockHeader->endingIndex;
/** The number of cell (set from the constructor) */
int getNumberOfCellsInBlock() const {
return blockHeader->numberOfCellsInBlock;
/** The size of the interval endingIndex-startingIndex (set from the constructor) */
int getSizeOfInterval() const {
return blockHeader->blockIndexesTableSize;
/** Return true if inIndex should be located in the current block */
bool isInside(const MortonIndex inIndex) const{
return blockHeader->startingIndex <= inIndex && inIndex < blockHeader->endingIndex;
/** Return true if inIndex is located in the current block and is not empty */
bool exists(const MortonIndex inIndex) const {
return isInside(inIndex) && (blockIndexesTable[inIndex-blockHeader->startingIndex] != CellIsEmptyFlag);
/** Return the address of the cell if it exists (or NULL) */
CellClass* getCell(const MortonIndex inIndex){
if( exists(inIndex) ) return &blockCells[blockIndexesTable[inIndex-blockHeader->startingIndex]];
else return 0;
const CellClass* getCell(const MortonIndex inIndex) const {
else return 0;
/** Allocate a new cell by calling its constructor */
template<typename... CellConstructorParams>
void newCell(const MortonIndex inIndex, const int id, CellConstructorParams... args){
FAssertLF(isInside(inIndex));
FAssertLF(!exists(inIndex));
FAssertLF(id < blockHeader->blockIndexesTableSize);
new((void*)&blockCells[id]) CellClass(args...);
blockIndexesTable[inIndex-blockHeader->startingIndex] = id;
/** Iterate on each allocated cells */
template<typename... FunctionParams>
void forEachCell(std::function<void(CellClass*)> function, FunctionParams... args){
function(&blockCells[blockIndexesTable[idxCellPtr]], args...);
//< height of the tree (1 => only the root)
const int treeHeight;
//< max number of cells in a block
const int nbCellsPerBlocks;
//< all the blocks of the tree
std::list<FBlockOfCells*>* cellBlocksPerLevel;
public:
/** This constructor create a blocked octree from a usual octree
* The cell are allocated as in the usual octree (no copy constructor are called!)
* Once allocated each cell receive its morton index and tree coordinate.
* No blocks are allocated at level 0.
template<class OctreeClass>
FBlockedTree(const int inTreeHeight, const int inNbCellsPerBlock, OctreeClass*const inOctreeSrc)
: treeHeight(inTreeHeight), nbCellsPerBlocks(inNbCellsPerBlock), cellBlocksPerLevel(0){
cellBlocksPerLevel = new std::list<FBlockOfCells*>[treeHeight];
// Iterate on the tree and build
typename OctreeClass::Iterator octreeIterator(inOctreeSrc);
octreeIterator.gotoBottomLeft();
// For each level from heigth - 1 to 1
for(int idxLevel = treeHeight-1; idxLevel > 0 ; --idxLevel){
typename OctreeClass::Iterator avoidGotoLeft = octreeIterator;
// For each cell at this level
do {
typename OctreeClass::Iterator blockIteratorInOctree = octreeIterator;
// Move the iterator per nbCellsPerBlocks (or until it cannot move right)
int sizeOfBlock = 1;
while(sizeOfBlock < nbCellsPerBlocks && octreeIterator.moveRight()){
sizeOfBlock += 1;
// Create a block with the apropriate parameters
FBlockOfCells*const newBlock = new FBlockOfCells(blockIteratorInOctree.getCurrentGlobalIndex(),
octreeIterator.getCurrentGlobalIndex()+1,
sizeOfBlock);
// Initialize each cell of the block
int cellIdInBlock = 0;
while(cellIdInBlock != sizeOfBlock){
const CellClass*const oldNode = blockIteratorInOctree.getCurrentCell();
newBlock->newCell(oldNode->getMortonIndex(), cellIdInBlock);
CellClass* newNode = newBlock->getCell(oldNode->getMortonIndex());
newNode->setMortonIndex(oldNode->getMortonIndex());
newNode->setCoordinate(oldNode->getCoordinate());
cellIdInBlock += 1;
blockIteratorInOctree.moveRight();
// Keep the block
cellBlocksPerLevel[idxLevel].push_back(newBlock);
// If we can move right then add another block
} while(octreeIterator.moveRight());
avoidGotoLeft.moveUp();
octreeIterator = avoidGotoLeft;
/** This function dealloc the tree by deleting each block */
~FBlockedTree(){
for(int idxLevel = 0 ; idxLevel < treeHeight ; ++idxLevel){
std::list<FBlockOfCells*>& levelBlocks = cellBlocksPerLevel[idxLevel];
for (FBlockOfCells* &block: levelBlocks){
delete block;
delete[] cellBlocksPerLevel;
// Lambda function to apply to all member
* @brief forEachLeaf iterate on the leaf and apply the function
* @param function
//void forEachLeaf(std::function<void(LeafClass*)> function){
// TODO
* @brief forEachLeaf iterate on the cell and apply the function
* @param function
void forEachCell(std::function<void(CellClass*)> function){
block->forEachCell(function);
* @param function
void forEachCellWithLevel(std::function<void(CellClass*,const int)> function){
block->forEachCell(function, idxLevel);
* @param function
//void forEachCellLeaf(std::function<void(CellClass*,LeafClass*)> function){
// TODO
#include "../../Src/Components/FSimpleLeaf.hpp"
#include "../../Src/Containers/FVector.hpp"
#include "../../Src/Containers/FOctree.hpp"
#include "../../Src/Core/FFmmAlgorithm.hpp"
#include "../../Src/Kernels/P2P/FP2PParticleContainer.hpp"
#include "../../Src/Kernels/Rotation/FRotationKernel.hpp"
#include "../../Src/Kernels/Rotation/FRotationCell.hpp"
#include "../../Src/Utils/FMath.hpp"
#include "../../Src/Utils/FMemUtils.hpp"
#include "../../Src/Utils/FParameters.hpp"
#include "../../Src/Core/FFmmAlgorithmThread.hpp"
#include "../../Src/Core/FFmmAlgorithmTask.hpp"
#include "../../Src/Files/FFmaLoader.hpp"
int main(int argc, char* argv[]){
static const int P = 9;
typedef FRotationCell<P> CellClass;
typedef FP2PParticleContainer ContainerClass;
typedef FSimpleLeaf< ContainerClass > LeafClass;
typedef FOctree< CellClass, ContainerClass , LeafClass > OctreeClass;
typedef FRotationKernel< CellClass, ContainerClass , P> KernelClass;
typedef FBlockedTree< CellClass > BlockedOctreeClass;
FTic counter;
const int NbLevels = FParameters::getValue(argc,argv,"-h", 5);
const int SizeSubLevels = FParameters::getValue(argc,argv,"-sh", 3);
const char* const filename = FParameters::getStr(argc,argv,"-f", "../Data/test20k.fma");
FFmaLoader loader(filename);
FAssertLF(loader.isOpen());
OctreeClass tree(NbLevels, SizeSubLevels, loader.getBoxWidth(), loader.getCenterOfBox());
for(int idxPart = 0 ; idxPart < loader.getNumberOfParticles() ; ++idxPart){
FPoint particlePosition;
FReal physicalValue;
loader.fillParticle(&particlePosition,&physicalValue);
tree.insert(particlePosition, physicalValue );
std::cout << "Done " << "(@Creating and Inserting Particles = " << counter.tacAndElapsed() << "s)." << std::endl;
const int blockSize = FParameters::getValue(argc,argv,"-bs", 250);
counter.tic();
BlockedOctreeClass blockedTree(NbLevels, blockSize, &tree);
std::cout << "Done " << "(@Converting the tree = " << counter.tacAndElapsed() << "s). Block size is " << blockSize << "." << std::endl;
blockedTree.forEachCell([&](CellClass * cell){
std::cout << "Cell " << cell->getMortonIndex() << std::endl;
return 0;
